Question about IBM ThinkPad T23 2647 Notebook
Laptop screen goes black, no backlite
IBM Thinkpad T23 Laptop. About 4-5 years old. Screen no longer functions - flickers and goes to black. All else working fine.
  • IBM Master
  • 32,281 Answers
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on May 08, 2009
Windows won't start
re-install the operating system or restore from a set of back up discs you previously made from the laptop.
Dec 23, 2012 | IBM Lenovo ThinkPad T60
IBM R40 laptop will not start.
remove the battery and adapter. press power button for 30 sec. then connect the adapter. press power button. if this didnt work. you need to ask for an help of a local tech to check for the video card and cable.
Mar 22, 2010 | IBM ThinkPad R40 2722 Notebook
How to replace monitor screen on ibn thinkpad t60
I have the same problem with my IBM T60. Screen is very dark, and I have to move it up and down to try to get it to flicker on. Right now, I have another monitor plugged in.
The laptop is about 4 years old and has been used daily.
Aug 26, 2009 | IBM ThinkPad T60 Notebook
My R51 thinkpad screen keeps flickering and is quite garbled it blanks out alot and stays black until you hit FN + F7 (the key to switch from laptop screen to desktop screen) in wich case the screen would...
Sounds like the lcd is toast.
Hook the laptop up to an external monitor and see if you get normal video. If you do, chances are it's the lcd. You'll have to replace it.
Jun 19, 2009 | IBM ThinkPad R51 Notebook
A blank screen on ibm thinkpad R51
your wires connecting from your laptop hardware to your display is messed up and is only "re-connected" and "hot-wired" by your action of closing/opening the lid.... use your warranty... your problem is when your warranty is expired so be glad this happened when you still have warranty
May 29, 2009 | IBM ThinkPad R51 Notebook
Problem with ibm thinkpad r40
The IBM beep code error 1 long 2 short beeps means there is a video card fault. Reseat your RAM because the video card uses some of the RAM. If it doesn't work then the video chip on the motherboard is faulty, the only way to fix is to replace the motherboard - this may not be a cost effective solution.
Connecting an external monitor to the laptop won't work because the video card also sends data to the video port.
Apr 06, 2009 | IBM ThinkPad R40 2722 Notebook
The display screen has turned black
When you connected the external monitor thto the laptop did it display?
If so then you have to reset the monitor port. Hold down the function key and find the FKEY that shows a picture of a monitor. Press that until you get the laptop screen back.
Typical use is:
  • 1 press = external monitor
  • 2 presses = laptop and dual monitor
  • 3 presses = just the laptop screen
Dec 12, 2008 | IBM ThinkPad R40 2722 Notebook
When i turn on my laptop, the screen is blank
It seems to be u have problem with ur RAM ..Try to change it
Nov 29, 2008 | IBM ThinkPad R40 2722 Notebook
Laptop screen
Sounds like the switch that tells the cpu when it's open or closed is going bad. On most laptops there is a little switch that protrudes from your keyboard (usually in upper corners). Try cleaning it with isopropyl alchol(rubbing alchol) and a q-tip and see what happens. If you can't locate the switch on your model get back to me and i'll research a little deeper for you. Hope this helps
Sep 14, 2007 | IBM ThinkPad 770 Notebook
IBM ThinkPad T23 2647 Notebook Logo
1,102 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
