Question about Frigidaire FRS26H5AS Side by Side Refrigerator
Stops cooling unplug works again - Frigidaire FRS26H5AS Side by Side Refrigerator
  • 2,113 Answers
You have a defrost issue. Either replace the timer or fix the heating element or thermal cutoff next to it
Posted on Nov 28, 2013
Intermittently starts beeping 3 times and some time later (hours to days) stops cooling. Works again, for a week or so, after unplugging for 10 minutes or so
Hi, your suggestion is good. Also consider an overbuild up of frost which the autodefrost can't cope with. I don't know what to suggest you do about it apart from minimising the moisture content of the food that you put into it.
Just seen your post regarding replacing the control unit yourself. I think that it's feasible if you have a reasonable amount of experience. However, the final decision is yours, I cannot suggest that this is something that you should do.
Jun 29, 2015 | Frigidaire Pro PHS69EJSS Stainless Steel...
LFC20745SW- Refrign not working, the freezer working
the refrigerator is not defrosting automatically the vent is geting ice up blocking the air flow when you unplug it the refrigerator defrost and start working like normal they may be a problem with the motherboard
Sep 11, 2013 | Refrigerators
Whirlpool stopped blowing cool air. Unplugged
It sounds as if your defrost timer has failed. Unplugging the unit over night allowed the unit to defrost. If unplugging it overnight or by using a stnd fan blowing into the freezer section for 90 minutes results in the fan blowing cold air then your unit is not defrosting. Most often the defrost timer is the problem. However there could be other defrost circuit like the thermostat or the defrost element. In order to provide you with the correct solution and defrost timer location you should privde your model number for further instructions.
Jan 02, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
My Magic Chef refrigerator has stopped cooling. When I unplug it for a few days, and then plug it in, it will work for about a week, and then quit cooling again. The freezer is perfect, and continues to...
The most likely cause is that the defrost system is not working. After about a week it builds up with enough frost to stop the cold air from getting to the refrigerator section. The most common problem is the defrost timer, defrost heater or defrost thermostat.
Aug 26, 2009 | Magic Chef CTB1502AR Top Freezer...
Freezer and refrigerator doesn't cool properly
Sounds like a main control board bad . A model number would help .
Jul 18, 2009 | GE Profile Arctica Stainless Steel Top...
Freezer works frige dont unplug for an hour then it works .
I would suggest check the coils to make sure they are clean . Also check the fan which cools the compressor to make sure it is working . When you unplug , it gives the compressor time to cool down a bit , but after it restarts , it will get hot again and stop cooling .
Jul 06, 2009 | Refrigerators
GE- GTS22WC refrigerator. Both the refrigerator and the freezer stopped cooling, We put it in the basement thinking it was no good, and after a few months we plugged it back in and it worked ok for about...
The auto defrost heat element is not working. When the ice buildup clogs the airflow the unit stops cooling. Once you unplug it and give it a chance to melt it works again. You need to have the defrost unit replaced.
Jun 27, 2009 | GE GTS22KBP Top Freezer Refrigerator
Found that the rfridge stopped working, unplugged it and now running again,but not getting cold. can hear blower ?
Unplug again and wait for 3-4 hours for compressor to cool, then reconnect power. If no luck, then the compressor is probably shot. Replace refrig.
Jun 13, 2009 | GE Profile PDS22MBS Bottom Freezer...
Kenmore fridge stopped cooling
sounds like its freezing up on you. check the drain outlet and make sure that its clear. also i would replace the defrost timer on this unit because its suppose to bring on the heaterfs to melyt the ice so thaat yoiu don't have to. they are around 30 mdollars at the appliancew repair store and all you need is the model number and serial number for the uit. after you get it it's either on the very top of the refrigerator section or in the very back. It has 4 wires going to it. good luck.
Jan 12, 2009 | Kenmore 53642 / 53644 Side by Side...
Frigidaire FRS26H5AS Side by Side Refrigerator Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
