Question about Microsoft (X-Box) P5F-00001 Xbox 360 Headset
8 GB USB Flash Drive not enough memory for GTA 5 in a Xbox 360 game console
8 GB flash drive not enough memory message in a box 360 when trying to download Grand Theft Auto 5
    Problem Solver:
  • 7 Answers
Similar problem. At the start, instead of the usual 'Save to internal memory or external device' select 'Save to Cloud' and that should take care of it. I actually ended up buying a 16GB USB Stick so I don't get caught out again. Hope this helps.
Posted on Dec 09, 2013
  • 73 Answers
SOURCE: wont read disk
i had that problem i took it back to the shop and swapped it now it works fine
Posted on Nov 29, 2008
gungraveisli
  • 75 Answers
SOURCE: my xbox 360 hard drive
the systems serial number is located on the back of the unit and the hard rdrives is on the under side of the drive by the barcode. try writing them down and entering them at the format screen.
Posted on Mar 16, 2009
bilink
  • 128 Answers
SOURCE: xbox 360 wireless guitar won't sync with console
seems like the sync problem with XBOX console, you can try fixing this with the help of XBOX 360 repair guide
available here
Posted on Jul 14, 2009
arcavazos837
  • 112 Answers
SOURCE: I have a problem with my Wired Xbox 360
You have to sync it. To do this you need to Press and and hold a tiny button in the front of the xbox next to the sd card slot for about 2 seconds. Then right afterward press a tiny button located on the top of the xbox controller. Its located next to the battery pack.
Posted on Jan 02, 2011
  • 4 Answers
SOURCE: can you connect a white
Yes you can do this. Simply get the White controller turn it on and hit the sync button at the same time as hitting the sync button on the Elite Console.
Posted on Jan 29, 2011
Fix code 3141 3151 b200 0700 c000 0013 help me fix please .
Did you download the 12625 update from Microsoft and try it from USB? More info please, was the box modded in any way? The update you need is not the latest by far. Download update 2.0.12625.0 here
1 Plug your USB flash drive into a USB port on your computer.
2 Download the update file.
3 Click Save to save the console update .zip file on your computer.
4 Unzip the file. If you are using Microsoft Windows XP, Windows Vista or Windows 7 or 8, double-click the .zip file to unzip it.
5 Copy the contents of the .zip file to the root directory of your flash drive.
6 Unplug the USB flash drive from your computer.
7 Plug the flash drive into a USB port on your Xbox 360 console.
8 Restart the console.
When the console restarts, the installation program starts automatically. Select Yes when you are prompted to update the new console software.
Hope this helps
http://download.digiex.net/Consoles/Xbox360/Dashboards/2.0.12625.0.zip
Jan 29, 2015 | Microsoft Xbox 360 Console
My xbox 360 is now showing flashing 1 red light on and off
These steps are taken from the support site as always, it's the first website where you should look.
Solution 1: Disconnect and reconnect cables
Here's how:
  1. Turn off your Xbox 360 console.
  2. Unplug all memory units, controllers, and accessories from your console.
  3. Unplug everything from the back of your console, including power and video cables.
    Don't remove the hard drive.
  1. Reconnect your console's power supply.
  2. Reconnect each accessory one at a time, starting with a controller.
  3. After you've reconnected every accessory, turn the console on.
Solution 2: Remove the hard drive
To see whether the problem involves the original Xbox 360 Hard Drive, temporarily remove the hard disk drive. Here's how.
Note Not all Xbox 360 consoles include a hard drive. If your Xbox 360 console doesn't have a hard drive, to go Solution 3.
  1. Turn off the console.
  2. Locate the hard drive on the top of the console (or on the left side, depending on how the console is oriented).
  • Press the release button on the hard drive.
  • Lift the hard drive away from the console.
hdseparating.jpg If these steps resolve the issue, reattach the hard drive to verify that the error occurs only when your Xbox 360 Hard Drive is connected.
