Question about Sewing Machines
Elna ec/zz/sp/st/su manual 2 - Sewing Machines
  • 11 Answers
SOURCE: Elna walking foot
If your SU is an Air Electronic model i.e. 80's model, Elna didn't make a walking foot to fit. However, if you've got a walking foot that is the same height from sole plate to the screw fitting as a standard Elna foot then you could give it a try. The walking foot connects to the presser bar with a screw but the needle bar also needs to hook into a secondary lever on the side of the walking foot to make the foot actually move. Probably sounds very confusing . Check the movement of the foot manually by hand turning the fly wheel to see how it works before you actually use with the motor to minimise any problems if the foot doesn't fit.
Also you'll probably only be able to do straight stitch with this foot due to the clearance around the needle plate.
Posted on Oct 28, 2008
SOURCE: have a 1970's elna su supermatic but cams don't work
There are two types of discs - single and double.
For the thinner single discs do as follows:
1.Turn stitch width knob to "0"
2. Turn stitch length knob to "0"
3. Insert the single disc
4. Turn the top selector to "A"
5. Make sure the needle selector is in the centered position.
6. You may now choose any stitch length or width you wish. I usually try "3" for the width and 1/2 for the length to start.
For the thicker double discs do as follows:
3. Insert the double disc
6. You may now choose any stitch width.
7. The stitch length must be put on "A" - this is the difference between the single and double discs!
I hope this helps!
Posted on Apr 09, 2009
  • 47 Answers
SOURCE: I need a manual for an Elna SU
Visit www.ifixmachine .com
Posted on Jul 24, 2009
SOURCE: Manual for Elna lotus sp model 35 m703163
http://www.scribd.com/doc/25386753/Elna-Lotus-Sewing-Instruction-Manual
Posted on Jul 13, 2010
  • 51 Answers
SOURCE: Need instructional manual book and extension table
http://www.tradebit.com/filedetail.php/91117786-elna-sp-st-su-sewing-machine-manual
Posted on Sep 14, 2010
How do you adjust the tension control on an Elna lotus SP
The tension dial is on the front of the machine right above the needle. The higher the number, the tighter the tension is applied to the top thread. HINT: When threading the top thread, ALWAYS RAISE the presser foot throughout the entire threading process. This allows the thread to seat completely in the tension disk. Tension is correct when the top and bobbin threads meet in the middle of the fabric.
Elna Lotus Instruction Booklet
Elna Lotus SP bobbin case repair Removing cotton jam from Elna Sewing...
Elna SP ST SU sewing machine repair tips (I use liquid Tri-Flow Synthetic Lube or silicone spray to loosen parts seized from old oil. Do NOT use WD-40, cooking oil, motor oil...)
Apr 29, 2017 | Elna Sewing Machines
I'm looking for manual 1&2 for Elna lotus sp type 35 p836436 the 1968model
You will probably need to contact an Elna dealer. Elna does not readily make manuals available.
Sep 21, 2016 | Elna Sewing Machines
Having trouble replacing the bobbin case
Elna SP ST SU sewing machine repair tips - YouTube
? 2:25
https://www.youtube.com/watch?v=TqrbimZyP1U
Oct 24, 2011 - Uploaded by Absolute Sewing
More Photos on replacing gears and some repair ti... ... I amhaving trouble with my Elna SU 62 skipping stitches when I sew on knits. ... Elna Lotus SP bobbin case repair - Removing a cotton jam from a Elna Sewing machine ...
Amazon.com: Bobbin Case 627569106 - Elna, Janome ...
Jan 12, 2016 | Elna Sewing Machines
Manual for elna lotus sp
follow this link for free download
http://www.scribd.com/doc/25386753/Elna-Lotus-Sewing-Instruction-Manual Elna Lotus Sewing Instruction Manual
May 06, 2014 | Elna 2007 Mechanical Sewing Machine
I need a manual for the elna stella air electronic type 57 sewing machine
You could try www.diplodocs.com or www.scribed.com, I think I've seen it on one of those sites. Is the 57 the TX model? If so, its got the most stitches of the Stella models, there was the ZZ, TSP, SP and TX, nice machine. If you can't find a free one you should be able to buy one from one of the sites like www.sewingpartsonline.com or www.whitesewingcenter.com
May 14, 2012 | Elna Sewing Machines
I nead a manual for a elna special ? please
try this link http://www.arizonaexpressionz.com/elna_instruction_manuals/Elna_EC_ZZ_SP_ST_SU_manual.pdf
there is a sewing guide available too, the SP would have less stitch functions than the SU - they did combined manuals for this range I think.
Good sturdy Swiss made machine, these were used in school classrooms for many years in NZ.
May 22, 2011 | Elna Sewing Machines
I purchased a used Elna su type 62cr209707. I need an instruction manual, where do i find one?
The Star Series SU is a lovely machine,
you can purchase a manual from here - well worth spending the dollars to find out how it works, especially the buttonhole which isn't like modern 4 step ones. You may also find that the foot control has a switch to give you slow speed vs normal speed sewing.
If you are in the USA you could also visit www.whitesewingcenter.com, they have lots of Swiss Elna goodies for sale and are very knowledgable on these machines.
You might also want to track down a newer Swiss made Elna pressure foot holder with the clip on feet, rather than using the full feet with your machine. They are interchangeable. Have you got the black discs to go with your SU too? there is a large range so you can sometimes track down some more to add to your collection.
There is also a newer black pressure foot screw which is a combined thread snip, its a bit bigger in diameter to the black thumb screw on your machine now and you can use it to cut and hold the threads at the end of each seam, very cute.
Always give this machine a good clean and oil before using it, there should be a red dot in the middle of the bobbin holder, oil here regularly and any other points that the manual shows with good quality sewing machine oil, it takes 130/705H standard sewing machine needles, put in a new needle for each project to get great stitching results.
Enjoy your SU!
Apr 15, 2011 | Elna 3210 Mechanical Sewing Machine
I have a old Elna machine. The air electronic SU 390 B. I have lost the manual and am trying to do buttonholes on a dress. I have forgotten the sequence of nob adjustments to complete the process.
Is this the duplex model with the base that fits into a sewing cabinet?
My Elna booklet lists a SP "air electronic" duplex (CL.39), if so, then it would be same stitches as the 38, yellow front panel, 7 built in stitches and automatic knob with blue markings for buttonholing.
Here is the SU manual images for buttonholing, should be exactly the same for the SP.
tally_girl_4.jpg Instructions are:
use buttonhole foot. turn the 3 dials to buttonhole marked in blue (stitch selection, width and length).
Mark length of buttonhol on the material. Place work under foot with the mark in the middile fo the foot, the start being directly below the needle. sew the first side, raise the needle. Turn stitch width dial to 2, blue. Sew a few stitches for bartack. Raise the needle.
Turn stitch width dial to 3 blue. sew the second side. stop just short of the first side. Raise the needle.
turn the stitch width dial to 4 blue. sew a few stitches for bartack. Raise the needle.
Turn stitch width dial to "fastening off stitch" blue dot. Sew a few stitches, holding back the material by hand. Raise needle, lift pressure foot and remove work, triming off threads.
Open the buttonhole with your seam ripper (put a pin across the end to avoid any nasties).
Aug 26, 2010 | Elna 2007 Mechanical Sewing Machine
Sewing Machines Logo
26 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
