Question about Broan-NuTone Nutone IMA4406 Intercom Master Station White
The intercom system will not work, it has a light on it, but it will not respond to any buttoms pushed
I just bought a Wireless Intercom System. I hooked
frequency problem. check your partners/pair intercom system.
Oct 12, 2013 | Computers & Internet
Intercom uniden D1688
After reading the manual over and over with no success, I got the hint to successfully do an intercom call by reading a post from a website.. The manual says to press the Intercom buttom. Then select the phone you wish to intercom with (or All phones) - do this by using the up-down button. The step left out of the manual is: THEN press the MENU key. It works perfectly!!
Jan 07, 2012 | Uniden Cordless Phone
My toshiba laptop is not responding only orange light flashes
Hello try pushing the power buttom again as most laptops go into a sleep mode when lefton and no one has touch them for a few minutes . If that doesn't work, maybe it's defective and such be brough back to the supplier for replacement or refund ( don't forget the receipt )
Mar 07, 2010 | Toshiba SatteliteĀ® Pro A200 PC Desktop
Lights and intercom
Feature 00
press the button that is supposed to be him
press the left intercom and *XX (XX is the extension number of the user)
feature 00 when done
Pressing the button will now page the phone, and you will see the status of the user.
Aug 12, 2009 | Avaya Partner 34D Corded Phone
My girlfriend took the batteries out of the Phillips universal remote. When she replaced them with new ones, the remote would not respond to the Toshiba TheaterView big screen television it was programmed...
first push code buttom then press tv then start pushing power buttom until tv go off (do not push power again after tv go off if this happen need to do everything again)then press enter and try again
Jul 27, 2008 | Televison & Video
RED INDICATOR LIGHTS FLASING ON INTERCOM
Thats a common "problem", but its easy to fix. The Intercom lights flashing like that is normal and they will continue to do so until you "assign" the phone its intercom number.  If you have more than one of these phones, go to your other phones, lift the handset and see what intercom number lights on that phone when you do so(the lights/buttons that are flashing). Notate which intercom number that is and move to the next phone. Once you have notated the other intercom numbers go back to the phone you wish to program and push PROGRAM , then push the touch tone key of which intercom number you wish to assign the phone (ie. 1 2 3, etc.), then push MEMORY.  That should do it, and if you need replacements their on Amazon. Good Luck
May 22, 2008 | Dual Handset Cordless Telephone with...
Adding an extension
If you program that button to ba a DSS button for that station (41) it will intercom that station, can be used to transfer calls to that station, and will light up when it's busy. It could be called something else in programming like Station Intercom Button, Quick Transfer Key, etc..
Problem is, your phone can be used on many different Avaya phone systems that all program differently.
The manuals for the phones and systems are all available free at www.avaya.com but you need to know which system you have before looking for the manual.
Feb 13, 2008 | Lucent PARTNER18 Corded Phone
Display frozen
I think if you push the heated wash and heated dry buttom several times until all the buttoms light up this may fix your problem.
You may have different kind of light flashing indicator, but the same solution.
Possibly check the sequence switch
Feb 09, 2008 | Dishwashers
Open Questions:
See all Broan-NuTone Nutone IMA4406 Intercom Master Questions
Broan-NuTone Nutone IMA4406 Intercom Master Station White Logo
32 people viewed this question
Top Broan-NuTone Home Security Experts
Lawrence Oravetz
Are you a Broan-NuTone Home Security Expert? Answer questions, earn points and help others