Solution 3: Disconnect memory units or USB flash drives
Here's how:
  2. Unplug any memory units or USB flash drives attached to your console.
  3. Turn on the console.
If these steps resolve the problem, reattach the memory unit or USB flash drive to make sure the error occurs only when it's connected. If this is true, order a replacement memory unit or use another USB flash drive.
Solution 4: Request a repair
If the previous steps don't resolve the single flashing red light issue, there are no additional troubleshooting steps. Your original Xbox 360 console must be repaired at our service center. Start the repair process online.
Jan 09, 2015 | Microsoft Xbox 360 Console
X- box 360 is asking me to apply an update. So when I apply it a prompt comes up that says.update failed status code: 3F4B - 0000 - 0080 - 0300 - 8007 - 000F
Dear ,
Please try the following solutions.
Solution 1: Try installing the update again 1.Restart your console.
2.Press the Xbox Guide button on your controller (the large central X button).
3.Go to Settings and select System Settings.
4.Select Network Settings.
5.Select Wired Network or your wireless network name (if you are prompted to do so).
6.Select Test Xbox Live Connection.
7.Select Yes if you are prompted to update your console software.
If this didn't resolve the problem, try the next solution.
Solution 2: Make sure you have enough storage space
The latest console software update requires at least 190 megabytes (MB) of storage space (or 256 MB if you live in Japan). If you don't have enough free space, you need to move or delete some items
Solution 3: Clear the system cache
Removing the temporary files on your console might solve the problem.
After clearing the cache, try the update again. If this didn't resolve the problem, try the next solution.
Solution 4: Reinsert the storage device
1.If you're using an Xbox 360 Memory Unit or a USB flash drive instead of a hard drive, remove and reinsert the Memory Unit or USB flash drive.
2If you have a hard drive, try removing and adding the hard drive
again.
Solution 5: Roll back updates 1.Press the Guide button on your controller, go to Settings, and select System Settings.
2.Select Storage.
3.Scroll down to your Memory Unit or hard drive, so that it's highlighted.
4.Press the Left bumper, press the Right bumper, and then press X.
5.Again press the Left bumper, press the Right bumper, and then press X.
6.Select Yes.
Regards,
Samy
Regards,
Aug 10, 2014 | Video Game Consoles & Games
Wont read a flash drive
Make sure the flash drive will work on a normal computer. If it does try a different port on the xbox. If it works on the computer and not the xbox you might have to format the flash drive to work with the xbox Go here USB flash drive support for Xbox 360 or How to Configure any USB Flash Drive as Storage on Xbox 360
Apr 03, 2014 | Microsoft Xbox 360 Console
Won't read the flash drive
Make sure the flash drive will work on a normal computer. If it does try a different port on the xbox. If it works on the computer and not the xbox you might have to format the flash drive to work with the xbox Go here USB flash drive support for Xbox 360 or USB flash drive support for Xbox 360
How to update xbox 360 model 1439 the sensor doesn't work
Hello
An alternate method is to log onto x box live, find updates.Download them to a pc.
Use winzip or winrar to compress the file or update.
Then using a flash drive or a usb cable put the update onto the x box console via usb or flash drive.
Oct 19, 2011 | Microsoft Xbox 360 Console
My xbox work read copy games or originals
Did you try to flash the X-BOX drive with the j-tag exploit, if yes then it must have not run successfully , if you have not dont do it as it will just ruin your console if you donot know what you are doing. Try using a Cd-Lens cleaner as your DVD-Lens might be dirty and could be a cause. Does the disk spin when it is inserted into the drive ?
Clear your system cacheIf your Xbox 360 console can't play multiple game discs, try clearing your system cache. Here's how:
  1. On the console, go to My Xbox, and then select System Settings.
  2. Select Memory.
  3. Highlight any storage device, and then press Y on your controller.
  4. Select Clear System Cache.
    Note If Clear System Cache is not available, follow the steps in Clearing the System Cache (http://support.xbox.com/en-us/pages/xbox-360/troubleshoot/hardware/clear-system-cache.aspx) .
