Question about Nvidia Asus M2n5-bn/t3-ah1/dp_mb C51pv Athlon-64 Socket-am2 Motherboard
SeNvidia Asus M2n5-bn/t3-ah1/dp_mb C51pv Atarch
L46wd22 blue light blinks once
.bn/,.mb,.mb.,mb.,bnm,.bn.,n
Mar 25, 2012 | RCA L46WD22 Television
I need the drivers of graphics asus Barebone pundit P1
Hi
There are 4 different P1 models (AH1,AH2,PE2X,PH1?)
If you go to
http://support.asus.com/download/options.aspx?SLanguage=en&type=1
on the left you'll see "Desktop" then under that "Barebones" then scroll down in the middle to "Pundit" and you'll see the models on the right - select which ever is yours and it will take you to all the drivers and support.
Jul 27, 2011 | Computers & Internet
I have an old desktop pc, ASUS P4S533MX, Intel socket 478, with SiS PCI IDE Controller.. ( IDE ATA/ATAPI ) 1. Can I upgrade the Radeon 9250, 128 Mb DDR 64-bit to something better? 2. Is it...
well...ASUS P4S533MX- Intel socket 478 allow maximum processor upgrade from 3.2 GHz upto to 4.2 GHz.
for upgrade the Radeon 9250, 128 Mb DDR 64-bit ....whole moherboard along with new processor has to be replaced. an expensive deal..
better to buy new motherboard+compatible processor of ur choicce
Sep 19, 2010 | Intel ASUS P4SC Socket 478 Pentium 4...
I need a driver for asus P5L13L-T3-P5945GC
You can go to ASUS, and in the upper left hand corner enter T3-P5945GC and click on drivers below, It will take you to the download drivers page.
Good Luck
Mark
Feb 17, 2010 | ASUS P5GC-MX/1333 Motherboard
NO SOUND
Based on the question you asked, please download the latest drivers from Asus and try again. http://support.asus.com/download/download_item.aspx?product=8&model=Vintage-AH1
Dec 28, 2009 | ASUS T2-AH1 Barebone
Power switch & reset switch hookup
This should be your manual:
http://dlcdnet.asus.com/pub/ASUS/mb/socketAM2/M2A-VM/e2975_m2a-vm.pdf
Page 1-32 Has your connections.
Hope this helps :)
Mar 08, 2009 | ASUS M2N-MX Motherboard
Computer stop running 10-20 min after start
Usually this will happen due to an overheating problem. I would check ALL of your fans and make sure everything is working properly and that you are not overclocking anything that would cause issues as well.
Jan 28, 2009 | DFI MB INFINITY C51PV-M2 G AMD Athlon...
Driver for motherboard p4p8t
hi rosela,
You can download the drivers at
http://support.asus.com/download/download.aspx?SLanguage=en-us
Note that the T2-P Barebones System uses the P4P8T motherboard (ref.;
http://www.amazon.com/Asus-Computer-FM-AGP8X-T2-P-STANDARD/dp/B0002AAQK2
Thanks for using the FixYa service
Kind regards
Feb 19, 2008 | ASUS T2 P4P8T WO/CD/MDM FM AGP8X GETH WIFI...
Monitor Problem
Well assuming you used the same video cable when you tested the monitor on the Asus PC you?re left with: - Physical problem with the Asus video card. - Asus video card configuration problem. - BIOS configuration problem - Possibly a problem with the DVI/VGA adaptor depending on the answer below. A couple of questions about the Asus before we start: - I?m not sure I understand how the DVI/VGA converter figures into this. Is your cable coming off the monitor DVI thus you need it to plug into the Asus VGA connector? If yes who is the manufacturer of the device and what model do you have? - Has the Asus worked in the past with another monitor or is this new? - What is its history/configuration?
Mar 11, 2007 | ASUS T2-AH1 Barebone
Nvidia Asus M2n5-bn/t3-ah1/dp_mb C51pv Athlon-64 Socket-am2 Motherboard Logo
60 people viewed this question
Top Nvidia Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Are you a Nvidia Computer and Internet Expert? Answer questions, earn points and help others
