Question about Element Electronics Televison & Video
Cannot find digital channels on element tv - Element Electronics Televison & Video
I have a element tv and use antenna for all my tvs I use but when I scan for channels it does not show or scan any digital channels only scans RF
sorry but FIXYA has no idea where you are or what is available there . check with any local tv sales or service company
Oct 09, 2017 | Element Televison & Video
19" Element HD Digital LED TV Model ELEFW195 Does not scan Digital Channels just Analog Channels.
Auto-channel search can't find digital channels - Community ...
community.insigniaproducts.com/...channel...can...digital-channels/.../13...
Aug 6, 2010 - When I ran the auto-channel search it could only find 4 analog ... Notgetting Digital Channels on NS-26L450A11 ... I've plugged the cable from the wall into the TV, and preformed the auto channel scan, with "cable" selected.
Troubleshooting Guide for Digital-to-Analog Converter Boxes
https://www.fcc.gov/.../troubleshoo...
Federal Communications CommissionIf you aren't receiving digital signals on your analog TV, you can purchase a ...antennas are designed only for reception of either VHF or UHF signals (but not both). ...The channel scan will automatically search for digital broadcast channels ...
Antennas and Digital Television ' Federal Communication
Jan 13, 2016 | Televison & Video
I cant get digital channels on my element 40 inch element plasma t v why
Perhaps your TV is not compatible with the new digital signals you now get from your provider. But you should be able to get (buy) a digital receiver from your provider, that is can receive all channels and can be connected to the TV with a HDMI cable.
Apr 19, 2015 | Element ELCHW402 40 in. LCD HDTV
Why cant i get my digital channels
Is your TV designed for digital signals, if not you will need a set top box. Make sure the aerial is in good order and all connections are tight and clean , go into settings on the TV, select digital tuning and press ok , if the TV is in good condition and there is a signal digital to the aerial it will download
I have an Element ELEFT502 50 HD Digital tv. I am trying to connect my cable line to the TV but cannot get the past the auto scan screen
put the co axel cable in the back , bypass this tv programming stuff put your tv on channel 3 or 4 and use the cable remote , no tv channels just cable
Feb 26, 2015 | Element Televison & Video
What channel to play videos on element tv
it used to be channel 3 but with new digital who can even guess
Jan 25, 2015 | Televison & Video
Digital tv channels
go to menu and select antenna type..
Jul 10, 2012 | Element ELCHW402 40 in. LCD HDTV
Program Blocked errors
I was having the same problem with the constant blue screen appearing with different error codes. Here is how I fixed the problem on my Elements 19": I did a channel search. I found there were 68 analog channels and 274 digital channels. On a hunch, I went into Skip Channels and checked off all the digital channels since I have basic cable. Although the tv is HD and did pick up the basic HD channels, I choose to skip those two since I do not have a cable box on that tv and only the basic channels were in HD (about 8). I watched my tv for two hours and blue screen appeared once every 30 minutes, but the next day it did not appear at all.
I concluded that those error messages are because those channels are blocked and we have not checked them off to be skipped. When checking the Skip Channels, as you highlight each channel it will either come in or it will not. You will find the "Blocked Program" errors are coming from channels that do not come in and you will need to skip those channels.
I hope you can understand how I solved my blue screen problem on my Elements tv. Good luck!
Nov 14, 2009 | Element Electronics FLX-1910 19 in. LCD...
Digital channels don't work anymore for my tv with
Switch position of televisions trial and error situation and let me know the result
Nov 16, 2017 | Element Electronics FLX-1910 19 in. LCD...
Televison & Video Logo
95 people viewed this question
Top Element Electronics Televison & Video Experts
LP
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