  5. Try to play a game disc.
  1. Turn off your console.
  3. Turn on your console.
  4. Try playing a game.
If all these fail try this
http://support.xbox.com/en-us/pages/xbox-360/troubleshoot/hardware/disc-drive-wizard.aspx
Mar 04, 2011 | Video Game Consoles & Games
It wont read on my xbox 360
If you already have the Spring 2010 Dash Update for the Xbox 360 console this can be configured( go to Setting up your Xbox 360 with your USB Flash Drive).
The update allows you to configure a flash drive to hold up to 16GB of Xbox 360 games, gamertags, videos, and other information. You can connect two USB storage devices to your console at once.
  • If you don't have it yet, you need to download the update:
To install the update through Xbox LIVE
1. On your Xbox 360 console, sign in to Xbox LIVE.
2. Select Yes, updated now when prompted.
3. When you see the new Dashboard, you're done.
Setting up your Xbox 360 with your USB Flash Drive: 1. Plug the USB flash drive to the Xbox 360 console.
2. On your console, go to My Xbox, and then select System Settings.
3. Select Memory.
4. On the Storage Devices screen, select USB Storage Device.
For detailed instructions you can visit: http://kb.sandisk.com/app/answers/detail/a_id/2777
Nov 25, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
X-box 360s brand new, cannot get it to download the update
Hello
The easiest option to update the Xbox 360 hard drive is to connect to Xbox Live. The console will automatically prompt the user to install any available updates. Alternatively, users can download the update files to a USB flash drive to transfer to the Xbox 360 hard drive.
Update via Xbox Live
Open the Xbox 360 dashboard menu. This menu automatically appears when the console is turned on. Press the "Xbox" button, followed by the "Y" button to return to the dashboard menu from a game.
Scroll up to the "My Xbox" tab of the dashboard menu.
Select "System Settings" from the "My Xbox" section of the dashboard. Scroll to the right while the "My Xbox" tab is selected to reach the "System Settings" icon.
Select "Network Settings" from the "System Settings" menu.
Select "Test Xbox Live Connection" from the network settings. A prompt will appear to update the Xbox 360 hard drive if your system is not already updated to the latest version.
Select "Yes, update now" to install the latest updates to your Xbox 360 hard drive.
Updating via USB Flash Drive
Copy the update files onto the root directory of your USB flash drive. You can download the Xbox 360 update files by going to download.microsoft.com/download/1/d/8/1d8c09be-278e-41cd-98be-eb9188128227/$systemupdate9199.zip. You must extract the files from the .zip file before placing them on the USB drive. The update files cannot be placed into a folder or the Xbox 360 system will not recognize them.
Remove the flash drive from your computer.
Insert the flash drive into the USB port on the Xbox 360 console.
Turn on the Xbox 360. An update prompt will appear when the system powers up.
Select "Yes, update now" to update the Xbox 360 hard drive.
Nov 21, 2010 | Video Game Consoles & Games
to play copied dvd's ( i think thats what you typed ), you will need to do a few things, including taking your xbox apart, and connecting it to your computer. You will also need to flash your dvd drive.
Quick NEED list:
1. SATA Cable
2. SATA Card
3. torx screw driver
4. torx 8 and 10 bits
5. Flash / Pen drive (USB)
To do this, your computer has to have some kind of SATA port. You can buy a SATA card for $25.00 at your local computer hardware store. Also make sure you pick up at least an 18 inch SATA cable. Now once you have both of these, then you will have to take your x-box apart.
Dont know how to take your 360 apart? Click on the link below
http://www.llamma.com/xbox360/repair/Xbox-360-Disassembly.htm
Heres a good tutorial on how you flash your dvd drive too:
http://venomousfire.blogspot.com/2008/02/how-to-flash-benq-xbox-360.html
hope this helps
Feb 10, 2008 | Microsoft Xbox 360 Core System Video Game...
Microsoft (X-Box) P5F-00001 Xbox 360 Headset Logo
141 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
