Question about HP Pavilion dv1000 Notebook
Hp laptop start screen zoomed in
I am on the start screen on a HP laptop with windows 8 and the screen is zoomed in so far that you can't navigate around.
    New Friend:
  • 63 Answers
Ctrl - should allow you to zoom out.
Posted on Nov 28, 2013
stabelabel
  • 51 Answers
SOURCE: WHEN I START MY HP LAPTOP AFTERTHE WINDOWS XP APPEAR IT JUST STOP
It's not booting to the OS I take it. THen you need to do a recovery it you have one. First try F8 key when you turn laptop on try safe mode see if that boots. If it does restart F8 again try last know see if that one work that would be your last start up backup if that works you should be ok. If not then go to setup do boot from CD install your Windows CD restart your laptop and try doing a windows repair if that does not work then you will have to do a complete reinstall.
Good luck
Posted on Mar 20, 2009
haayz
  • 197 Answers
SOURCE: screen was divided into 8
try to update video driver.
Posted on Jul 02, 2009
  • 41 Answers
SOURCE: on startup i have multiple screens and then the computer hangs
Reinstall latest release from Microsoft.. it should solve the problem
Posted on Jul 28, 2009
drifterK
  • 4924 Answers
SOURCE: I have an Hp Compaq nc8230 laptop. Everytime I try to turn it on, it starts up, gets as far as the windows loading screen, and then starts all over again. Is there any way to fix this?
This can be a fault of ram memory ...and and this case just open the ram compartment and remove them and place them back one by one (in case they are more than one ) ..and try to boot up ..and see which one cases the fault ..It may be just out of place and after replacing to work ..
It also can be a missing file in the operation system ..and to make it boot-able again you have to reinstall the system into computer using either the recovery tool available ..(disk or partition ) ..or using a boot-able disk with the operation system ..
you can also try ...(if you have a boot-able disk ) just to repair..and when the command will be asked ..just select the 1 for the hdd0 and the command fixboot ..This will rewrite the boot sector and will make it work ..o r..if you think you can not manage and be sure you eliminate the issues..just reinstall it clean and format the C drive during the procedure..
If it says anything about the hard disk when it stops from booting ..it maybe a case of bios settings ..and in thios case the actually fault is the lack of the raid or the ahci driver..and you will need to go into Bios settings by pressing F2 on start ..and in there select optimal factory setting s..and engage them (f7 probably ) and after that save settings with F10 and enter..
This should get it to the factory settings and make the hard disk functional by being read in the ide compatible mode..and there for not need the raid driver..
If this is not working you can get to the advanced settings in bios...select the hard disk 0 ..and under its options ...disable the ahci mode and select ide compatible or ..sata as ide..and save with F10 ...This also should solve the issue if the problem is the related with the hard disk recognition ..
In sort ...first check ram memory and hard disk physically ..than try to see if the bios settings of the bus is compatible (disable ahci function ) ..than as a last resort reinstall the operation system if it seam to be corrupted ..
Good luck ..!
Posted on Nov 30, 2011
SOURCE: how to unlock a hp windows 8 laptop
as the computer is starting up hit control f11 and do a system restore on it
Posted on Dec 12, 2012
How do I bypass forgotten screen lock code on hp 2000 laptop running windows 8 without a disc?
I forgot my password for my hp laptop.????????
h30434.www3.hp.com > Laptop & Notebook > Notebook OS
Step 2: Insert the Windows password bypass disk to your computer. Boot the computer from CD-ROM or USB. Step 3: After boot from your bypass disk, Windows Password Rescuer will start automatically. Then you can remove whichever user password.
how do i bypass the windows password without password ...
Dec 06, 2015 | HP Computers & Internet
How do I bypass HP password screen on my laptop
You need to do a system recovery. Which means loosing all your data.
HP have provided this page as it depends on when your laptop was manufactured.
Performing an HP system recovery Windows 8
Feb 06, 2015 | HP Computers & Internet
How do I make the print size larger on my HP. Computer it is a Desktop
Using the Browser, there is a zoom function on Internet Explorer up to 400%. It is under the view command.
Word processors such as word also have a zoom command.
Under windows 8, you can personalise the screen under the control panel and expand the text. There is also a magnifier function for parts of the screen.
Oct 09, 2014 | HP Computers & Internet
How to unlock a hp windows 8 laptop
When you are locked out of HP Windows 8 laptop, how to unlock HP laptop and login into Windows 8 successfully without password?
Follow this video and learn how to use Windows Password Genius Advanced to reset HP Windows 8 admin password.
This is an effective way after Windows 8 administrator password forgot and you don't have any available admin account to login into Windows 8 and no password reset disk has been created when HP laptop is accessible.
http://www.youtube.com/watch?v=7VAty_V8RFE&feature=youtu.be
Dec 11, 2012 | HP Computers & Internet
My laptop is zoomed out way to far and i cant even read the words or anything. how do i fix this?
Hi georginabale...
Try to adjust your screen resolution and see if that helps
Click Start>Control Panel>Appearance and Themes>Change the Screen Resolution.
When the window opens try using the slider in one direction and then the other to see if that solves your problem.
Note: give it a minute to get to the resolution after you have clicked on it.
Please take time to rate me
Sep 01, 2011 | HP Mini 1000 Netbook
My hp dv 1000 notebook will not boot up.
It could be that the hard drive drivers may be incorrect, if it started when you got the new hard drive its probably that. So update the driver or reinstall the drivers again,
or
try reinstalling Windows from scratch. (note- this may cause you to lose data).
Jan 18, 2009 | HP Pavilion dv1000 Notebook
I have a HP Pavillion dv6000 laptop, the start button doesn't start windows, but only QuickPlay begins and opens up. From that there's a windows icon for which I click on to start windows. But the screen...
Start windows in safe mode, if you have antivirus installes run it from safe mode, if it does into stand by in safe mode, you may have other issues but it sounds like a virus to me so far.
Dec 11, 2008 | HP Computers & Internet
HP laptop desktop screen seems to be zoomed in . all icons and wallpaper seem to appear quite large .
There is an opion under conrol panel, accessibility options to zoom or enlarge fonts etc. for visually impaired people.. But also I guess there might be a hot key you have hit by accident, that zooms the desk top. What model of HP? Also right mouse click the desktop, click properties & check the 'appearance' settings.. There is an option for large icons & fonts. Maybe the HP hotkeys hook into that Windows option. Rgds,
May 05, 2008 | Computers & Internet
HP Pavilion dv1000 Notebook Logo
78 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
