Question about Estate ETW4300TQ Dryer
Where is thermal fuse on estate dryer - Estate ETW4300TQ Dryer
  • 39 Answers
You give model for a WASHING MACH.. Are you sure you're looking for a fuse?
Posted on Nov 28, 2013
Testimonial: "Well I know its a estate dryer. And it does not heat it just spins."
4 Suggested Answers
SOURCE: Estate gas dryer heats up but then flame goes out
It's likely the problem with the airflow. High limit thermostat is turning the gas valve off. Clean/replace the vent and lint trap.Check if there is anything stuck to the grille inside the dryer.
Posted on Oct 13, 2009
  • 949 Answers
SOURCE: My dryer will not come on period and The
The thermal fuse is located behind the back panel just to the left of the exhaust opening (looking from the back), it is white in color and has 2 wires (usually blue) going to it.
If you dryer comes on sometimes I would suspect this is not the problem.
The symptoms you describe most often are a loose wire or a bad motor.
Posted on Apr 24, 2010
jsrock516
  • 5911 Answers
SOURCE: my dryer is an estate whirlpool dryer does not
I'm assuming from the symptoms you posted, that the dryer does run, correct? If so, the fuse box may have checked out, but have you also checked for the correct voltage at the wall receptacle? A dryer will still run, but will not heat, if its missing a portion of the input voltage. The reason is that the drive motor only uses 120VAC to run, while the heating circuits need the full 240VAC service. If you are missing one leg of the input voltage, the dryer will exhibit the symptoms you describe. In addition, depending on when your home was built, some houses use two separate breakers that feed the 240VAC source the dryer needs to run. Have you checked to make sure there isn't more than one breaker that feeds the dryer? If you have checked for the correct voltage, have you also checked the continuity of the power cord to the terminal block? A broken power cord can give the same symptoms.
If the model number is correct, this is a very simple dryer to work on. There are no other switches or relays, other than the door switch and the built in centrifugal switch inside the drive motor. If the door switch were bad the dryer would not run at all. If the centrifugal switch in the motor were bad, the dryer may or may not run (depending on how it is faulted), which may give you the symptoms you describe.
When you checked the components, how did you determine they were good? If you need assistance (just to clarify your measurments), the following two links can give you some tips on how to troubleshoot this problem:
http://www.fixya.com/support/r3576548-dryer_runs_but_does_not_heat
http://www.fixya.com/support/r3574266-thorough_dryer_advice
I hope I'm not insulting your itelligence. I ask these simple questions, because they are things that can easily be overlooked. If you need further assistance, please post back and elaborate a bit more on your symptoms, so i can provide you with a more definitive answer. I hope this information was helpful to you.
Posted on Jun 30, 2010
Amana dryer model YNED7200TW will not start. there is power, but start button does nothing. Resetting breaker did not work. Any ideas?
Thermal Fuse
Item #2986 (OEM Part)
$10.70
Thermal fuse. If the dryer overheats, this device stops the flow of electricity to the heat source and/or the entire dryer. It is located on the blower housing and cannot be reset. The most common cause for overheating is a vent tube clogged with lint, a birds nest or other debris.
Manufacturer Number 3392519
More
  • Admiral Dryer Thermal Fuse
  • Amana Dryer Thermal Fuse
  • Crosley Dryer Thermal Fuse
  • Estate Dryer Thermal Fuse
  • Kenmore Dryer Thermal Fuse
  • Kenmore Refrigerator Thermal Fuse
  • Kenmore Washer/Dryer Combo Thermal Fuse
  • KitchenAid Dryer Thermal Fuse
  • KitchenAid Washer/Dryer Combo Thermal Fuse
  • Magic Chef Dryer Thermal Fuse
  • Maytag Dryer Thermal Fuse
  • Roper Dryer Thermal Fuse
  • Roper Washer/Dryer Combo Thermal Fuse
  • Whirlpool Dryer Thermal Fuse
  • Whirlpool Washer/Dryer Combo Thermal Fuse
In Stock
Quantity: http://www.repairclinic.com/PartDetail/Thermal-Fuse/3392519/2986#repairHelpVideoTabs
Jun 08, 2011 | Amana Dryers
Estate Dryer eed4300tqr the dryer does not heat at all during it 's heating cycle and how do I repair it.
This is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. seth765.jpgseth765_0.jpg
check the continuity on all these thermal fuse and the element replace the one that has no continuty
Jan 18, 2011 | Estate EED4100SQ Electric Dryer
The dryer runs but there is no heat coming out of it
lllThis is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. This is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. seth765.jpgseth765_0.jpg
Jan 18, 2011 | Maytag Atlantis MDG6400AW Gas Dryer
Apr 24, 2010 | Estate TEDS740JQ Electric Dryer
Replaced the coil and still not heating up on my estate dryer
The thermal fuse (aka thermal limit switch) is probably blown. It is not a good idea to bypass this fuse -- if the dryer overheats, it will not cut off the heating element -- fire is likely in that scenario. If you want to troubleshoot the problem, let me know,
Charlie
Sep 26, 2009 | Estate TEDX640JQ Electric Dryer
ESTATE DRYER NOT HEATING
Check for a blown thermal fuse. It's about an inch long and is inside the rear of the dryer, usually attached to or near the exhaust duct. It can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity means a blown thermal fuse. The filter being full of lint has most likely caused the fuse to blow, Sorry for your trouble and I hope this helped. Best wishes.
Sep 14, 2009 | Estate TEDS740JQ Electric Dryer
Dryer won't stop
your blower wheel is either real dirty or your outlet is clogged up causing the thermal to trip.
Jan 11, 2009 | Estate TEDS840JQ Electric Dryer
Location of thermal fuse on whirlpool estate gas dryer
if this is a gas dryer and the ignitor is working the thermal fuse is fine.need more info .dose the valve coils make any clicking noisecheck with ohm meter to see if coils open/also is gas on
Dec 31, 2008 | Dryers
Estate dryer won't come on..
check the white thermal fuse on the blower housing
Apr 26, 2008 | Estate EED4300SQ Dryer
Estate ETW4300TQ Dryer Logo
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
