Question about Klip Xtreme KSS-710 2.1 Stereo Speaker System
Both mini speakers are playing, but not getting any sound from the base box.... what might be happening?
I'm using the Klip Xtreme KSS-710 2.1 Stereo Speaker System on my laptop. Both minispeakers are working properly. But the sound is very low from the main box. The volume and base were placed at maximum, yet very low sound
    Top Expert:
  • Klip Xtreme Master
  • 12,962 Answers
The mini sub woofer's amplifier is not working but the other amps powering the left and right channels are ok.
Posted on Nov 28, 2013
I have Sanyo M7755K mini boom box tape recorder. It is playing and I hear only audio from one speaker.The other speaker is silent. can you help me to solve the problem?
Check the stereo Balance control. If it is set to one end, that speaker won't output sound. If found the setting to this is set to mid-point, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Nov 17, 2014 | Sanyo Televison & Video
Downloaded music on sd card but can"t get it to play
Do you get normal sound other than that downloaded music? If so you may need to change the format the music is in. Do an internet search for "How to change the format on an audio file". What program you will need to use depends on the format the original is in.
Apr 10, 2014 | Universal Mini Speaker Tf Card/ Mp3/usb...
Speakers for Philips fwm154 stopped working
So the speakers are working but the mini hifi is not generating any sound to them. Replace the mini hifi, keep the speakers.
Dec 15, 2013 | Philips FWM154/05 MP3 Mini HiFi System
2000 Pontiac Sunfire after market stereo install. Got it installed the stereo powers on and acts like its playing but no sound is coming from the speakers.
new stereo in a box or used.
just the smallest of hints here. helps.
1 ,2,4, or how many speakers are dead.?
or
depress mute 1 time.
Oct 20, 2013 | Pontiac Sunfire Cars & Trucks
Onkyo HT S3300 center, left front and rear speaker not working.
check your speaker wiring, make sure both terminals are connected properly. or could just be left speaker is disconnected. and is set in stereo mode which will only play left and right front and Sub, if you have one. try chaning the surround mode to play in multi channel speaker which will send sound to all speakers. i trust your using a Digital audio cable from your source ( cable box, DVD player) if your using analog audio cable you will only get stereo sound, and nothing will ever come out of the rear speaker unless you change the surround mode to multi- channel speaker. also in the setup menu you should be able to perform a speaker setup, make sure all your speakers are able to produce sound. follow speaker setup mode in menu, make sure you have checked the boxes or Yes to speaker you have in your system. then perform calibration and a test tone will come out of each speaker as you select them.
Apr 28, 2011 | Audio Players & Recorders
I am not able to hear the dialog while playing DVDs. The background is great and comes through all 5 speakers, however, to be able to listen to the dialog, I have to switch over to 2-channel or Stereo. ...
Well let me first ask is the center chanel working? or properly hooked up. Cause most of the times when in 5.1 the talking or "dialog" as you put it comes only through the center channel its just kinda how they do it. Listen to see if the center channel is working. if you are unsure try hooking up a speaker that you know works into the center channel speaker output. If no sound comes out then the reciever possible has blown its center channel. Please follow up with a comment and i will be glad to assist you further thanks, Midwes-tek
Sep 17, 2010 | Coby DVD765 Theater System
Hello, i recently transfered my i tunes from one laptop to another. Now i have a crackle in every song, but not in the same place but in a different place epending on the tune.Please can you help me as i...
crackle is more likely from the mini cable running from your computer to your speakers. you can jiggle it around while playing music to see if this makes the crackle happen. replacement for a stereo mini , male to male is only a few dollars, unless you want a higher quality, or you are going to a bigger amp and speaker set up. then you could go from stereo mini to rca stereo.
Jun 25, 2009 | Computers & Internet
Kenwood Receiver connected to my pc
using the Y adapter method (i am guessing you are using just a single stereo mini-jack cable with a mini-jack to RCA adapter) you are only sending a standard Stereo signal to the receiver. Setting 5.1 in windows is just simulating (if using Stereo) or actually mixing 5.1 if you are using analog 5.1 (3 stereo mini-jack cables going to 3 mini-jack to RCA adapters using a 6 channel DVD input). if you have a surround sound audio card i suggest using the Analog 6 channel input by using 3 stereo cables each with their only adapter.
or, if you have a Digital output (Coaxial or TOSlink [optical]) try using that.
good luck.
