Question about Electrical Supplies
3 way light switch diagram - Electrical Supplies
  • 2,113 Answers
Http://www.howtowireahouse.com/How_To_Wire_A_3-way_Light_Switch_Or_Dimmer.html
Posted on Nov 27, 2013
MY BRAKE LIGHTS WORK BUT MY TAIL LIGHTS OR DASH LIGHTS WONT. I CHECKED AND REPLACED FUSES
How do you turn those lights on for your vehicle ? Headlamp switch ? I would say what ever controls (turns on) would be the culprit ! Test first ,find a wiring diagram an check B+ voltage to the switch . The wiring diagram will show which color wire it is , then with light switch in the running lamps position only , not headlamps . The diagram will show which wire should have B+ voltage . If there is any the switch is bad . There are videos on youtube for basic automotive electrical testing ! If your not sure take it to a qualified repair shop !
Jul 25, 2016 | 2003 Kia Spectra
Need wiring diagram
Wiring diagram for a 3-way switch, one of the many wiring diagrams showing different methods of wiring a three way switch circuit. This electrical wiring diagram shows power into light switch Box #1 – wire to light from switch box #1, and from switch box #1 to three-way light switch box #2.
Jan 06, 2016 | Holmes Products Heating & Cooling
Wiring diagram for a 1994 olds cutlass supreme instrument lights
Power comes from headlamp / dimmer switch . Go here for free wiring diagrams http://bbbind.com/free_tsb.html Enter vehicle info year ,make , model ,engine size ! Under system click on lighting then under subsystem click interior light dimming .
Oct 04, 2014 | 1994 Oldsmobile Cutlass Supreme
Wiring diagram for 3 way 2 socket lamp
Where is the switch located? If you buy a replacement switch at Home Depot it usually comes with a diagram that shows you how to wire it. If the switch is built into the light socket just replace the socket the switch is included.
Jul 29, 2014 | Leviton Electrical Supplies
Three way electrical switch diagram
Copy following link for 3-way switch wiring diagrams:
http://waterheatertimer.org/How-to-wire-switches.html
Dec 06, 2011 | Electrical Supplies
Wiring diagram for cooper 7020040024
Switch is not identified.
Copy following link to see switch wiring diagrams:
Nov 28, 2011 | Electrical Supplies
Where located fuel sensor Suzuki Ario 2003
Component location diagrams for most 2003 Suzuki Aerio cars and light trucks sold in the U.S. from 1990+.
clsk2003aeri003.gifIgnition System Components Location Diagram for 2003 Suzuki Aerio 2.0 L4 GAS
Components on diagram:
  • TP Sensor
  • Ignition Coil
  • ECM
  • MAF Sensor
  • CMP Sensor
  • clsk2003aeri007.gifElectronic Shift Control System Components Location Diagram for 2003 Suzuki Aerio 2.0 L4 GAS
  • Data Link Connector
  • Transmission Range Sensor
  • Throttle Position Sensor
  • Pressure Control Solenoid Valve
  • Battery
  • clsk2003aeri010.gifInstrument Panel For Connector Layout Diagram Diagram for 2003 Suzuki Aerio SX 2.0 L4 GAS
  • Clutch Switch
  • Thermistor
  • Brake Light Switch
  • Blower Motor Relay
  • Heater Fan Motor
  • clsk2003aeri011.gifInstrument Panel Harness Diagram for 2003 Suzuki Aerio SX 2.0 L4 GAS
  • Wiper Switch
  • Washer Switch
  • Turn Signal Relay
  • Radio
  • clsk2003aeri015.gifHeadlight System Location Diagram for 2003 Suzuki Aerio SX 2.0 L4 GAS
  • Headlight Relay
  • Headlight
  • Clearance Light
  • Headlight Diode
  • Clearance Light Relay
  • clsk2003aeri022.gifFuel System Components Diagram for 2003 Suzuki Aerio SX 2.0 L4 GAS
  • Fuel Pump Relay
  • Fuel Tank Pressure Sensor
  • EVAP Canister
  • Fuel Tank Pressure Control Valve
  • Fuel Filler Cap
  • clsk2003aeri027.gifFloor For Single Unit Parts Diagram for 2003 Suzuki Aerio 2.0 L4 GAS
  • Wheel Speed Sensor
  • ABS Control Module
  • G Sensor
  • Air Bag Control Module
  • EVAP Canister Vent Valve
  • clsk2003aeri030.gifInstrument Panel For Ground Point Diagram for 2003 Suzuki Aerio SX 2.0 L4 GAS
  • Instrument Panel Ground Points
  • clsk2003aeri036.gifEngine Compartment For Single Unit Parts Diagram for 2003 Suzuki Aerio 2.0 L4 GAS
  • Horn Relay
  • Radiator Fan Control Relay
  • Cruise Control Module
  • Condenser Fan Relay
  • clsk2003aeri037.gifEngine Compartment Components Diagram for 2003 Suzuki Aerio SX 2.0 L4 GAS
  • MAP Sensor
  • Knock Sensor
  • Noise Suppressor
  • Heated Oxygen Sensor
  • Sep 18, 2011 | 2003 Suzuki Aerio
    No parking lights.. Head lights and brake lights work. No power getting to parking light bulbs. All fuses in panel test good. Need good wiring diagram to chase wires. Any suggestions on problem or where...
    You can try an internet search for the wiring diagram. No power to all the parking lights? Then probably the light switch. Make sure you have power to both sides of the fuse. If not the either wiring from the switch or the switch itself. Good luck.
    Aug 16, 2010 | 1982 Chevrolet El Camino
    Electrical Supplies Logo
    Top Electrical Supplies Experts
    Steve
    Gene Haynes
    Are you an Electrical Supply Expert? Answer questions, earn points and help others
