Question about Bosch WFLI 2440 Front Load Washer
Timer messes up goes thru cycle and starts over
Ge washer model # wbvh5100hww
Ge washer wont shut off during spin have to shut off manually cycles thru all others wjre5550k2ww
Sounds like a timer/control issue issue..( you particular model has a control board instead of timer)..It would be best to call a professional to do proper diag and the repair but if want to risk it and attempt it yourself the part number is WH12X10439...
Good luck
Jul 05, 2017 | GE Washing Machines
Wbvh5100hww washer - no error codes. Starts to fill, then goes straight to drain and skips other cycles. Test mode t08/t09 for hot and cold water valves fails.
There is a strainer in the hoses that are most likely clogged; clean it out and your problem should be repaired. If you still have the errors and you have good pressure coming to the washer, then you will need to replace the water valve on the washer. Here is that part to order. Keep me posted.
Sep 26, 2013 | General Electric WBVH5100HWW Front Load...
GE WBVH5100HWW front load washer stops at 1
It appears that you have an electronic control board (directly behind the touchpad) issue. Contact an appliance service company.
Apr 13, 2010 | GE Washing Machines
Washer does not move to next cycle; does not turn off automatically
MY GE WASHER CONTINUALLY WASHES AND DOES NOT DO ANY OTHER CYCLE OF THE WASH IS THE PROBLEM MY TIMER IS MESSED UP??
Sep 25, 2009 | General Electric Clothes Washer Timer -...
Washer won't wash
Hi!
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 30, 2009 | GE Washing Machines
Washing machine does go thru spin cycle or drain water.
If the washer does not spin, take off the rubber bumbers inculding the little washers attached, inside the lid. It lowers the lid, which takes care of the problem. I had the same problem. Not anymore! Trust me, if nothing is wrong with any other part of the washer, this will work.
Apr 25, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
We purchased a GE front load washer in December 2007. Recently the boot had to be repaired. Now the machine is pausing when it gets to the rinse and spin or drain cycles. The pause light starts to flash. ...
ok Problem is not finding out the meaning of the pause button flashing but.......
you need to contact GE directly as this machine is under warranty.
Follow this link. GE APPLIANCE
If they do not help I will just contact me
Jun 05, 2008 | GE Washing Machines
Bosch WFLI 2440 Front Load Washer Logo
12 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
