Question about Dell Dimension E520 PC Desktop
Can't receive faxes
Tapi connection failed modem box
    Novelist:
  • 152 Answers
Check to be sure your modem drivers are installed properly, or they are the correct version for your modem. You may need to re-install the drivers.
If the device still does not function correctly, you may need to purchase a new modem, they usually aren't very expensive.
Posted on Jun 01, 2009
I have my machine hooked up with my answering machine. How do I set up to have the answering machine pick up and then once the beeping of a fax starts, it will connect.
Unfortunately you can't do that with any stand-alone answering machines. You'd need to manually activate the Fax when you hear the fax tones. What you can do is use an item like this: http://faxswitch.com/stick.html or this: http://www.usr.com/en/products/telephony-usr4000/ to route the calls to the Fax or the answering machine for you. The other option is to use a TAPI Voice/Fax Modem with your computer that supports telephony operations. Then you can use the computer to answer the fax calls and telephony software to add an answering machine to the computer. (This is one example: http://www.ventafax.com/ .)
I wish that I had better news for you.
(Note: I have a USB Voice/Fax Modem that claimed it would handle telephony operation after a firmware upgrade to the unit. It never learned how to correctly interpret the necessary codes. This may be a driver issue but I never resolved the problem. So my fax modem is still on Manual answer.)
May 12, 2015 | Canon PIXMA MX922 Wireless All-in-One...
Couldn't send fax. no tapi device found
I presume you are trying to send a fax from your pc?
Most modern pc's do not have an internal modem. Check to see if you have one and if so that it configured for the correct type of dialling ie tone or pulse.
May 30, 2011 | Office Equipment & Supplies
My lexmark S405 willnot receive faxes. It is
Assuming "cable modem" as some kind of DSL modem using your phone line for internet. Both your modem and MFU should be connected to the wall by a filter-separator, usually supplied with your DSL modem. Check its presens and proper connection. Remove any other joints or splitters
Jun 14, 2010 | Lexmark X2470 All-In-One InkJet Printer
Using a Lexmark 3400 series to fax
Yes your printer will send and receive faxes. 1. Make sure: • The printer is connected to a computer that is equipped with a fax modem. • The computer is connected to a working phone line. • Both the printer and the computer are turned on. 2 Load an original document facedown on the scanner glass.
Here is the manual, in case you don't have one http://www.retrevo.com/d/ds/progress?doc=7d2128cd89431b0e3d4c2a1c31fa8fc4
3 From the desktop, double-click the Imaging Studio icon. 4 Click Fax. 5 Click Scan and send a fax. 6 Click Preview Now. 7 Click and drag the dotted line box to select a specific area of the preview image to fax. 8 Adjust the settings as needed. 9 Click Next. 10 Follow the instructions on the computer screen to complete the task. Receiving a fax using the software 1 Make sure: • The printer is connected to a computer that is equipped with a fax modem. • The computer is connected to a working phone line. • Both the printer and the computer are turned on. 2 From the desktop, double-click the Imaging Studio icon. 3 Click Fax.
Dec 05, 2009 | Cars & Trucks
Not receiving faxes
for that U have to install software which comes with modem. der r few modems with this soft/w. it halts internet connection & recieves fax. and lateron resumes internet connection
Aug 08, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Any received fax fails
Problems receiving could be any number of problems. The first item I would check it to make sure no other devices are on the same line as the fax modem, such as a fax machine. This can cause a problem for a fax modem to receive faxes when another line is being picked up and listened to at the same time.
http://www.getfaxing.com/forums
Jan 17, 2009 | Symantec WinFax Pro for PC
One line two Devices
WinFax will support two modems, but I believe only one ISDN device. So, you can't use both ISDN and analog fax modem at the same time.
Nov 24, 2008 | Symantec WinFax Pro 10.0 for PC
Brother Intellifax 770 fax machine failure to receive faxes
I HAVE A BROTJERS 770 AMD ALL I DONE WAS GET A 2 SPACE TELE JACK AND PLUG IT INTO MY MODEM FROM COMCAST AND PLUG MY PHONE AND FAX INTO IT AND CAN RECEIVE AND SEND
Mar 24, 2008 | Brother IntelliFAX 770 Plain Paper Thermal...
Cannot send or recieve faxes
You cannot send a fax on a broadband connection, they should have given you a splitter, if not get one, the splitter is a small box like thing, it has two telephone sockets on one side and one socket on the other, the telephone line from the wall is connected on one side, on the other side you have to connect your adsl modem in one and your telephone in another socket, Usually the sockets have descriptions on them specifing which decive should be connected to the socket.
Now you should have a dial up modem(56Kbps internal or external modem) connect this modem to the socket which specifies, Telephone. Configure the modem. configure yor fax settings to use this modem. Now you can send your faxes.
If your ISP does not support dial-up then you cannot use it to send faxes.
Post back with your results.
Jan 04, 2008 | Computers & Internet
Remote device issued disconnect signal on last attempt.
What does the failed message say? Maybe its at the other "end" and not you. If it is nothing you can do except to advise them.
Sep 25, 2007 | Symantec WinFax Pro for PC
Dell Dimension E520 PC Desktop Logo
53 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
