Question about Invacare Pronto M51 Power Wheelchair
Battery level indicator fluxuiates
Battery indicator fluxuiates from full to needs charge and back to full
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 105 Answers
Some how u have a loose connection on the battery cables im thinking,check there first then all connections to joystick
Posted on Jan 19, 2014
How would i know that it is getting charged
When charging, the battery indicator will cycle from the current battery level to full. Once the battery is fully charged, the indicator will stop cycling.
Typically it takes approx. 6 hours to charge the battery from empty to full. (MMP8565 2GB Digital Audio Player)
Support Home Page
Feb 03, 2014 | Memorex Audio Players & Recorders
How will i know if the batt. is fully charge
Hello
Every phone has their own way to show the charging, Normally the running dots/line in the battery will show charging and stop this action will be the indicator of full charging.
Some phones shows the level of battery with colors, like red for empty and green for full images?q=tbn:and9gcrwklg9zmcido0et2bosnkz1j-trcwv6qjon7gf5ffz4alt-gtg Hope this helps if so do rate the solution
Jan 06, 2011 | Samsung Cell Phones
I drove it home and it was fine, i shut it off and within five mins i tried to start it and it would crank but wouldnt turn over, i tried a few more times and it nothing, but now my battery is going low...
The first and most likely indication of a low battery would be a hard starting problem caused by slow cranking. If the battery seems weak or fails to crank your engine normally, it may be low. To find out, you need to check the battery's "state of charge."
A battery is nothing more than a chemical storage device for holding electrons until they're needed to crank the engine or run the lights or other electrical accessories on your vehicle. Checking the battery's state of charge will tell you how much juice the battery has available for such purposes.
If your battery is low, it needs to be recharged, not only to restore full power, but also to prevent possible damage to the battery. Ordinary automotive lead-acid storage batteries must be kept at or near full charge to keep the cell plates from becoming "sulfated" (a condition that occurs if the battery is run down and left in a discharged condition for more than a few days). As sulfate builds up, it reduces the battery's ability to hold a charge and supply voltage. Eventually the battery becomes useless and must be replaced.
The charge level depends on the concentration of acid inside the battery. The stronger the concentration of acid in the water, the higher the specific gravity of the solution, and the higher the state of charge.
On batteries with removable caps, state of charge can be checked with a "hydrometer." Some hydrometers have a calibrated float to measure the specific gravity of the acid solution while others simply have a number of colored balls. On the kind with a calibrated float, a hydrometer reading of 1.265 (corrected for temperature) indicates a fully charged battery, 1.230 indicates a 75% charge, 1.200 indicates a 50% charge, 1.170 indicates a 25% charge, and 1.140 or less indicates a discharged battery. On the kind that use floating balls, the number of balls that float tells you the approximate level of charge. All balls floating would indicate a fully charged battery, no balls floating would indicate a dead or fully discharged battery.
Some sealed-top batteries have a built-in hydrometer to indicate charge. The charge indicator only reads one cell, but usually shows the average charge for all battery cells. A green dot means the battery is 75% or more charged and is okay for use or further testing. No dot (a dark indicator) means the battery is low and should be recharged before it is returned to service or tested further. A clear or yellow indicator means the level of electrolyte inside has dropped too low, and the battery should be replaced.
On sealed-top batteries that do not have a built-in charge indicator, the state of charge can be determined by checking the battery's base or open circuit voltage with a digital voltmeter or multimeter. This is done by touching the meter leads to the positive and negative battery terminals while the ignition key is off.
A reading of 12.66 volts indicates a fully charged battery; 12.45 volts is 75% charged, 12.24 volts is 50% charged, and 12.06 volts is 25% charged.
In recharging the battery do not attempt to recharge a battery with low (or frozen) electrolyte! Doing so risks blowing up the battery if the hydrogen gas inside is ignited by a spark.
Your charging system should be capable of recharging the battery if it is not fully discharged. Thirty minutes or so of normal driving should be enough.
