Question about Linksys Wireless-G WPS54GU2 Print Server
Usb light link
HP LaserJet 1022, USB light will not come on, Linksys Printer Port Setup utility shows Port 2 No Printer. LaserJet 4 Plus on parallel port , parallel light is on, Linksys Printer Port Setup utility shows Port 1 HP Laser Jet 4 Plus, printer works fine on network. WPS54GU2 Firmware 6032. Web access to the server works fine (192.168.0.***).
    Champion:
  • 411 Answers
HP LaserJet 1022 is a "host-based" printer so it must be connected to a PC. Load the driver on PC first and connect the USB cable when software tells you to do so.
Will not work on a Linksys print server.
LaserJet 1022N & LaserJet 1022NW have "special" HP print servers that can support HP host based printers.
Posted on Dec 29, 2013
What kind of cable or usb do i need to connect my hp laserjet 3015 to my pc?
Hi,your printer use 2 different USB and parallel interfaces..I recommend to use USB cable..
Pls visit the below links for these cables..
Just in case ,I have provided an URL for user manual as well.
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
USB Printer Cable for HP LaserJet P3015dnhttp://www.amazon.com/gp/product/B004PRSNRQ/ref=pd_lpo_k2_dp_sr_1?pf_rd_p=1278548962&pf_rd_s=lpo-top-stripe-1&pf_rd_t=201&pf_rd_i=B0001M3QZS&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=04ARKGAPMW24ZWCCBNHN
Parallel to USB Adapter opens new browser window - Connect USB Printer to PC Parallel Port with LPT2USB Adapter ********************
HP LaserJet 3015 user guide - ENWW
www.lavc.edu/it/manuals/printer_hp_laserjet_3015_user_guide.pdf
Use these topics to acquaint yourself with your new HP LaserJet 3015 all-in-one
Jul 01, 2011 | HP LaserJet 3015 All-In-One Printer
I bought a new HP computer and it didnt have a serial port included in it. I purchased a secondary PCI Express card that gave me two serial ports. They are programmed in as com port 1 &2. They show...
Serial connection eh? Any reason you went with serial instead of parallel? The cards likely sell for about the same price or you could just buy a USB to parallel cable that would allow you to hook up a USB port of your computer to the parallel port on the printer.
The reason that it looks like the job disappears is likely due to the fact that the serial bus is not supporting bidirectional printing so the printer cannot acknowledge that it has received the job.
Apr 19, 2011 | HP LaserJet 5 Printer
LaserJet IIIp will not print using USB to parallel cable via Vista
DOT4 USB Printing support must be installed and the printer setup on a USB port in the printer manager for this to work. The laserjet 3p driver provided by Microsoft does not natively support DOT4 USB printing, as USB was not even invented when that printer came out. You might be able to enable this support by using the HP Universal print Driver instead of the built in driver provided. You can get the universal driver here:
Jun 19, 2009 | HP LaserJet IIp plus Printer
Can i connect hp laserjet 4p via usb ??
I have a similar situation. Trying to print from a HP LaserJet 4 using a parallel cable to USB. It will not recognize the printer. What is the installation setup or what is the trick to get it to print?
Jan 13, 2009 | HP LaserJet 4 plus Printer
HP Laser Jet 4 Plus to iBook G4 serial to usb
serial to usb is not plug and play so i don't believe this configuration will ever work.
parrallel to usb is plug and play 90% of the time.
purchasing and installing a port replicator is a 100% fix as long as the formatter on the printer is working properly. good luck!
Aug 21, 2008 | HP LaserJet 4 plus Printer
HP LaserJet II p Plus will not print
I am assuming that you are using Vista. Based on your post/description:
1. the HP Compaq 6710b has no parallel port;
2. the HP LaserJet IIP Plus is only capable of either serial or parallel connection;
3. hence you're attempting a USB to Parallel interface;
4. the printer is installed in your notebook and is set to USB port;
5. from the printer a test print can be performed but not from the Printer Properties in your notebook;
6. all printing jobs initiated from the notebook results in an "Error".
With the above in mind, may I point/suggest that:
a. Windows Vista driver will only enable your HP LaserJet IIP Plus' basic functions to work. It is not 100% compatible;
b. alternately, you can try using the XP installation CD/drivers of the printer;
c. the compatibility issue may be compounded by the USB to parallel interface;
d. the USB to parallel interface may be hampered by a known Vista USB issue;
e. you can try patching/updating the Vista USB driver. Since this has been a recognized issue with Vista, Microsoft has posted a fix for this here or here.
f. verify that the printer does not display a 22 or 40 Error.
If the printing concern has not been rectified after completion of the above procedures, you may need to:
i. download and install HP Universal PostScript Print Driver; or
ii. consider using a wireless print server connected to the parallel port of the printer; or
iii.consider replacing your printer. Sorry.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 12, 2008 | HP LaserJet IIp plus Printer
HP Laser Jet 1320n series
The HP LaserJet 1320 has a USB port and a Parallel port.
The HP LaserJet 1320n has a USB port and an Ethernet port.
USB-to-Parallel converter cables, like this one, are designed to attach a parallel device to a computer's USB port.
But you need to do the opposite (attach a USB device to a computer's parallel port). A USB-to-Parallel converter cable will not do this.
Feb 29, 2008 | HP LaserJet 1320n Printer
HP1100
I am currently using this print server with the HP Laserjet 1100 on the parallel port and it works flawlessly.
Jan 15, 2008 | D-Link DP-G321 Print Server
Linksys Wireless-G WPS54GU2 Print Server Logo
136 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
