Question about KNG America Geography Astronomy Globe
Globe doesn't light up any more.
  • 2,113 Answers
You can customize it and make it work again
Posted on Nov 28, 2013
Headlights wont work on 1998 mustang v6 Running lights brake lights and gauge lights work fine. The lights only trn on when i hold the high beam switch. Any suggestions?
check fuses and check globes . Globes might have two filaments and low beam ones has blown . Had this globe thing happen on two globes at the same time on Ford Falcon's Halogon globe headlights.
May 05, 2014 | Cars & Trucks
Light on tacho doesn't work
You can change the globe, otherwise the wire + or - is broken
Aug 12, 2012 | 1989 Yamaha FZR 1000
Connect the wire of the globe broadband doesn't work
globebroadband preffer IPs..try to encode the IP provided by globe for you..
Jul 11, 2011 | Computers & Internet
My ringgrip smartglow 6 hour timer globe which is used infrequently (when I go on holidays) has stopped working (no illumination). As I consider that it has not had a lot of work, the question is, is there...
I have three solutions to help you.
1/ The globe may have been bumped or jarred and the filament may be broken
The filament can be repaired.
Look through the small area of clear glass near the neck of the bulb, using a magnifying glass; and a torch at that area and other areas around the globe
to inspect the filament.
With your eye follow the filament connections very slowly from one end to the other,
until you find the break (if any).
Memorise roughly where it has the break in proportion to some reference on the outside of the globe (felt pen mark).
Then insert the globe into a portable corded fitting (mechanics light).
Holding the fitting in your hand, switch it on.
Move your hand around (so the globe is either upside down, left, right, or diagonal, etc),
gently jarring the globe, remembering the position of the break of the filament, try to cause the filament's broken end to touch the terminal where it originally broke off from (doesn't have to be the exact position of the terminal, but in that area).
With a little patience, you may cause it to touch, and when you do, the light will instantly come on, the filament will be repaired (welded back on), and may even outlast any other part of filament breaking in future.
Now the instant it comes on, don't move your hand for a minute or so, to allow it to properly weld, then switch off, allow it to cool, then remove from portable fitting.
2/ If the problem is not the filament, the electronics can also be repaired.
They are located in the bayonet part of the globe,
and are the second cause of failure.
A skilled technician can access and repair that area
for only $10 grand.
3/ A more economical remedy, however, is to hold the globe upside down
in your hand,
then slowly release it from a twenty storey window.
Hope one of these helps !
Mar 11, 2011 | Home
Left Brake light Globe fuses tazz 2000(New Shape)
Make sure you have the appropriate light bulb and fuse. Otherwise it has to be an intermittant short.
Oct 27, 2008 | 2000 Toyota Corolla
Replacement of Light globe in Ice Dispenser
USE LESS THAN 5W GLOBE IF AVAILABLE
OR
7 W IS A STANDARD GLOBE BEING NORMALLY USED, WILL & SHOULD NOT AFFECT THE POWER CIRCUIT AS PER MY EXPERIENCE
BEST WISHES
Dec 12, 2007 | Refrigerators
KNG America Geography Astronomy Globe Logo
Top KNG America Toys Experts
Andrew Taylor
Andrew Taylor
Are you a KNG America Toy Expert? Answer questions, earn points and help others
