Question about Microwave Ovens
Black piece on the bottom won't spin - Microwave Ovens
  • Microwave Ovens Master
  • 2,113 Answers
Replace the belt
Posted on Nov 28, 2013
My turntable doesn't turn
Sounds like the turntable drive coupling is broken. In the bottom of the microwave where your turntable is, underneath that is a small drive coupling that the motor shaft pushes into. if the motor doesn't turn or the coupling, which commonly has a D shape shaft to keep it from slipping, is broken, the tray will not turn. One quick test it to remove your tray and see if you can turn the coupling easily by hand, if you can you probably have a broken drive coupling. The turntable motor is very difficult to turn by its shaft. so if it turns easily it is probably a broke coupling. NEVER force your turntable around by hand or you can break that coupling.
May 12, 2014 | Panasonic NN-S963BF Microwave Oven
Replacement or fix
just replaced our 6 year old Thermador MBBS ($750) with a GE JES2051SNSS from Home Depot ($179). The bottom guide piece from the Thermador bolted right on the bottom of the GE and positioned the new unit so the front trim piece fit perfectly.
Jun 06, 2013 | Thermador MBBS Microwave Oven
Kenmore microwave 721 85032010 will turn on but won't heat or spin
Chances are that is just a defective top or bottom door switch or its mount.
See our help file on door switches here.
Also, that model number does not show up as a valid US Kenmore model.
Please check the tag in the cooking cavity or elsewhere n the oven and let us know if you need further help.
Jun 05, 2013 | Microwave Ovens
Door won't stay shut, microwave will not start
Contact the maker or Google the model number for "parts"
That part likely will require the unit to be taken apart to replace it.
Jun 16, 2012 | Jenn-Air Microwave Ovens
I pulled the door off my advantium today to clean it after I cleaned the vent grille. I set the door carefully on it's side so I thought but a small little plastic piece broke off where the door...
Glue won't work, the part must be replaced.
We have the service manual at our site and you can download it free here.
You can order parts from the Pros here, our favorite supplier.
Jul 07, 2011 | GE Advantium 120 Convection/Microwave Oven
Hi my sf 80hj washing machine leak below ( rotating shaft) sos thank
A rubber gasket (seal) must be replaced. This seal connects the bottom of the tub to the rotating shaft (Agitator shaft).
A variety of factors determine how long these rubber gaskets last befroe they start cracking.
The seal is available from most appliance parts stores (local and on-line). The trouble is replacing it, it take about 2 hours for an amature and some major disassembly. Removing the agitator, the inner tub (the one that spins after rinse cycle), and some shaft pieces.
Cost for a repair technician will be about $150 to 200 (guess only - I am not sure about the rates in your town).
Good luck.
May 23, 2011 | Microwave Ovens
Put a hamburger in to heat, on a paper plate. The interior began to spark. the plate on the Right hand side appears to have a something black and charred (as if a piece of meat or grease has adhered to it)...
Usually the sparks are from exposed metal. Clean the oven, and the table and anything else you can inside. Then just try nuking a cup of water. That gives it something to work with and it won;t make any sparks itself. Then just see if the sparks are gone. If the paint has come off inside the cavity and exposed some metal you can get sparks but that usually means replacing the microwave. If its caused by an object or buildup then a good cleaning stops it.
Oct 10, 2010 | Whirlpool MT1110SKQ 1100 Watts Microwave...
Kithchenaid Microwave
You'll notice there are small clips holding the stainless outer door to the black metal inner door. Get a bunch of putty knives (butter knives work too) and work a knife into about every other clip. I did it on the bottom. Once you're sure all the bottom clips are free, and you've removed the three screws on the side of the door, you'll be able to gently pull the stainless outer door away from the black inner door and get to the handle screws.
I bent both doors in this process, and tore the black plastic liner into a few pieces while I was getting everything out, so I had to buy a new door ($200). Be careful.
Sep 09, 2008 | KitchenAid KHMS155LSS 1000 Watts Microwave...
TURNTABLE
That piece is the pulley shaft: F21315Y00AP PULLEY SHAFT 3.29 You can get it from Panasonic's online part site: http://www.pasc.panasonic.com/epartr/ Generally you unplug the unit from the power line, then remove the bottom panel(s) above the stove top. The motor is usually held in by 2 screws. When the motor is loose, you can remove the old couler and insert the new one. With one hand on the new coupler and one on the motor, you have to wiggle them a bit so that they interlock. Then while holding the coupler & motor, insert the screws.
May 06, 2007 | Panasonic NN-T993SF Microwave Oven
Microwave Ovens Logo
13 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
