Question about HP Black Pavilion 20-b013w All-in-One Desktop PC with AMD E1-1200
Hp pavilion all in one AMD goes to sleep after 1 minute idle then asks for password to open up.. how to extend idle time to 2 hours
Goes to sleep after 1 minute idle time then asks for password to get back in. every time I get up it goes to sleep.. I want to EXTEND IDEL TIME... thank you
  • HP Master
  • 4,134 Answers
What you are experiencing isn't "sleep" mode, it is the screen saver. If you have WINXP, right click on a clear area of the desktop, and select "Properties". When the DISPLAY PROPERTIES window appears, select the "screen saver" tab. Change the "WAIT" time to the time you wish the scrren saver to delay. If you don't want to have to login after a screen time out, uncheck the "On resume, display Welcome Screen" box.
Posted on Nov 27, 2013
4 Suggested Answers
Sameeraryan
  • 82 Answers
SOURCE: HP Pavilion dv9667ea laptop continually freezes
fORMAT YOUR oPERATING SYSTEM BEFORE THAT DO TAKE VACKUP THIS WILL SURELY HELP YOU
Posted on Dec 27, 2008
xboxLoVeR
  • 6 Answers
SOURCE: Monitor went into sleep mode after uncertain time.
First of all I dont think and moniters should have sleep mode..
Im not sure but it might be the connection from your pc to the moniter.
(-(-(-NeRd-)-)-)
Posted on Dec 31, 2008
SOURCE: I have an Hp pavilion
Verify your fans are for the CPU and case are moving. You can remove the Pc cover and turn on the Pc. Watch the cooling fan on top of your CPU heat sink, it should begin spinning when you turn on your PC. If it doesn't then with the PC unplugged, make sure the connector for the fan is seated properly. From behind the PC you should be able to feel the Power Supply cooling fan moving air. Either of these could cause your PC to over heat and shut down.
Posted on Aug 18, 2010
I AM LOCKED OUT OF MY KINDLE FIRE IT KEEPS ASKING ME FOR A PASSWORD AND I NEVER SET ONE.
If you can't remember the password for your Kindle, you can reset your password to regain access.
To reset your Kindle if you don't have the password:
Kindle Touch
1. Press and release the power button to turn on the device or exit sleep mode.
2. Enter "111222777" into the passcode field and select OK.
Kindle
2. Select the keyboard key once on the password screen and enter "resetmykindle" in the password field and use the controller to select the enter key.
Kindle Keyboard
1. Slide and release the power switch to turn on the device or exit sleep mode.
2. Enter "resetmykindle" in the password field and press the enter key on the key pad.
3. Wait several minutes while your Kindle restarts.
Kindle FIRE
2. In the password field, attempt to enter a password 4 times.
3. When password is incorrectly entered 4 times, you will be prompted to reset Kindle Fire.
4. Select "Ok reset".
Feb 16, 2016 | Cell Phones
How to unlock keys
Try these -
1. Turn on your HP Pavilion Slimline computer.
2. Press "F2." This attempts to load your HP BIOS. You are prompted to enter a password.
3. Type "merlin" into the password prompt and press "Enter" to unlock the password on your HP Pavilion Slimline BIOS.
Jun 26, 2014 | HP PAVILION SLIMLINE S7520N AMD Turion 64,...
How do i change sleep mode
Sleep Timer Mode
The Sleep Timer mode is an energy-saving feature that enables you to set a time for the monitor to
power on and off at the same time every day. This also extends the life of the backlight bulbs in the
monitor. The Sleep Timer has five settings:
? Set Current Time
? Set Sleep Time
? Set On Time
? Timer: On/Off
? Sleep Now
To set the timer:
1. Press the Menu button on the monitor front panel to display the OSD Menu.
2. Scroll down and highlight Management.
3. Press the OK button to select Management.
4. Scroll down and highlight and select Sleep Timer > Set Current Time.
NOTE: You must set the current local time before you reset the time for Sleep Time or On Time. Note that the time is displayed in a 24-hour clock format. For example, 1:15 p.m. is displayed as 13 hours 15 minutes. A power failure or loss of power to the monitor will cause the timer to reset to 00:00. If this occurs, you will need to reset the sleep timer mode.
