Question about Sony MHC-GX555 Mini Hi-Fi System Shelf System
LG FA 162 doesnt power on.
Mini Hi Fi LG FA 162, doesnt power on and has te IC STR-A6252 blown up. What can cause this IC to blow? many thanks
    Problem Solver:
  • 20 Answers
Dry electrolitic condensator on main power unit or short circuit on speaker cables
Posted on Dec 12, 2013
2 Suggested Answers
welcomejee
  • 10594 Answers
SOURCE: I need a owners manual for a Sony Mini Hi-Fi
Click Sony Support to download user manual of MHC-GX250
Thanks.
Posted on Nov 25, 2009
Need to know which optocoupler ic is used in str 6267 based power supply in sony trintron crt tv
Sony FD Trinitron WEGA... Repair Questions - Fixya
www.fixya.com/.../p228979-sony_fd_trinitron_wega_kv_36fv310_36_t...
Hello, i have a sony FD Trinitron WEGA #KV-36FV310 ... Need to know whichoptocoupler ic is used in str 6267 based power supply in sony trintron crt tv.
Sony KV-TG21M61 21" TV Repair Questions,... - Fixya
www.fixya.com > Forum > Standard (CRT) Televisions > Sony
Need to know which optocoupler ic is used in str 6267 based power supply in ... My sony crt Tv totally dead when touch any components and the IC strs6307 ...
Tv code hi i'm looking for a 3 diget programming code for my ...
Dec 21, 2015 | Sony Televison & Video
What would cause new fuse to blow when powering on (Sony STR-DN1030 Receiver).
Look in the circuit board area where the power cord mates with it for capacitors that have bulging tops (instead of the flat tops that are normal). If you see even one, you need to replace all the large capacitors othe power supply section (normally around 5 or 6).
Dec 08, 2014 | Sony STR-DN1030 7.2-Ch. Wi-Fi Network A/V...
Sc403.i replace ic sla6024 on motor but?
Look at your blown fuse FU5
• Main motor/drive malfunction
• Transfer belt contact clutch defective
• Transfer belt position sensor
defective
• Harness disconnected
Jun 30, 2011 | Ricoh Aficio 1035 Copier
I have a s1500 samson amp I keep blowing speakers, what can I do to prevent this from happing again? The speakers that blown first was two 12'' yorkville 350 w impedance 8 ohm, the next speakers that blown...
Turn the volume down? Feed it cleaner source material?
http://s3.amazonaws.com/samsontech/related_docs/s1500_s2000_manual.pdf
You don't say under what conditions you're blowing them or if any of the informative indicators are warning you of impending doom. The Samson is capable of cooking just about any home speaker.
The following conditions will cause the Protection LED to go on:
Initial power-up: For approximately five seconds after initial power-up, the
protection circuitry is activated and the speaker output is muted. If everything is
operating normally, you will hear an audible click at the conclusion of this brief
period, as the protection circuitry is deactivated and the S1500 / S2000 begins
delivering signal to connected speakers (at which point you'll hear a click). It is
normal for the Protection LED to fade gradually after the amplifier is powered off.
Overheating: A temperature sensing device in the S1500 / S2000 will cause
the protection circuitry to be activated (and the Protection LED to go on)
whenever the operating temperature of the unit rises above a safe level. To
guard against this problem, make sure the S1500 / S2000 receives adequate
ventilation on all sides and that both the front and rear panels are unobstructed.
Severe overcurrent conditions: This occurs whenever the signal being input to
the S1500 / S2000 rises to a level above 20% THD (Total Harmonic Distortion).
Shorted speaker cables: This will occur if, due to faulty wiring, the hot and
ground signals being output by the S1500 / S2000 short one another.
Output impedance drops below 2 ohms: This can occur if the S1500 / S2000
is connected to inappropriate speaker systems (see the "Setting Up and Using
Your S1500 / S2000" section on page 5 in this manual for more information).
DC voltage detected at speaker output: The most likely cause of this is an
internal failure.
In general, any time the Protection LED lights up (other than during the
approximately five seconds following initial power-up), there is reason to be
concerned. If this occurs, turn the S1500 / S2000 off immediately and carefully
check all wiring and external devices in order to locate and correct the condition
that caused the LED to light up in the first place.
For further assistance, contact your local Samson dealer. If purchased in the
United States, you can call Samson Technical Support (1-800-372-6766)
between 9 AM and 5 PM EST.
Feb 07, 2011 | Crown XTi 2000 2-Channel Amplifier
No Display, no sound- not working, showing dead. But input Power is ok. Picture tube filamment not getting power. model sony KV-2192M3
Hello
Check the input fuse first. If it is blown, there will be some short inside the power regulator circuit. Usually Sony sets uses STR regulated power supply. You can see this STR, and Ic, screwed onto a heatsink. Replace it with a same type and number. Before replacing the STR, check the diodes used in that section for damage, mainlu zener diodes. They might get shorted along the blowing of the STR. Check that section throughly before resoldering the new STR.
If any further assistance you needs, get me through Fixya. Ok.
Nov 27, 2010 | Sony FD Trinitron WEGA KV-21CL10 21" TV
How can I unlock my LG FB 162 mini home theater?
hi, am having problem with my LG mini home theater sound, pls help me with the unlocking code, fmtech 83 @yahoo.com.
Aug 10, 2010 | LG DU-27FB32C TV
Sony MHC-GX555 Mini Hi-Fi System Shelf System Logo
118 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
