Question about LG LFX25971SW Bottom Freezer French Door Refrigerator
Reset switch for ice maker - LG LFX25971SW Bottom Freezer French Door Refrigerator
The Ice maker is not making ice. The water is on is there a reset button?
No Reset call the manafacture or go the Store where you bought it and get an Exchange sound like its defective
Mar 06, 2017 | Refrigerators
Power surge caused appliance to go out. refrigerator ice maker now not making ice. has water on but no ice help
Reset the ice maker:
Locate the switch next to the water filter status light.
Press the light switch five times in 10 seconds or less.
Wait for the status light to change from red to green.
Mar 02, 2015 | Whirlpool Refrigerators
Ice maker not working. Have replaced the Ice Maker and still not working. Is there a fuse for the ice maker controller or reset button? I have the Whirlpool Conquest Gold Series between 8 and 10 years...
Roger... this is going to sound way to simple. The ice maker power is cut off by the door switch. Check the door switch. 1/2 of the switch powers the light and the other half powers the ice maker when the light is off. That stupid little door switch has tripped me up several times and I work on them!!! There is one locking tab on ONE side of the (usually white door switch to pop it out of the chassis. It will have 3 terminals on it. One is a common wire, one powers the light (door open / plunger extended) and the other one powers the ice maker (door closed / plunger depressed)
Don't buy a controller yet!!!!
Thanks for choosing FixYa.
Kelly
Nov 23, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I turned off my ice maker with the switch on the ice maker now it wont turn back on. Is there a reset or a way to reset the ice maker
How did you know it is not on? A single cycle for an ice maker takes some time to complete. They don't have reset buttons. You just lower the arm to turn it on and raise the arm to turn it off. The cycle goes like this. The tray is filled with water then as the water freeze it reaches a temperature that which triggers a sensor. Then a heating element melts the bottom of the ice then the mechanism rotates and dump the ice. Cycle starts again. This single cycle can take a few hours to complete. If the cycle is interrupted by turning off the water, it could take a while because the ice maker will go through the cycle regardless.
Jun 26, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
My ice maker is not working I can not hear the water going in is there a switch or reset button
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
kjg46890
Jun 22, 2010 | KitchenAid Superba Architect KSCS25INSS...
Hi, my model# is psi23scna. the whole unit
Check all your pin plug connections and then unplug the refrigerator for about 20 minutes with the ice maker turned off. Plug refrigerator back in and then switch the ice maker switch back on. This should reset board and ice maker which is also electronic. If this works let me know if not then tell me and i will send you the service manual. You either have a loose connection from board or a defective new board or electronic ice maker. Or just may need to have everything reset so they know they are connected to the new motherboard, Sea breeze
Feb 09, 2010 | GE Profile Arctica Stainless Steel Top...
Ice maker in Maytag French Door not working
replace the ice maker if the reset button has not done any good
Sep 16, 2009 | Maytag 25 Cu. Ft. French Door Bottom...
Ice maker very slow to make ice
there may be some thing stuck in the ice machine try checking it out
Jun 02, 2009 | LG LSC26905TT Side by Side Refrigerator
LG LFX25971SW Bottom Freezer French Door Refrigerator Logo
29 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
