Question about Panasonic NV-FJ620 VHS/S-VHS playback VCR
Philips video problem is half picture on taped programs,and tape then ejects and video sometimes chews up tape???
  • 579 Answers
Time to have its belts replaced
Posted on Dec 31, 2007
How do I stop the vcr chewing tapes?
Probably bad drive belt need replacing.
Sep 18, 2014 | Televison & Video
A vhf tape got stuck in the machine. I could see the tape itself was caught on some moving prongs. now i don't know the proper setting for the prongs and cannot get any vhs tapes to play.
Hi, if VHS tape is in you have only one solution..to disassemble DVD/VCR ..Can you do it ? you may try !!t
Here's how to do it..
* 1 Turn off the COMBO. and unplug it.
* 2 Remove the 4x screws off COMBO on the sides and take off the DVD/VCR casing.
* 3 Look for the Tape which messed up with VCR transport mechanism ,try to release tape of the transport with your hand..
* 4 Since EJECT feature works with power only ,while you keep the tape off from transport plug the device to power and turn it on..Don't worry,you will see the eject mechanism starts moving back on forth,keep the tape off it and let it eject..
* 5.When tape is out .If it destroyed badly normally you should not use it however if the recording in is valuable for you you can cut the chewed portion and
splice it back together .(Pls see the video included...How to fix a broken VHS tape.)
* 6 While it is open,place another Tape to see if mechanism works properly. and eject it...
* 7 Replace the casing and the screws. Plug the player in and turn it on. Now player is finally working ..
Hope this helps!..
Take care and please
Remember to rate/vote and give us 4 Thumbs Up
to continue f
or Helping out the Community :)
http://www.youtube.com/watch?v=Q1PJWA2KGyg
Mar 13, 2011 | Philips DVD740VR DVD Player/VCR
Model is Sylvania DVC 840G, DVD/CD player with VCR. Have limited space. VCR on seperate shelf in cabinet, had to put two TV converters on top of VCR (top each side) so we could watch TV and tape a...
The tape mechanism belts have stretched and the unit is not running properly. When this happens, microprocessor is programmed to eject tape and shut down unit.
Apr 11, 2017 | Sylvania Televison & Video
A VHS tape is in the recorder but will not eject. The flap opens when eject key is pressed, the cassette comes up, does not come forward, and then goes back down. The recorder then switches itself off.
Hi, the problem is the tape has got chewed up inside the video the only way your going to get it out is by taking the case of but dont do this whilst its plugged in.
you need to take the tape off and you may have to cut the tape so you can put the case back on and switch it on so the tape will eject, you need to get what ever is keeping it stuck free, the chances are the tape has got chewed up around the drive and this will need cutting free to allow the tape to come out.
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks.
you could try fast forwarding a bit or rewinding a bit then try ejecting but failing that your going to need to take the case off to free the tape
Sep 01, 2010 | Panasonic DMR-E95HS DVD Recorder
It wont eject or play makes lound noise for a min
There is a broken plastic part on the cassette. Needs to be replaced.
Mostly caused by improper position of the tape and camera jam(tape jam)
needs sony camera technician who can replace the part inside the cassette.
Apr 03, 2010 | Sony Handycam DCR-TRV310 Digital Camcorder
Loaded tape into Samsung VP-L700U 8mm and received 'Emergency Eject' message. Tape now chewed. Repeated & ruined several new & used tapes, including cleaner tape. Camcorder was working a half...
Internal mounting screws for the tape chassis may have come loose and can no longer hold the tape in the correct position. You will need to disassemble the camcorder to access the tape mechanism.
Nov 15, 2017 | Samsung VP-L700U Camcorder
Why is my vcr chewing up tapes
The answer is easy take the top off the unit, and with an old video tape try it and watch what the video does. This is the only way really as the causes of tape damage are many, including objects that have got into the works. The only tape chew fault that can be put down to a single thing, is the crinkle bottom or top edge. Which is caused by the pinch roller being worn.
Once you see what it does you can post again and describe it, we are FixYa should be able to pin it down.
Feb 03, 2010 | Philips VR750 VHS VCR
Canon XM2 Chewing tapes
This seams to be the problem, all the time, plus the sound goes off on most of theses camcorders, and the only way they will work is with an boom, mic.
Could I use an tape clearer when it says eject?
Aug 02, 2008 | Canon DM-XM2 Mini DV Digital Camcorder
Cassette
Most VCR's will auto-rewind the tape when it gets to the end of a tape. Most will leave the tape in the unit assuming you may wish to view it again once rewound. Does the tape eject properly when you press the eject button? What does the manula say about the eject function?
- Jim
Jan 23, 2008 | Philips VR550 VHS VCR
Samsung SCD-5000 miniDV tape deck problem
Hi, I have a SCD 5000 Samsung camera. The video plays and records. But the camera side does not show in the video screen. HELP me
Jul 06, 2007 | Samsung DouCam SCD-5000 Mini DV Digital...
Panasonic NV-FJ620 VHS/S-VHS playback VCR Logo
63 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
