Question about Maytag Neptune MAH9700 Front Load Washer
Error code OE does not finish whole cycle
I started to do a load of laundry, but ran into a problem.  As the load was beginning to finish with about ten minutes left an error code was flashing OE.  I do not know what that means and cannot seem to get my laundry done.
  • 2 more comments
  • teresac_acd Sep 11, 2008
    I seem to have the same problem and now my damn door wont open
  • maytagsux Apr 04, 2009
    OE Error Code: Faulty Water Sensor? Unplugged, turned off water/turned on water, still OE. Door won't open.  What a lemon!
  • iluvgr8danes Apr 13, 2009
    UM dont bother calling Maytag... They dont know what OE means and will just tell you to call a repair man... We have the same problem and we just turn off the washer and then turn it back on to Spin only then it drains and spins and is done... gets it done but its a pain. when we have money for repairs I guess we will call a repair man. The recall is for the electric board they say that the machine can leak onto the electric board and cause it to shock and then possibly cause a fire in your house. they said that they are going to send us a kit to make the outlet a GFCI outlet (OOOO, Im glad they are so helpful (NOT)
  • Anonymous Apr 18, 2009
    Maytagsux update.  OE all day Sat april 4, repairman showed up Monday the 6th and of course machine worked fine--Murphy's Law! $73 service call charge, but if it happened again in next 6 weeks would only have to pay for parts....gee thanks.  He just basically looked at my user manual and said IF he did come back he would just call Maytag.  OE error again following Sat. the 11th, made appt. for Tues. the 13th.  Happened to try again and it worked for some reason...cancelled Tues. appt.  Now same problem again tonight, april 17 but this time OE appeared almost right away as opposed to the rinse/spin cycles.   Have tried everything here except disconnecting and reconnecting water supply hoses.  Have turned them off and on a few times though.  According to manual OE is water sensor valve/pressure switch...dealer here says he has NEVER had to order one of those!   I've had the drain pump apart looking for obstructions, tested the hose for the pressure switch, unplugged everything, opened the door manually etc etc.  This was the first time I had to open it up and have a look at the inside of the machine, and was unimpressed to find as massive dent in the back of the machine where the water supply hoses connections are located.  This dent was conveniently hidden by the top cover of the machine, and would only be visible if you were looking at the machine from the rear or had the cover off.  When we called the store for service, noticed in the phone book ad that they sell scratched and dented appliances as well as "good" ones.  Nobody told us we were buying a dented model.  Frustrated and angry. Pulled out the other manual with the "warranty" in it tonight...1 yr parts/labor...had this set for just over 2 years
Just resolved same problem...it is the pressure switch aka water level sensor.  OE is overflow error.  Pressure switch is located under top cover on front right hand side.  It is round and has a rubber tube leading down to the drum and a electrical connection to the board.  Paid maytag man to diagnose/install cost me about $150
Posted on Apr 26, 2009
    Problem Solver:
  • 10 Answers
There has been a recall placed on your model of washer. It applies to ones with a serial number from 10188468GA through 11683946GJ. For mor info go to:
http://www.repairclinic.com/0098_11.asp
Posted on Oct 28, 2007
There is a recall on the circuit board for certain Maytag Neptune washers. See the link below:
Posted on Apr 07, 2010
I had to unplug my washer. Shut the water inlet, and then turn it back on and it worked fine. However the problem keeps repeating. At least you can finish the load.
Posted on Mar 03, 2008
Our Maytag Neptune Front load washer keeps displaying code 3E (NOT code E3). It will do so repeatedly until I give up for a day or so until forced to wash again at which time it work fine for 5 or 6 loads or go straight to 3E depending on which way the wind is blowing. Although my web research has found that this is a very common problem Maytag has been no help at all. The recall does not apply to this problem. I have called 3 different repair services reapeatedly and not a single one will call back. After 45 minutes of complaining to Maytag they said they would give me 20% off of a new model washer in their fine family of washers or 25% off of any parts. So far I've found others on web that had same problem & it was a circuit board that cost approx. $260.00 to repair. I'm at a loss as to whether to have machine repaired, have hubby look at it or beat it with a sledgehammer. Anyone have any luck with same problem?
Posted on Mar 03, 2010
Water not coming into tub just makes clicking sound and FH code
I think the solenoid operated inlet valve has failed, for which ever inlet is turned on. This is a very common fault.
May 11, 2015 | Washing Machines
Every other load we have OE coming up, also the drowm will not spin
LG washing machine error code - OE
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc
Nov 28, 2010 | LG WM2277H Front Load Washer
Wont finish the load
Here is a tip that I wrote about the LG OE Code and the causes and fixes...
Here also is the complete list of LG Codes
heatman101
Jul 21, 2010 | LG WM2701HV Washer
LG WM2277 "OE" ERROR. PLEASE HELP
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!!
Jan 12, 2010 | LG WM-2277HW Front Load Washer
Shows OE error. Won't spin
if its only 6ths old call out the manufactures.
Sep 28, 2009 | LG WM-2277HW Front Load Washer
Oe flashing does not spin
It's the pump motor - I pluged it into the machine and ran a test cycle (service manual link below) and there was the grinding noise. NOTE - I also tested the spin through the QC test mode (see pg 15 of manual) and that worked fine. BTW I pulled the pump out from under the washer instead of taking the whole thing apart much, much easier.
http://136.166.4.200/contents/Laundry/WM1832/WM1832xx_Service_Manual.pdf
Jan 14, 2009 | Washing Machines
Loud banging during spin cycle
please balance your washer and use smaller loads
Mar 18, 2008 | Kenmore 43052 Front Load Washer
Maytag Neptune MAH9700 Front Load Washer Logo
3,807 people viewed this question
Top Maytag Washing Machines Experts
Sheldon Dedek
John Tripp
John Tripp
Donni Steen
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
