Subaru 2007 Outback 2.5I Limited A/C Compressor Logo
James Osler Posted on Nov 27, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Acceleration I am having an acceleration problem car will start fine and run at idle fine but when I drive it sometimes won't take power. I see this happening in more wet rainy conditions when driving and I put my foot on the gas it will not accelerate. the check engine light was blinking but not staying on. I did have a full tank of gas at the time. Later today car was running fine no check engine light. I have had this problem before in the rain 40,000 miles before. Outside temp was 50 degrees 100% humidity (foggy)
mike kirschbaum
Level 3:
Genius:
  • Master 1,198 Answers
  • Posted on Nov 28, 2013
mike kirschbaum
Master
Level 3:
Genius:
Answers
1198
Questions
Helped
359610
Points
3184
A dirty air filter will be worse when damp.
1helpful
Engine cut out
Sounds like you may have fuel filter problem. you may want to check the pump and filters located in or near the fuel tank.
Go directly to the source ( Fuel Tank, Pump, Filters, Fuel Pressure Regulator and Injectors )
You may have water or grit in the fuel
Hope this helps
My 1997 Jimmy runs fine in idle when I take off the vechile is fine until it reaches 20 mph it won't accelerate and the rpms increase up to 3000 but no speed. What's wrong it's a 4 wheel d
Sounds like 2nd gear in the transmission is slipping. Cars usually shift at 15-20 mph from first to 2nd. First check the trans fluid.
I have a 1996 Isuzu Hombre. Sometimes it won't start and just turn over. It also dies sometimes while driving or just idleing at stop sign. When this happens there is a clicking and buzzing sound
Sounds to me like a bad battery, however the alternator could be bad as well if it's not charging the battery enough to allow for amperage to crank. Auto Parts Forum
1995 pontiac bonneville stalls
I just went through lots of troubleshooting and expense on my 1996. Whenever I would lift my foot off the accelerator and was below about 30 mph, the rpm's would starts jumping around and sometimes it would stall. If I gave it a little gas (accelerator), I could sometimes keep it running. It also backfired once in a while. Starts right back up. Also, if I let it idle while in part, it would die after 1-2 minutes.
I ended up finding a hole in the fuel regulator. About a ~$70 part if you get an AC Delco, but very simple to change.
96 GMC Vandura idle problem and sometimes acceleration problem
accelerator pedal position sensor/ throttle position sensor/ motor
idle problem under load could be idle rpms too low
ICT sensor
run the fault codes
Top Subaru Air Tools & Compressors Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Subaru Air Tool and Compressor Expert? Answer questions, earn points and help others
