Question about Janome Sewing Machines
Threads not sewing
Machine works but threads are not sewing together. Needle goes in and out of fabric but the threads remain separate.
  • Janome Master
  • 7,365 Answers
Try a new needle
rethread the machine top and bobbin
make sure the bobbin is inserted into the bobbin case correctly
also could be a timing problem
Posted on Dec 03, 2013
fixitruss
  • 6 Answers
SOURCE: Machine not sewing
 If you have the machine threaded correctly, and are absolutely sure. New needles installed and it still does not sew, you most definitely have a timing problem. You should take to a qualified service center to be properly timed.
Posted on Oct 10, 2007
bargainbox
  • 1388 Answers
Make sure you have threaded the machine from right to left, it sounds like the needle thread is trapped under the lower looper thread and cannot form a stitch.........start the threading over from scratch like this:
  1. Lower Looper
  2. Upper Looper
  3. Left Needle
  4. Right Needle
Is there a diagram for how to thread on the inside of the door ?
Follow that slowly and carefully to make sure you have not missed any thread guides on the way, as each one needs to be followed through to ensure correct tension and thread progression.
If you are certain that all threaded correctly, did you have a fabric jam and pulled it loose ? If so, the timing may well be affected.
Post an update and we'll get this right.
Bargain Box
Posted on Feb 03, 2008
SOURCE: Not picking up the Bobbin thread
I cleaned the machine good with canned air, oiled it. I took out the bobbin case and cleaned it good also. I then noticed the tension screw on the bobbin case was loose, tightened it and the problem was fixed.
Posted on Nov 17, 2008
Mongo32
  • 111 Answers
SOURCE: my machine is not stitching
needle in backwards?
Posted on Jun 13, 2009
  • 96 Answers
SOURCE: stitching loose. won't thread the fabric
try to rethread the machine all the way back to the spool of thread and check the top and bottom tensions on scrap of same fabric
Posted on Dec 13, 2009
How to change sewing for different thicknesses
First, you will need to select a brand new needle of the type suitable for your fabric. Select a proper thread weight and type for your needle and fabric.
Select the proper presser foot for your project/fabric. On some fabrics, you may even want to use a straight stitch needle plate to prevent the fabric from going down the needle hole.
You will want to adjust the upper tension so that the upper and bobbin threads meet in the middle of the fabric.
Also, probably want to adjust the presser foot pressure so that the presser foot presses harder or lighter (depending on the fabric) so the fabric will feed through evenly, ie both the top and bottom fabrics move together at the same rate. Hint: if it is really thick, like sewing a quilt with batting, a walking foot may be helpful.
Be sure to test on scrap fabric from your project before beginning sewing your project together.
All About Needles
Why is there an extra needle plate supplied with my machine Brother straight stitch plate and presser foot cannot be used with zig-zag or decorative stitch or you will surely break your needle and possible knock the machine out of time!
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwib0Z_YrrbJAhUBUGMKHc6OBhAQFggeMAA&url=http%3A%2F%2Fwww.ca.uky.edu%2FHES%2Ffcs%2FFACTSHTS%2FCT-MMB-213.pdf&usg=AFQjCNE4QlGk1Fvt8K2UGCRCfzMpGS-A2Q&cad=rja adjusting tension
Adjusting Sewing Machine Tension to Prevent Problems
http://makeitsew.biz/presser-foot-pressure
Adjusting the presser foot pressure on your sewing machine
Nov 29, 2015 | Sewing Machines
I have my machine threaded and it runs with no beeps however it is not sewing the material together
I'm wondering if you have the flat side of the needle in correctly. If your bobbin assembly is in the front of the machine, the flat side should be towards the back. Also, check to make sure your needle is ALL the way up in the needle clamp.
Sep 02, 2014 | Singer Advance 7422 Electronic Sewing...
Hand held sewing machine
I think you are saying no stitch is formed also referred to as the needle not catching thread. Below offers a variety of diagnoses and solutions which are straight forward.