5. Press the OK button once to enter the adjustment mode for hours.
6. Press the - (Minus) or + (Plus) button to adjust the hour.
7. Press the OK button again to enter the time for minutes.
8. Press the - (Minus) or + (Plus) button to adjust the minutes.
9. Press the OK button to lock in the time chosen.
10. After setting the current time, the highlight automatically skips to Set Sleep Time. Repeat steps 6 through 9 to set Sleep Time.
11. If you do not want to set Sleep Time, press the OK button twice, then select Save and Return to exit the menu.
12. After setting Sleep Time, the highlight automatically skips to Set On Time. Repeat steps 6 through 9 to set On Time.
13. Set the Timer mode to On to activate the Sleep Timer settings.
14. When you are finished, select Save and Return to exit the menu.
The fifth selection, Sleep Now, turns the monitor backlights off immediately and stays in sleep mode
until the next On Time activates or a monitor button is pressed.
May 27, 2014 | HP Pavilion 22bw Black 21.5" LED Monitor...
Hp pavilion all in one amd
Usually control panel, settings or look for something like power saving
Nov 27, 2013 | Audio Players & Recorders
How to extend the battery life of your laptop HP/Compaq pavilion dm4
Tips to increase battry life:
1. Never charge when battery already full.
2. Keep low Brightness.
3. Keep volume medium.
4. Always use headset to hear songs or see films.
5. High graphics games never play on laptops it reduses your lapy's battery life.
6. Never use laptop up to 0% battery power.
7. Close background processes using task manager(these processes not essential but consume battary.
Jun 21, 2013 | HP Pavilion dv6000z Notebook
Desktop icons disapear when h p pavilion pc goes into sleep mode
Open Control Panel, Power Options, set to High Performance, you didn't supply the model of HP or the OS?, change power plan or Advanced power settings, to Sleep and Hibernate to Never, adjust other settings. Always shut down your laptop when not in use, your laptop will last longer, extend component life and will not be subjected to power surges, remove the battery if used on AC for extended periods. A reboot everyday will reset the laptop's OS.
Jan 29, 2013 | HP Pavilion Computers & Internet
HOW DO I TURN OFF THE SLEEP MODE ON MY PRINTER BROTHER MFC 7420
Setting the Sleep Time reduces power consumption by turning off the fuser inside the MFC while it is idle. You can choose how long the MFC is idle (from 00 to 99 minutes) before it goes into sleep mode. The timer is automatically reset when the MFC receives a Fax or PC data or makes a copy. The factory setting is 05 minutes.
To turn Sleep Mode off press Menu/Set, 1, 6, 2. Then use the dial pad to enter the length of time the MFC is idle before it goes into sleep mode, in this case 00 so it wouldn't go to Sleep mode at all. Press Stop/Exit.
Feb 04, 2011 | Brother Office Equipment & Supplies
My hp pavillion runs good then after an hour to 2 hours latter it just turns itself off then restarts.why?
Just out curiosity have you ever gone into the power options and looked when it is set to go to sleep? Go to controll pannel and then to power options set them all to never and give that a try!
Nov 18, 2009 | HP PAVILION SLIMLINE S7520N AMD Turion 64,...
Hp Pavillion dv6000 will not turn when hit theon off button nothing happens
A lot of times these laptops are in a sleep mode (after a certain period of time which is decided by the windows or the user, the computers turn of the screen). I would start by pressing on the power button for a long time (about 1-2 minutes), then try all the basic stuff:
1. check the laptop's cable, if it looks okay or not, maybe there's a problem charging the battery.
2. try replacing the cable and the battery.
3. try removing the battery for about 24 hours.
update me if you have any developments
Oct 27, 2009 | HP Pavilion dv6000t Notebook
Need control switch for time when moniter goes to sleep
The setting is controlled by your computer not the monitor. I'm assuming you are running Windows - open the Control Panel (from the Start button) and go to Power Options. You can find it in here. If you have problems, get back to me with the specific Operating System you are using and version or service pack level and I can give you more specific details.
Oct 06, 2008 | HP Pavilion F1703 17" LCD Monitor
HP Black Pavilion 20-b013w All-in-One Desktop PC with AMD E1-1200 Logo
74 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