If your battery is completely dead or extremely low, it should be recharged with a fast or slow charger. This will reduce the risk of overtaxing and damaging your vehicle's charging system. One or both battery cables should be disconnected from the battery prior to charging it with a charger. This will eliminate any risk of damage to your vehicle's electrical system or its onboard electronics.
Take care and good luck
NB: Your alternator might not also be charging the battery while the car is on, so try to check the alternator.
Alternators are pretty rugged, but can succumb to excessive heat and overwork. They can also be damaged by sudden voltage overloads (as when someone attempts to jump start a dead battery and crosses up the jumper connections or if someone disconnects a battery cable from the battery while the engine is running).
Sometimes alternators can partially fail. In the back of every alternator is a "diode trio" that converts the alternators AC (alternating current) output to DC (direct current). If one or more of these diodes fail, the alternator's amperage output will be reduced. It may continue to produce some current, but not enough to keep the battery fully charged -- especially at idle or low speed.
Most service facilities have test equipment that can identify these kind of problems. So if you suspect a weak alternator, you should have it tested to see if it needs replacing.
Most service facilities do not repair or rebuild alternators because it's too time consuming and requires special parts. Most will replace your old unit with a new or remanufactured unit. Your old alternator is usually traded in or exchanged for a credit (so it can be remanufactured and sold to someone else).
Oct 26, 2010 | Oldsmobile Alero Cars & Trucks
It powers off even when the battery indicator level is full. i have replaced the battery but the problem remains. when it powers off, the only way to get it back on is to put back on charge.
please check your ampire such as 1024 mah? if not please change your battery? for use many days then mobile battery become weak day by day. and another tips is please recharge your battery when the battery indicator come 1 level. and don't try short circuit of your battery. never charge from DC current. thanks
Jan 10, 2010 | Nokia E71 Smartphone
My wii remotes wont pick up signal blue lights flash then just go back out again
Hi, check the batter level and then try re-synching the remote's.
Here's instructions for both:
f4bc8924da.gif A fresh set of alkaline batteries should last, depending on amount and type of use, up to 35 hours. This can vary greatly based on certain factors, such as Wii Remote Speaker Volume, Rumble, battery quality and age, and type of game being played.
Important Note: If you are using rechargeable batteries, the only type of battery recommended are Nickel Metal Hydride batteries. When it comes to using rechargeable batteries, you must follow manufacturer guidelines for safety and proper usage. Failure to do so could cause damage to the Wii Remote and void the warranty.
There are two ways to check the Wii Remote's battery levels:
  • Remove the battery cover and press the Red "Sync" button. The number of lights flashing indicates the Wii Remote's battery strength. Four flashing lights indicates full strength, with one light flashing indicating the lowest level.
    or
  • Use the HOME Menu to check battery level of each Wii Remote:
    1. Press the HOME Button on a Wii Remote that is synchronized with the Wii console.
    2. Select the Wii Remote Settings option from the Home Menu.
    3. The battery level of all synced Wii Remotes is displayed along the bottom. Four bars indicates a full charge, with one being the lowest charge.
55851daefd.gif Note: Make sure you have placed batteries in the Wii Remote.
  1. Press the Power button on the Wii console to turn it on.
  2. Remove the battery cover on the back of the Wii Remote you wish to sync up, and press the SYNC button just below the batteries. The Player LED will blink.
  3. Open the SD Card Slot cover on the front of the Wii console and press the SYNC button on the inside of the compartment.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 to 4).
This procedure must be followed for each additional Wii Remote added to your system.
I hope this helps
Mike
Jul 30, 2009 | Nintendo Video Game Consoles & Games
Battery power on mobility scooter
Most scooters show a drop on the battery level meter when in use, as long as it is`nt slowing down it should`nt be a prob. I mean,when you engage the throttle you ARE putting a load on the batteries,so it`s only par for the course that the indicator would drop a bit.
Jan 04, 2009 | Pride Mobility Products Pride Mobility...
Invacare Pronto M51 Power Wheelchair Logo
27 people viewed this question
Top Invacare Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
gnshome
Level 1 Expert
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
