Question about Dryers
Tappan dryer do'nt heat
    Sergeant:
  • Dryers Expert
  • 448 Answers
Model # need for info to be corect
Posted on Dec 06, 2013
Why machine tumbles without drying and indicating E68?
not sure bout the code however need to check heating element with a multi meter and check thermostats also, also are u getting a full 240 at the terminal?
May 15, 2014 | Frigidaire 131758600 Washer Washing...
Zanussi ZWD 1270 no heat
E72 can also be caused by broken wiring to the NTC(Sensor). If the wiring is low voltage( very thin wires) then pull gently on the wires where they go into the NTC. If they break away there is the problem, you would need to replace the wiring harness for that NTC. Also, check the fan motor is running and the belt on the ventilator has nt stretched. If all is ok check the condenser is nt blocked with lint
Mar 11, 2014 | Zanussi ZWD1270 Front Load Washer / Dryer
Dryer is on and spins but does'nt heat up, what could the problem be?
probably the fuse in back of the machine, I had the same problem and that was the fix, easy to do.
Nov 15, 2011 | Dryers
My kenmore h5 elite electric dryer does not heat. i checked the heating element and it looked bad so i replaced it and it still does nt heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 04, 2011 | Kenmore HE5 Electric Dryer
My dryer runs but is not heating up. I am looking at the heating element and it does nt look bad. What else can it be?
Thermostats or thermal fuse more than likely. Use an ohm meter to check the continuity across t stats and thermal fuses. Get a cheap ohmeter at any hardware for around $12
Mar 24, 2011 | Amana NED7200TW Electric Dryer
How do take a Tappan gas dryer apart to get heating element?
all that unbolts from the bottom and comes out the back however if you are not a service tech wi ouldnt suggest to remove anything cause i seen too many try and end up with a gas leak and blow the house up!!
Jan 14, 2010 | Dryers
Roper dryer runs but has no heat
my roper dryer does not heat up i checked thermostat, thremo fuse and heating element they show working could it be my timer when dryer is running timer does nt advance it stays in the same position.
Jan 11, 2010 | Dryers
Tappan gas clothes dryer: Burner problem
Two possibilities are the coils on the valve or the valve its self. MOST cases the soils are the problem. How old is it? Do the coils on the valve have quick connects or are there wires coming out of them?
Let me know if I can help further.
Vic
May 10, 2009 | Dryers
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
