Question about Hunter Ceiling Fan Light Switch Control
MODEL # 27186-060, RECEIVER # 84368 LIGHTS FLICKER WHEN TURNED ON. WHAT GIVES?
WHEN I TURN ON THE LIGHTS, THEY FLICKER AND I HAVE NO CONTROL OVER THE FAN
The vizio set will not respond to remote to turn set on.
Point the remote at your cellphone camera and press a button. You should see a flicker from the remote if it is working. If no flicker then remote is defective. If you have a flicker then the problem lies in the t.v. could be the receiver or another issue in the t.v.
Jul 21, 2016 | Vizio 60" E601I-A3 Full HD LED-LCD TV
Control panel lights flicker, heater will not ignite
Possibly bad control board or a bad connection, need a little more info and I only have my phone to answer questions so I don't see the type of heater your posted under if you did.
Feb 28, 2016 | Hayward H400FDN Low NOx Natural Gas Pool...
How part no. CBB61 can replace part no. 84368?
CBB61 isn't a part number. it's more like a 'Type' number. The thing that matters is the uF (microfarad) value of the capacitor. If the uF value is close it (+ or - 1 uF) it will work fine.
May 04, 2014 | Hunter 52" Ceiling Fan With Light And...
Casablanca intellitouch 3 light flicker
Call Casablanca at 1-888-227-2178
Feb 19, 2013 | Dryers
A relay in my rooftop model 57915.33 chatters intermitently and trips the shore power breaker.
The reason the lights are not flickering and breaker not tripping when 6 pin harness disconnected that goes to roof unit is because the compressor and fan are disconnected, which would be the major draw that causes it. There is a few ways you can narrow down the cause, or defective relay, but my guess is if it's causing lights to flicker and breaker to trip, it's on the compressor circuit. The fan coming on and off unless capacitor faulty wouldn't draw it down that much, and obviously capacitor is good otherwise it wouldn't operate good when turned on normally. I'd start by inspecting wires to and from thermostat for possible rubbing or touching against one another at a bare spot perhaps. Can't rule out 100% that thermostat isn't defective as well. When thermostat set to cooler temperature, and on, does it turn off and on in normal cycles, to maintain temperature?
Nov 27, 2011 | Dometic Rooftop RV Air Conditioner
All my warning lights have come up on my ford laser 1989 giha model and every thing is fine new battery plenty of fuel oil full but still oil light on fuel light and charge batery light as well. i notice...
check all the earth connections and clean them. see if that sorts the problem any lights flicker usel means that the earthing is not good and its using another earth so the light will flicker on the device not being activated.
Jul 16, 2017 | 2006 Ford Laser
Lights flicker when turned off by remote
I had this same problem with a Hampton Bay fan with a remote light switch. I call the manufacturer of the of the switch and was told that the model switch I had would not work correctly with CFL bulbs. The problem is with the dimmer function. You either need to change the bulbs to incandescent, or change the remote receiver in the ceiling. Hampton Bay was kind enough to send me a new receiver that works with CFL. The CFL units are white, and the incandescent is black. Hope this helps you.
Feb 26, 2009 | Universal Remote Control Hampton Bay...
Underlights flicker while cooking.
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
If this continues, it can cause the lights and possibly the fan to go out and cause further damage to the control board.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Dec 13, 2008 | Samsung SMH7178STD Microwave Oven
Dryers Logo
113 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