Nov 12, 2008 | Kenwood VR-406 Receiver
I have a simple stereo speaker from Radio Shack. Small metal case with two wire input latches. Each box has two speakers in side. Both speakers boxes went out at the same time. I wasn't there when this...
You need to measure across the speakers themselves n ot the crossover (cap). If these are 8 ohm speakers, an ohm meter will read about 6 or so. That is because both impedence and resistance use the same measurement. With an ohm meter you are measuring resistance. The speakers are rated using impedence.
If both speakers are open (measure infinity), I would suspect a problem with the stereo that caused them to go open. With the stereo on and playing something (radio,cd , or whatever) use a DC voltmeter to measure between the speaker terminals (Red/Black). You should read essentially 0 no matter what the volume. If you read any DC more than 3/4 V, the problem is with the amp section of the stereo.
Dan
Jul 18, 2008 | Audio Players & Recorders
Sound problem
I have a creative SoundBlaster LIVE! 24 Bit External Sound Card and this annoyed me for weeks.
depending on your surround sound reciever depends on the solution.
i have an Acoustic Solutions surround sound system with coxial and optical inputs, aswell as stereo red & white jack inputs.
not knowing the method or connection your using makes it difficult to give you a single solution so i'll list a few.
The soundblaster software shoudl include the Creative Audio console with all sorts of effects, one is CMSS (CMSS-3D) Stereo widening which is still stereo but gives a surround sound effect.. but i'm guessing you payed for 5.1 and you want 5.1 onto the next part
5.1 surround sound can only be produced when the actuall audio your playing contains 5 channels of audio, for example you cant play a stereo song in 5.1 surround sound without some sort of hardware or software sound manipulation. Luckily my surround sound system has Pro Logic II built in and some other effects which convert a 2.1 signal to a 5.1 signal and it works brilliantly. I'm not sure of a software alternative.
setup for your soundcard will be different under XP and Vista also, but there should be a properties option for your sound device where you can select your speaker setup such as headphones, built in speakers, 2.1 speakers, 5.1 speakers, 7.1 speakers and you should be able to manage this from the creative software.
If using Coxial / Optical or SPDIF under vista you MUST set the playback device as SPDIF, at least you have to with my sound card and drivers and seems to be a limitation of the actual sound card drivers for vista.
Personally i was looking forward to hearing the windows login melody in 5.1 surround sound too, but this doesnt happen.
Infact i find that almost all programs bar a few will not play Dolby Digital or DTS 5.1 surround sound via any or my output options hence the next solution..
if you have the 5.1 sound but winamp simply just plays it in stereo try the following.
You need to use DirectSound Output:
Preferences (Ctrl-P) > Plug-ins > Output > Select "DirectSound Output"
That should work in most cases, but if not, then:
Checkmark: "Allow hardware acceleration" in DirectSound Output config,
and make sure your sound card/chip is selected as Output Device.
Note that any changes will take effect only after playback is restarted.
In some cases, a Winamp restart is required.
If that doesn't work make sure you have the latest version of DirectX
(v8.x or higher is required)
Winamp 5.25/5.3 and higher:
For actual multi-channel files (ie. aac/wav/ac3/ogg/wma files encoded in 5.1ch surround, as opposed to standard 2-channel stereo mp3's), you need to checkmark "Allow surround sound" in 'Winamp > Prefs > Playback' for the music to play in its original 5.1 channel format (Note that this setting is checkmarked by default).
Windows Vista:
In addition to the above instructions, Vista users will also need to go to:
Control Panel > Sound > Playback tab > Speakers > Configure:
Select: 5.1/7.1 Surround.
Then:
Control Panel > Sound > Playback tab > Speakers > Properties > Enhancements tab
and checkmark "Speaker Fill"
Hope this helps
Anthony Kinson
Apr 22, 2008 | Audio Players & Recorders
Klip Xtreme KSS-710 2.1 Stereo Speaker System Logo
88 people viewed this question
Top Klip Xtreme Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Klip Xtreme Audio Player and Recorder Expert? Answer questions, earn points and help others
