Question about JVC Car Audio & Video
How to adjust fader on jvc model kd-s38
Need to know how to adjust fader, balance and channel presets on car sterio jvc model kd-S38
Jvc kd s39 how do you adjust the fader and balance?
This helped me isolate a bad RCA cable. Originally I thought it was the balance. Found the balance menu b/c of this post. Thank You!
May 14, 2013 | Car Audio & Video
Wiring a jvc kd-s38 to a 1996 Monte Carlo ls
You may download the installation manual here. If you need the operation manual, you may download it here.
Jun 02, 2012 | JVC Car Audio & Video
How do i unlock the panasonic dvd-s38 to play all region dvds
In addtion to the S68/S38 remote this hack requires a universal remote configured for the S58/S38 with a separate 'Pause' button (or another Panasonic DVD remote with a separate 'Pause' button may work).
Neither the 'Play/Pause' nor 'Frame' buttons on the S58/S38 remote work for this hack.
1. Power on.
2. Open tray.
3. Using the S58/S38 remote press Audio, 1, 9, 8, 2, Subtitle
(it is not required but, if the TV is on, it will display the 'no go' icon after each key press - ignore it).
4. Using the other remote press Pause.
5. Using the S38 remote press 0.
The DVD front panel should now show the text "on".
If so, the DVD is region-free.
Dec 06, 2010 | Panasonic Dvds38 Dvd Player
I would like to know how to hear the sound on my rear speakers how do I do do this I have a KD-A605/KD-R600 model by JVC
To switch from front to rear speakers you need to look for FADER option.It would be under main SOUND menu.That will of course work if you got rear speakers hooked up.
Jan 05, 2010 | JVC KD-R600 Car CD/ MP3 Player
I can't figure out how to adjust the bass on the JVC KD-HDR30.
Hello hawk713, Like with many other JVC receivers, adjusting the bass is done from the "EQ" (equalizer) mode for one or all of 6 presets: ROCK, CLASSIC, JAZZ, HIP HOP, POPS, and USER. To adjust it, select the desired preset mode, use the left/right rocker (on volume control) to scroll to the desired frequency, 60, 150, 400, 1K, 2.4K, 6K, and 15K, and then turn the volume control up/down to set a level from -5 to +5. 60 and 150 adjusts the bass, 400, 1K, and 2.4K adjusts the midrange, and 6K and 15K adjusts the treble. Then you select whichever EQ setting sounds best with the particular music you're playing. Hope this helps.
Jun 06, 2009 | JVC KD-HDR30 CD Player
Car Audio & Video Logo
57 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
