Question about eMachines D3415 PC Desktop
PC wont start/boot
My pc wont boot or start, i turn the power on and the fans spin and the HDD and power indicator lights are NOT on. the screen is blank and there is no sign that the computer is doing anything.
I replaced the power supply from 300watts to 450. Before that ...it would not come on at all...but since the change, only the fans are working.
I appreciate any help/advise given!!
  • gogitojr May 15, 2009
    My PC stop working, I changed the power supply to a working 350 watt output unit. The internal motherboard green light now turns on, but no fans or beeps or LEDs on the "on/off switch come on. What could it be?
  • 20 Answers
Unplug all drive cables, backwards P-IDE can cause this issue.
If this doesn't help remove the video card if possible If the motherboard is alive you should get a video beep.
If you don't hear anything remove the ram, you should get a memory beep. If you don't get a memory beep it's either the motherboard or CPU.
You could try to clear the CMOS and if the system has a backup BIOS review the manual to boot with the emergency BIOS.
Posted on Jul 11, 2009
    Champion:
  • 381 Answers
Hello...i think you need to check all socket connection on the board and you need to check the memory or try to reset the Bios.or check the ATX power supply it is good or working..thank you
Posted on May 08, 2009
Acer am1100 won't start up
Discribe what happens when push the on/off button and you try to boot, fan spin? LED's blink? HDD/DVD light blink? Sound? Any thing on screen at boot? What blue light?
Feb 26, 2013 | Acer Aspire AM1100-B1410A Refurbished AMD...
Acer Aspire 5542 wont startup
Bring it to a repair shop and have them check it out. They should at the very least be able to recover you data.
Jun 29, 2012 | Acer aspire 5542 1615
Wont boot
In that case, looks like you have a faulty motherboard (video chip) chip-set. Remove motherboard from the casing and apply thermal paste. Also clean-up the whole board. I hope this will help you.
machinetosh of (tipidpc.com) site
look for kuya boy laptop
Global PC Laptop Professional Services
09126888500
Apr 01, 2010 | Toshiba Satellite 1905-S303 Notebook
PC start up failer
  1. remove the two rear screws and remove all the cards attached to the main board
  2. unplug all the cables that connect from the drives to the board.
  3. power on the unit
  4. if the unit powers up, install one of the cards you removed and complete step 3
  5. if the system does not power up, the last card or device activated will be your culprit and will need to be replaced or left out.
if you find that your system will not show a bios splash screen with all the other components removed, then you are looking at either a video, or power supply failure. Listen to your system for spinning fans and hdd activity. touch the hdd if you cant hear it when you power up the system, paying close attention to when the drive activates. It should activate almost immediatley, pause, and then run for a short boot period. if nothing, then if may be your power supply. you will not be able to see any lights at all, no light on the motherboard, drives, or power LED is the best indicator of a shot power supply
Good luck, please rate this post
Mar 23, 2010 | Acer Aspire E500 PC Desktop
When pluged into outlet fans spins and doesnt stop, wont boot
Fan spinning hard is usually a CPU issue.
If you've made any hardware changes to your computer, undo them. This happened to me when I was trying to upgrade my Processor (CPU) and I had the wrong kind.
Mar 09, 2010 | HP Pavilion m7560n PC Desktop
Toshiba M305D S4830 laptop wont start
"I have M305D S4830 laptop. I put it to sleep in the night. In the morning when i tried to turn it on, it wouldnt start. The light on the switch turns on and it charges the battery fine, but no HDD activity(but it does spin up and stay), no screen, nothing. The fan turns on and then turns off in 1 sec and then just the power indicator lights stay on... i also checked cmos battery, removed it and put it back.its voltage is also fine..."
Hello PPL! Maybe this WILL HELP you! I HAD absolutely the same problem >> 3 months of god **** stress, didn't find any solution, till one day i found on my Recovery CDs one note!! >> It sounds like:
"BEFORE pressing power button, HOLD 'C' button and while Holding 'C' button push POWER Button ONCE!! to start Laptop, KEEP Holding 'C' button!!! untill appears TOSHIBA screen!" then release 'C'. After that, it will appear "Operating System not Found">>then just do a restart by pushing Power Button and Start again! For me, It Worked!! and i'm god **** happy now)...let me know if it Helped you, Good Luck!
Feb 04, 2010 | Toshiba Satellite Laptop with AMD Turion...
My hp dv9000 will not boot. when power is turned on all leds light up screen stays black. hard drive and fan can not be heard. restarts after 10 seconds with no error message or flashing lights.
Remove the hdd cover from the bottom and make sure it is completely seated and connected. If the hdd is properly installed and it still will not boot, try entering the CMOS Setup. If you can enter setup you most likely have a bad hdd. If you can't you need to take or send the pc to a repair shop.
Oct 06, 2009 | HP Pavilion dv9000z Notebook
Hp Pavillion Tx1320us..wont boot up
You're probably one of thousands of victims of defective nvidia chipsets in these systems. Call HP and complain.
Jun 08, 2009 | HP Pavilion TX1320US Tablet PC
Compaq Presario Wont Boot
Hi, my name is ArmyMason, hate to tell you this, but it sounds as if you have a bad Processor. Did you recently experience a bad storm with lightning? Was their a lot of dust on the fan? Lightning could have struck the computer and killed the processor or excessive overheating of the processor could have also been the case. If it was a lightning strike I would contact the insurance agency and have them replace your computer. Reason I think its the processor is because you don't recieve any post and the fan spins for a second and then shuts off.
Feb 23, 2009 | Compaq Presario SR1030NX (DW256A#ABA) PC...
PC wont Boot/start
The first thing you should do is swap the power supply for a known good one,
If this is a new build that hasn't worked from the start follow the instructions here:
http://forum.pcmech.com/showthread.php?t=132409
Aug 27, 2008 | Computers & Internet
eMachines D3415 PC Desktop Logo
274 people viewed this question
Top eMachines Computers & Internet Experts
brian soufane
Avishek Samaddar
Avishek Samaddar
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
