Question about Brother LS-2125 Mechanical Sewing Machine
Bobbin keeps popping out - Brother LS-2125 Mechanical Sewing Machine
  • 37 Answers
If you are using a generic plastic bobbin, check the height of the bobbin. I only use metal bobbins because all the plastic ones do that in mine.
Posted on May 12, 2009
Bobbin case keeps popping out
Hallo Rhonda
Pls chk your bobbin locking at fixing shaft grew or not. on bobbin a sliding locking plate locks at shaft. while keeping in case chk that is loked by pulling. if it dosent lock , change bobbin with spare one.
Jul 16, 2014 | White Sewing 2037 Mechanical Sewing...
Janome sewist 525s my bobbin shuttle keeps popping out
try another bobbin, that one might be warped
use a can of computer air in the bobbin area for lint
if the problem persists then the machine should be checked
Mar 29, 2014 | Janome Sewist 525S Mechanical Sewing...
Janome travel mate bobbin assembly
there could be something wrong with the hook and the hook race
or there could be a timing problem with the machine.
check to make sure the top thread doesn't come off the thread take
up lever when sewing
make sure the bobbin is turned the right way also.
Dec 05, 2012 | Janome Sewing Machines
Singer 2662 bobbin case keeps popping out.
Check our bobbin for burrs and damage. If the thread catches a rough edge it can pop the bobbin out. Try a different bobbin with new thread... see if that helps. If it does your current bobbin is likely trash.
Hope that helps.
Jul 14, 2012 | Singer 2662
The bobbin case keeps popping the bobbin up when trying to sew. How do you fix this problem?
Hi Kathy it sounds like maybe something is in/under your bobbin case. If you have a manual it should show you how to take the bobbin case out and clean it. Hope this helps
Jun 18, 2012 | Sewing Machines
The bobbin case on my singer 5050 keep popping up?
is this a top or front or side loading bobbin case?
Jan 16, 2012 | Singer 5050 Mechanical Sewing Machine
My bobbin keeps popping out. There is a small hole under the bobbin casing. I pulled what appeared to be a wick out of there. It was frayed on the end and I thought it was part of my tension problem. Is...
Hi, the wick will not interfere with your tension, it is there to oil the hook shaft.
If you e-mail me at dupina@mweb.co.za i will send you the instructions and pictures on the bobbin case settings. Take special note of the retaining bracket, plate spring position and the Reverse rotation stopper. It sometimes happens that the reverse rotation stopper bends upwards, allowing the bobbin case to move underneath it. Press it slightly down to prevent this.
Aug 25, 2011 | Singer Touch Sew 7462 Mechanical Sewing...
I threaded it all right i have cheacked it many times but the thread in the bobbin keeps getting jammed
Many causes for this problem. Most common are;
  1. Top thread not inserted correctly.(must keep thread tight.)
  2. Debris and loose thread around the bobbin cage. All it takes is a tiny piece of thread in the right place.
  3. Bobbin inserted backwards in the "bobbin holder". When installed correctly, There is some resistance when you pull on the thread, but the bobbin will spin without trying to pop out of the "bobbin holder".
Oct 29, 2010 | Brother XL-5500 Mechanical Sewing Machine
The bobbin case on my Singer Inspiration 4210 sewing machine keeps popping up in the back causing my thread to bunch up underneath. I cleaned the bobbin case, but now it won't sew at all; the case keeps...
unscrew the black plate that holds in the bobbin case and move it over to the left just a little bit, but make sure there is still clearance between the lower right corner of the case and the plate. The case should be able to wiggle a little, but not so loose it can pop out..
Jan 17, 2010 | Singer Inspiration 4210 Mechanical Sewing...
Brother LS-2125 Mechanical Sewing Machine Logo
89 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
