I have an active internet connection on my Dell Vostro 200, and try to install a program just saved and it says there's no connection to the internet, try again.
  • 629 Answers
If your internet connection is working, like you can access web sites, try to uninstall the program, run disk cleanup and delete temp internet files or browing cache/history. afterwards, make sure the program is not blocked by ur firewall or anti-virus if any as long as you are sure it is safe and legit. afterwards, install the program again. if it fails during installation again, try to download the set up file again as it may not be complete or it is corrupt. if it fails when it tries to load after installation, check program help documents if it has a internet setting that you need to adjust to make sure it will connect through your connection method,.
Posted on Nov 30, 2013
kamal1984
  • 1383 Answers
SOURCE: cant get net connection
http://drivers.softpedia.com/get/NETWORK-CARD/OTHER-NETWORK-CARDS/Dell-Vostro-200-LAN-Driver.shtml
Posted on May 31, 2009
bob_computer
  • 3153 Answers
SOURCE: dell vostro 200 4 repeated beeps on start up
Disconnect all devices from the power supply EXCEPT the motherboard
Remove any extra cards including video etc.(plug monitor into the onboard)
If you hear any beeps these can indictate where the fault is.
either of these sites below will help you further with that
Beep codes P
c
More beep codes
Power up the pc and see if the fans are working.
If not then double check the power connections to the board.
If you still have no fans it is time to suspect the power supply as the probable cause.
If the fans worked then you should have gotten a display which told you there was an error and offering you a chance to go into the BIOS. ignore it and shut down the PC.
Now connect one drive only and boot again.
Repeat that until you identify the component that is giving you a problem.
Once you find the problem then remove or disconnect and carry on with the rest to see if another component might also cause a problem
If there is only one problem device then you may want to investigate that device further, Unless you don't mind replacing it
Posted on Oct 05, 2009
  • 212 Answers
SOURCE: Dell Vostro 200 PC freezes randomly.
Try doing a system restore. back it up a few months and try that.
Posted on Dec 29, 2009
  • 644 Answers
SOURCE: Is the Dell Vostro 200 wireless enabled?
Most desktop pc's dont come with any wireless adapters, so i think yes youll need to purchase a wireless card.
Posted on Jan 22, 2010
tweekygeeky
  • 13 Answers
SOURCE: dell vostro 200 4 beeps then with f2 starts
here is the explanation of what can be possibly wrong,
1 long, 2 short - Video adapter error: Bad or improperly seated video card
Repeating beeps Memory error: Bad or improperly seated RAM
1 long, 3 short-Bad video RAM or video card not present
4 short Keyboard communication failure: Bad keyboard controller or keyboard
This is what the typical explanation is. To avoid assumption, i will need info on *********** board...thanks,
Posted on Mar 19, 2010
How to create hotspot in dell vostro 200 ?
Deepa christopher
Unfortunately, you cannot make the computer a hotspot without a wireless card installed. You could add a wireless card and then search the internet on how to setup the computer as a hotspot with the OS installed on the computer.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Apr 03, 2016 | Dell Vostro 200 PC Desktop
Dell Vostro 200 will not connect to internet, what can I do?
check that the lan connection isn't disabled.
go into control panel>network connections.
I would disable it and then re-enable it, that sometimes works. if there is no lan connection showing then you need to download it onto a usb stick from the dell website and install it on the vostro. Product Support Dell US
Apr 25, 2015 | Dell Vostro 200 Desktop Computer
Dell Vostro 200 won't connect to Internet after complete System Restore
Get a copy of "Driverpack Solutions" and run it. It sounds as though you do not have the network drivers installed.
Mar 13, 2012 | Dell Vostro 200 PC Desktop
Where is the wireless switch on the dell vostro 200
Unlike notebook computers, most desktops don't come with wireless networking built in. I can't find any mention on Dell's site that the Vostro 200 has wireless capability, so this computer doesn't have a wireless switch. To use your desktop computer on a wireless network, you'll need to install a wireless adapter. USB adapters are very easy to use since you just have to plug them in. They're not expensive and you can easily find them at retail stores and online.
Jun 13, 2011 | Dell Vostro 200 PC Desktop
Tropix drivers(note book) i tried and installed windows 7 but cd, DVD, internet connot connect in other ward i cannot instoll any thing.
If you have access to a computer that has internet connection, use that to go the Dell's website and go to support type in when asked to type in specific model type in Vostro V3500 using windows 7 and download driver network adapter just to be able to get on the internet from the Vostro. Save it on a flash drive or external drive. Hope this helps.
Feb 25, 2011 | Dell Vostro V3500, 15.6 HD LED, Windows® 7...
How to make internet connection in dell vostro 1310 ? I use USB Internet Broadband
install your usb broadban kit on your laptop, now its reaady to use...
Mar 12, 2010 | Dell Vostro 1310 Notebook
Jan 22, 2010 | Dell Vostro 200 PC Desktop
Cant get net connection
May 31, 2009 | Dell Vostro 200 PC Desktop
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
