I need to knoe the right front fascia part number i need for my nissan 2005 altima 3.5,i believe it was replaced with a front end for a altima 2.5
    Problem Solver:
  • 19 Answers
Check with a Nissan dealer or a Used Parts (Junk Yard)
The junk yards Usually have interchange manual listings.
Posted on Nov 29, 2013
How do I locate ignition coil #3 on a 2005 Nissan Altima 4 cylinda?
on top of the engine remove the plastic cover depending on which model you will have 1. a coil pack for all 4 cylinders so you change the whole part or maybe 2. 4 seperate coils if so no.3 is 3rd from front of engine or 3rd from drive belt end as you look under hood
Apr 04, 2017 | Nissan Cars & Trucks
2005 Nissan Altima 2.5L - where is the heated oxygen sensor number 2 located
Oxygen sensors are mounted either side of the catalytic converter. Number 1 is mounted before the cat in the down pipe and the Number 2 is in the exhaust pipe just after the cat, think the number 2 is the downstream.
Jan 05, 2014 | 2005 Nissan Altima
How to replace driver side headlight 2003 nissan altima
To Remove:
  1. Ensure that the lighting switch is in the OFF position.
  2. Disconnect negative battery cable.
  3. Remove or disconnect the following:
  • Front Fascia
  • Headlamp mounting bolts.
  • Headlamp by sliding it foward.
  • Headlamp connectors.
To Install:
  1. Install or connect the following.
  • Headlamp and mounting bolts.
  • Front fascia.
  • Negative battery cable.
Jan 14, 2011 | 2003 Nissan Altima
Need step by step instructions on how to remove a rear bumper cover on a 2007 nissan altima
Rear Bumper: Service and Repair
REAR BUMPER
Removal and Installation
REMOVAL
1. Remove the LH and RH rear combination lamps.
2. Remove both the rear wheels and tires.
3. Remove the LH and RH splash shields.
4. Remove the rear bumper fascia clips and screws, then remove the rear bumper fascia.
5. Remove the rear energy absorbing foam.
6. Remove the rear bumper reinforcement.
7. Remove the rear bumper supports.
INSTALLATION
Installation is in the reverse order of removal.
Nov 12, 2009 | 2007 Nissan Altima 3.5 Sedan
Replacing headlight bulbs Altima2003
Removal and Installation To Remove:
  1. Ensure that lighting switch is in the OFF position.
    • Front fascia
    • Headlamp by sliding it forward
To Install:
  1. Install or connect the following:
      1. Torque to: 58 in. lbs. (6.5 Nm)
    • Front fascia
Oct 01, 2009 | 2003 Nissan Altima
How to replace front airbag sensor on 2005 nissan altima
1 First remove Both Positive and negitive battery terminals. wait atleast 3 minutes.
2 Remove front grille
3 Disconnect crash sensor Plug.Crash sensor is just below the hood latch.
4Remove crash sensor retaining nuts.
5 Remove crash sensor.
Installation is the reverse order
Sep 25, 2009 | 2005 Nissan Altima
How do I replace the alternator on a 2005 Nissan Altima?
first things you have to do to change nissan altima 2.5 alternator?
1- disconnect battery
2-from the top of alternator there will be 3 thing u have to open one is with bolt 12 mm and second is with screw star.
3-turn the starting full right there will be small cover 2 plastic clip and one 10 mm bolt.
4-from the down take 12 mm and turn the pulley which is bellow alternator with press.
5- take belt out (note that u have to draw the map of belt be4 take it out.
6-and install alternator back again in same steps.
Dec 26, 2008 | 2005 Nissan Altima
Location of oil filter on Nissan Altima 2005
The oil filter is located behind the right (passenger) inner fender cover. It is right next to the crankshaft pulley at the bottom of the front of the engine facing toward the right front wheel. I do not have a picture at this time.
Hope this is helpful!
Nissan Scope Technician- 10+ years experience in Nissan dealership.
Nov 04, 2008 | 2005 Nissan Altima
Replace Breaks/ Breaks pad for Nissan 2005 Altima
parts at napaautoparts.com are from 54 to 42 for the front pads. look the rest up chum
Sep 24, 2008 | 2005 Nissan Altima
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
