I haven't used the admin section of my copier (lanier LD345c) in 4 years and can't remember the user name and password we moved buildings and I got it stuck on the log in screen
Typically... admin is the user name and there is no password.
-b
Posted on Feb 22, 2011
How can i rest a password on my truvision dvr30
The TVR 30 is shipped with one predefined user for the system administrator and
seven predefined standard users. The default system administrator logon uses admin
as the account name with a default password of 1234. You can modify the admin
password but not the admin user name. The seven predefined standard users are
labeled User1 to User7 with a default password of 4321 and level 4 access. The
administrator can customize the seven standard users and define their privileges.
Use the Users screen (shown in Figure 20 below) to manage users.
Note: When accessing the main menu for the first time, the system lets you pick
either an admin user or a regular user (User 4) by default. If you select User 4, enter
the initial default password of 4321.
Dec 28, 2014 | GE TRUVISION DVR 30 8CH 2TB
Default password for Lanier LD118d PCL
user is: admin
password is: password
for new model password is empty
Feb 06, 2013 | Lanier LD115 118 118D Toner 9 000 Yield
How do u delete names that have been stored in copier that r not being used for scanning
Open Internet explorer type the machine IP press enter then you will get the web page select user control it wll prompt for user name and password select admin and admin as username and password, if it is not entering try admin and Sharp respectively as username and password. then you can delete the user from there.
Apr 26, 2011 | Sharp AR-M277 Black and White Copier
Can't remember password.
Press a restart button at the back of your router, hold it like that for 20 seconds, then go on your local web adres (LAN web adress example 192.168.1.1) and use one of those 3 combinations:
user name: admin
password: blank(empty!)
user name: admin
password: root
user name: admin
password: admin
please rate my solution! :) thx
Apr 13, 2011 | D-Link Wireless N 150 Home Router 4Port...
Can't remember user name and password
If you can't remember the user name and password of your router the only way you can correct this is to reset it by doing this following procedure.
To reset the router using a pen or paper clip press and hold the reset button of the router for 15 seconds while power is ON and then after that power off and power on the router and it will be back to its default settings with default user name and password of the router which is admin and you just need to reconfigure the router for internet connections.
Jan 06, 2011 | Linksys WRT150N Wireless N Router -...
User manual for a Lanier Copier LD430c specifically instructions to program fax numbers.
Enter the IP address of the copier in the address bar on your browser(to see the copier's web page). You should see a log in button, admin is name and password is left blank. Address book should now appear on left side of screen, click it and add or edit addresses now.
Jun 09, 2010 | Office Equipment & Supplies
I forgot my password ??
you can find it by going into the administrator/router configuration web page and under the wireless section you may be able to find it!
the config page is usually found by typing in your internet browser 192.160.0.1 then press enter, then when asked to enter user name and password, leave user name blank and password enter "admin"
if you can't access the configuration page because you also set a different password or user name that you can't remember the only option is to reset the unit to defaults pressing for 30 secs a reset button usually found on the back of your router while your router is powered.
some new linksys routers I have encounter may require a pin instead of a password, the pin is found on the bottom of the router, try that too.
I strongly suggest that if you have technical questions that you review the manual for your unit that can be found here on the download section and come back if you have further questions after reading the manual
Apr 19, 2010 | Linksys WRT160N Wireless Router
LANIER COLOR COPIER MODEL LD345c Funtional Problem SC541
sc541 means no warm up, press the clear modees the punch in107 then press and hold down the clear stop key untilk it goes into sevice mode then shut main power
Apr 07, 2010 | Lanier 1205 Copier
I can not remember my password so i can use my wi fi. So how do i reset my password. i can log on to the router can i change it in the settings?
Reset
Pressing the Reset button for 5 seconds restores the router to its original factory default settings.
Log in to the Router
This section will explain how to log in to your router using the following steps:
1. Launch your web browser.
2. Enter the URL http://192.168.1.1 in the address bar and press Enter.
A login screen like the one below will be displayed after you connect to the user interface.
Note: There are three account types, each requiring a different username and password.
• The user account provides limited access to certain configurations (username / password: user / user).
• The admin account can perform all functions
(username / password: admin / admin).
• The support account is for ISP technicians for maintenance purposes
(username / password: support / support).
Note: Passwords can be changed at any time.
3. Enter your user name and password, and then click OK to display the user interface.
Note: This manual has been prepared using the admin user name
Aug 20, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
I bought Xerox Workcenter Pro 123 a year ago. One month later had a stroke and cannot remeber admin user ID or password. How can I reset?
Go to Xerox.com. Click on the Support and driver section.
Type in 123 in the search box. Then when it comes up, select Drivers and Downloads, then on that site you can click on Documentation and download the User and Admin Guides. That way you can have that info at your fingertip.
The default code is 1111, or 11111. 4 or 5 ones.
May 02, 2009 | Xerox Office Equipment & Supplies
421 people viewed this question
jasbo
jasbo
