Question about Whirlpool 30 In. Black Gas Range - WFG114SWB
Whirlpool oven won't go higher than 190 and takes forever to get that temperature
When oven temperature is selected we set it to 350 and when we push start it goes straight back to 190 help! i need to cook my thanksgiving diner!
  • Kimberly Claros
    Kimberly Claros Nov 28, 2013
    I dont know much about ovens... is there anyway you can tell me what that is and where it is? Thanks!
  • mike kirschbaum
    mike kirschbaum Nov 28, 2013
    The breakers are at your main electrical panel, the ones for the stove will be big, near the top. Turn them all the way off and then on again.
    Genius:
  • 1,198 Answers
Check both breakers, it may only be getting half the voltage.
Posted on Nov 28, 2013
Testimonial: "I dont know much about ovens... is there anyway you can tell me what that is and where it is? Thanks"
  • 15 Answers
SOURCE: Re:Whirlpool SF310PKE gas range
When the oven safety valve refuses to open and let gas through, it's almost always because not enough current is flowing through the ignitor. Often an aging ignitor will appear to be glowing pretty brightly but still won't draw enough current to make the valve open. The first thing to try replacing is the ignitor.
You describe your ignitor as "red and glowing" but oven ignitors normally get a lot brighter than "red" -- well into what I'd call yellow.
Posted on Dec 21, 2007
SOURCE: Whirlpool 465 oven temp
Go to Calibration mode and adjust the temperature up by 10, 20 or 30 degree. This is in each manual.
Posted on Jun 07, 2008
aborcass
  • 2651 Answers
SOURCE: Error F1E2 Whirlpool Super Cap Gas Range 465, oven crazy!
F1 E2
1. Verify failure if not displayed, using CANCEL/OFF key. Press key for 5 seconds until last
error code is displayed.
2. Disconnect power longer than 30 seconds.
3. Re-apply power and observe for longer than 1 minute.
4. If failure remains, disconnect power, replace control.
Posted on Nov 23, 2008
iwillfixforu
  • 619 Answers
SOURCE: Whirlpool error message EO-F3 and E4-F3
Bad EOC. Have to change the oven control. Sorry but this will be the only repair unless you know some one who can take it apart and repair some connections by using a soldering iron. Good luck.
Posted on Feb 02, 2010
heatman101
  • 43501 Answers
SOURCE: Doesn't get to correct temp set.
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Posted on May 06, 2010
My Kitchenaid Oven doesn't allow me to set a temperature higher that 350 degrees. Electric oven. For example, i will punch in 425 and the panel will default back the temperature to 350.
350 will be the design max for your oven unless the handbook says for your model is higher rated and is faulty
repair or replace with a higher rated temp oven
Nov 07, 2016 | KitchenAid Ovens
How do you turn it on and set temp
ELECTRIC RANGE USER INSTRUCTIONS - Whirlpool
www.whirlpool.com/digitalassets/.../Use%20...
Whirlpool Home AppliancesPress the number keypads to set a temperature other than 350°F (175°C) in 5° ...Timed Cooking allows the oven to be set to turn on at a certain time of day, ...
Oven Temperature Issue ' FAQ ' Sub-Zero and Wolf
www.subzero-wolf.com/.../oven-temperature-not-same-as-set-t...
Sub?ZeroOvens will heat up higher than the oven temperature set point and then turn off. ... If oven temperature is off on an R or GR Series Gas Range, ensure that the ...
Oct 29, 2015 | Kitchen Ranges
Whirlpool RBS245PDS18 temperature calibration?
If it is new contact the people that sold it to you for warranty repair. If not Just set it higher, that is a lot lest costly then getting the appropriate equipment to calibrate it. You can also replace it.
Dec 19, 2014 | Whirlpool Ovens
Can not raise temperature above 350
500 degrees farenheit is 260 degrees celcius (metric)
any chance the display is set for metric ?
Jun 28, 2012 | Whirlpool RBS305PDS Electric Single Oven
The temperature in my oven is not accurate.... If I set it for 350, it pre-heats and then buzzes [to let me know it's reached temp]....but the temperature is NOT 350; rather, it is at 275 [I have a...
Your oven's manual should tell you how to adjust this. The manual should also have a trubleshooting chart. Also remember, your temperature sensor may be going bad and will need to be replaced. For now, you can set the temperature 75 degrees higher to get the correct temperature you need.
Sep 15, 2011 | Whirlpool Electric Range
Whirlpool Built In Oven - Accubake - RB5275PD06 After self cleaning last week, the control panel is not functioning properly. For example, when we press the temp button, it won't go above 350. When...
Good Evening!
This is a common problem that Ledgestone Technologies and Fixyourboard.com can solve. The touchpad on your oven has failed and will need to be replaced. Read more about the failure and solution below. Message us if you have any questions!
info@fixyourboard.com
Whirlpool Oven Wont Increase Temperature Stuck at 350
May 27, 2017 | Whirlpool Ovens
My Whirlpool oven no longer heats to the set temperature.
Temp probe/thermometer inside oven dirty, or off attachment, or defective. On some models, a small screw head adjustment is provided to calibrate thermometer under dial knob. Else, I would just set dial 50 degrees higher rather than expense of new thermometer or dial.
Mar 02, 2009 | Ovens
Oven model RBS245pd86
after cleaning the oven the bake temp would not go any higher than 350. when you press the temp button to go lower or higher it only go down. could you tell me what is wrong or what to do.
Jul 27, 2008 | Whirlpool RBS245PDS Electric Single Oven
RBS305PDB6
The 350 as you stated is a default set point that you see before you start the cycle. What you should see afterwards (start bake) is the current temperature - which would normally be lower than the set or desired temperature - it will eventually get there
Regards
Jul 19, 2008 | Whirlpool RBS275PD Electric Single Oven
Whirlpool 30 In. Black Gas Range - WFG114SWB Logo
81 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
