Question about Kitchen Ranges
Having problems with fan assisted oven on leisure roma 100 cooker, it doesnt seem to work everything else seems to work fine, Can anyone help me
  • 1 more comment
  • bmurphylk May 10, 2009
    Thanks I have done what u said I have checked for any cracks and made sure the door is closed fully to the frame but no joy. There seems to be no power supply at all to oven light doesnt come on even. Its a domestic appliance
  • Anonymous Mar 29, 2014
    clock stopped working and the oven went off. everything else working. now oven will not come on
    clock not working, just gone a black face. now oven will not work
    Guru:
  • 462 Answers
Often these fan assisted type ovens have a safety that keeps th fan off if it believes the door is open. Look for uneven door closing or cracks in the door to frame closure. Is this a commercial convection oven?
Posted on May 08, 2009
  • 1 more comment
  • Farley Redfield
    Farley Redfield May 11, 2009
    Well Can you tell me what does come on? And list the things that are suppose to come on and are not?
  • Farley Redfield
    Oh yes I forgot to mention that can you see where the door switch is? And access it? If so put the wires together and see if this will allow anything to come on if so this switch is out.
    But because you say the light dosnt work, and Im assuming it may have a set of fuses inside the oven and this may be whats out. Remove and check the fuses for continuity or check across them with power applaied (thats end to end on each one) for voltage. If you read voltage across the fuse (like you were going to check for continuity but in this case your checking volts) th fuse is open replace it and recheck.
  • Farley Redfield
Main oven not no heat.thought maybe heating element. tried to take element out from inside oven but seem I may need to take back cover off as it seems the two screws on one side come in from there.
yes your doing fine, usually heating element are sturdy and seldom busted. try to follow the wiring inside and locate the thermal fuse that is installed inline with the wiring,have it replaced
Sep 03, 2015 | Leisure GRB6CVR Electric Cooker with...
Gas hob will not light on my leisure gas hob
At the rear of the oven is a gas cut off valve. Try twiddling it
Nov 24, 2013 | Ovens
Timer leisure Roma 100
You will have to resort to your owner's manual. Every Range is different. If you don't have the owner's manual, check with the manufacturer online.
Apr 30, 2012 | Kitchen Ranges
Have a Leisure roma 100 cooker model number RM10FRS main fan oven not heating need a service manual to find out how to get at heating element to see if needs replacing.
most likely thermal fuse behind oven take off back plate and you will see the brown wire with the heat shrink sleeving covering the fuse.wire and fuse comes as one part
Jul 05, 2010 | Kitchen Ranges
Need manual for Britannia ilve range cooker
You may have the cooker oven set to automatic. Phone their Service Team on 01253471111 option 3. They will help you fault find. The ID strip with all the cooker information is inside the right hand oven on th right hand side.
Jun 08, 2009 | Britannia SI10T6L Dual Fuel (Electric and...
No Bake; everything else works
Hi, When you put the oven on bake, can you see the ignitor glowing but get no flame?
Sound like the ignitor might be getting weak and not opening the gas valve. Please let me know if this sounds like the problem.
It is common for the ignitor to go bad. Even if it glows, it can be bad.
Please let me know if I can assist you further.
Vic
May 31, 2009 | GE Profile JGS968 Gas Kitchen Range
Both ovens on my leisure rangemaster 100 will not come on
phone rangemaster they can advise how to change the spark in egnition and supply bit. 08707 895 107
Jan 23, 2009 | Rangemaster 110 (Gas) Kitchen Range
How to fit a flame failure device to rangemaster 55
the part that you need is the oven ignitor, located nest to the oven burner. that part gets hot to open the gas to the burner, that will make the oven work again.
Dec 08, 2008 | Rangemaster 110 (Dual Fuel) Dual Fuel...
Flavel Milano 100
Hi all...
Yep got the main oven gone......
Lucky iam good with electrics, got my brother in law to double check Qualified Elctrician it turns out that its the Thermal Fuse that has gone have ordered a new one at the cost of £8.......
This range is made by Beco thats why its hard to find info on the cooker.. The grill/fan oven has thermal fuse as well.....
Hope this helps MVE
Aug 11, 2008 | Kitchen Ranges
Kitchen Ranges Logo
1,047 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
