Question about Bissell Steam Shot, Model 39N7-1
Steamer will not spray when I press button - Bissell Steam Shot, Model 39N7-1
Shark Super Steamer
The steam generator is defective.
Aug 28, 2016 | Euro-Pro Shark Super Steamer
When you push the start button the oven shots off
PDF]Convotherm by Cleveland Service Manual.pdf
manuals.therrconline.com/.../Cleveland/convotherm%20by%20cleveland...
Cleveland Range, LLC ... After the first signal (do not press Start/Stop) open door and spray the oven ... After the next signal, switch the combi steamer off and thoroughly wash out the oven ... Service Handbook OEB/OES/OGB/OGS ..... steam injection (controlled via the bypass probe) is depressed until the Crisp & Tasty.
Sep 08, 2015 | Cleveland Range Cleveland OGS-10.20...
Wiring diagram for wagner 905 steamer
Wagner Power Steamer 905 Manuals
www.manualslib.com > Brands > Wagner Manuals > Steam Cleaner
Wagner Power Steamer 905 Pdf User Manuals. View online or download Wagner Power Steamer 905 Owner's Manual.
Aug 29, 2015 | Wagner Spray Tech Wagner Power Steamer 905
I " inherited" this iron without a manual. How do I retract the cord on my cordless iron? It refers to a button but I can't locate it.
I never saw an iron with a retractable cord . The cover would have to be large enough to accomodate the cord and the heat from the iron could melt the cord. Are you sure it supposed to work like that?
Sep 24, 2013 | Panasonic Appliances Steam Iron with Spray
Shark handheld steamer heats up but does not spray
Try rinsing it out with CLR, it gets rid of calcium, lime and rust deposits i heard its very good.
Jul 10, 2009 | Euro-Pro Ultra Steam SharkTM II Hard...
Scunci steam cleaner not spraying steam
Unscrew the screw on the handle and remove handle. Remove rubber where top screws on. Remove two screws and the top and now unscrew the black pipe where the steam comes out. Now remove the button and see the small metal protrusion on the pot where the button was. Hit it with a hammer a few times softly to remove the scale buildup until the metal starts moving in and out again. I also sprayed it with a little silicone spray. Now put everything back together again. My steamer now works beautifully again!
May 24, 2008 | Scunci 52067 Handheld Steam Vacuum
Briel espresso machine
Try opening the frothing valve by turning the dial and force water through it instead of steam by pressing the middle, coffee button. You may be experiencing vapor lock. Once the water comes through the steamer valve, turn the steamer knob off and release the coffee button. Then try the steamer button with the steamer dial open. This may do the trick.
Dec 02, 2007 | Briel Domus Due Espresso Machine & Coffee...
Heats up and produces steam but the release button does not open the flow of steam.
To remedy this, I did the following:
1) Removed screws from: a) Lower area of handle (1 screw), b) Top of steamer, under round rubber flap around fill hole (2 screws), c) Front of steamer where nozzles attach (2 screws)
2) Removed back of handle, top of steamer, front of steamer where nozzles attach
3) Once all parts are removed, you can see a brass button that is pushed by the trigger
4) Using a needle-nose pliers, grasp and rotate the button several times in both directions (you may hear it cranking against the interior spring). Do this until it turns fairly easily with the pliers.
5) Once this is done, you fill find that the brass button can be very slightly depressed with a bit of force. You may also need/want to unfold a large paper clip to push into the nozzle hole to help unsticking the brass button (not sure if that helped in my case, but it was something I tried along the way). When the brass button moves in and out (again, it won't move much), the steam release mechanism is unstuck!
6) Reassemble all parts (everything snaps back neatly into place).
This worked for my unit!
Nov 11, 2007 | Scunci 52067 Handheld Steam Vacuum
Bissell Steam Shot, Model 39N7-1 Logo
Top Bissell Heating & Cooling Experts
Lawrence Oravetz
Tom Chichester
Are you a Bissell Heating and Cooling Expert? Answer questions, earn points and help others