Sewing Machine Needle Not Catching Thread
Below is general advice quoted from 6 common sewing machine problems solved:
Skipped stitches are usually due to a bad needle. The needle may have become damaged or bent by sewing material too thick for the needle, forcing material through the feed dog, or hitting a straight pin. If the problem seems to be consistently reoccurring, it may be due to forcing the fabric. Sewers should allow the feed dog to pull the fabric and only use their hands to guide the fabric through the feed. When sewing knitted fabrics, using a stretch needle can help prevent skipped stitches.
Below is a video showing how thread is hooked into a fabric:
Sewing Machine Anatomy How Stitch is Made
Jan 18, 2018 | Sewing Machines
Top thread tangled in bobbin.
try changing the needle---flat side goes to the back side of the machine
also check the top tension
depending on the fabric your sewing on--the needle & thread have to work
with the fabric--example light fabric needs a different needle & thread than
a heavy fabric
check to see if the thread is coming off the thread take up lever when you
sew.
Apr 04, 2012 | Singer 8280 Mechanical Sewing Machine
GC 500/550 not pulling bobbin thread. My wife has used the machine several times without issue, the last time she broke a needle sewing some denim, we found most of the needle but could not find it all,...
some sewing machines can not sew denim good,
here are some suggestions
since a needle was broken & replaced--if the needle has a flat side it goes to the back of the machine
make sure the needle is inserted correctly & pushed up inside of the needle holder & the needle screw tightened correctly
is the correct needle being used for the thread & fabric being sewed?
when sewing denim, a denim needle is needed, I usually purchase mine at walmart, I have 2 necchi sewing machines & the denim needles work just fine on my machines.
if none of the above suggestions help then the machine could be out of time, just because of a broken needle. only a repair shop has the correct tool to fix this problem
Sep 09, 2011 | Singer CG754 Mechanical Sewing Machine
My kenmore sewing machine model 385.18221 is not really sewing. It seems like it is for a couple of stitches then the fabric goes down into the machine, threads r hung up in the bottom and when u get the...
Here are several solutions to try.
- Re-thread your machine. It may be threaded incorrectly (backwards).
- Raise your feed dogs if your machine has this feature.
- When you start to sew a seam, hold the upper and bobbin thread tails. Hold them back and out of the way as you sew your first couple of stitches. This will keep them from getting caught in your machine.
- Reinsert your needle and make sure it goes all the way into the holder and that it’s positioned correctly – usually with the flat side away from the bobbin, but consult your machine’s manual to be sure.
- Change your needle, it may be blunt, bent, or otherwise damaged.
- Your fabric may require a different needle. Generally, heavier fabrics require larger needles and thinner fabrics, smaller needles. You may also need a larger needle if you’re sewing through many layers of fabric. And make sure to use a ballpoint needle for knit fabrics and a sharp needle for woven (or a universal needle for either). Make sure your needle is appropriate for the type of thread you’re using.
- Adjust the pressure of your pressure foot. It may be too light for your fabric.
- Change your thread. If your upper thread and bobbin threads are different types, try using the same thread for both. And use a good quality, brand name thread.
- Adjust your thread tension, It may be too tight or too loose.
- Change your needle plate. Try switching to a needle plate with a smaller hole (a straight stitch needle plate).
Important Note: After changing your needle plate, check to make sure your needle aligns perfectly with the smaller hole before starting to sew. A misaligned needle could hit the plate and break, which could be dangerous. And make sure to change your needle plate back for zigzag and other wide stitches.
I hope these solutions help you.
Sep 24, 2009 | Kenmore Drop-In Bobbin 16231 Mechanical...
My ls2125i won't stitch
Although I am not a expert at sewing machines, I have worked a lot with an industrial sewing machine. You might check the tension of the thread that goes through the needle. If it is to tight it will pull it through the needle. There should be somewhere on your machine that you can adjust the tension.
Jul 28, 2009 | Brother LS-2125 Mechanical Sewing Machine
Machine not sewing
  1. Lower Looper
  2. Upper Looper
  3. Left Needle
  4. Right Needle
Bargain Box
Feb 01, 2008 | Sewing Machines
Sewing Machines Logo
44 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
