Question about Sony MHC-GX555 Mini Hi-Fi System Shelf System
Ic str A6252 - Sony MHC-GX555 Mini Hi-Fi System Shelf System
Need to know which optocoupler ic is used in str 6267 based power supply in sony trintron crt tv
Sony FD Trinitron WEGA... Repair Questions - Fixya
www.fixya.com/.../p228979-sony_fd_trinitron_wega_kv_36fv310_36_t...
Hello, i have a sony FD Trinitron WEGA #KV-36FV310 ... Need to know whichoptocoupler ic is used in str 6267 based power supply in sony trintron crt tv.
Sony KV-TG21M61 21" TV Repair Questions,... - Fixya
www.fixya.com > Forum > Standard (CRT) Televisions > Sony
Need to know which optocoupler ic is used in str 6267 based power supply in ... My sony crt Tv totally dead when touch any components and the IC strs6307 ...
Tv code hi i'm looking for a 3 diget programming code for my ...
Dec 21, 2015 | Sony Televison & Video
Hi! i have sanyo televesion, model ts21sf1k. the problem is no power. i replace the power ic regulator STR w6753. but still no power. no voltage out in power supply.
SMPS circuit is not functioning. Check and replace all the associated component to STR. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jun 24, 2015 | Sanyo Televison & Video
LG FA 162 doesnt power on.
Dry electrolitic condensator on main power unit or short circuit on speaker cables
Nov 27, 2013 | Sony MHC-GX555 Mini Hi-Fi System Shelf...
VOLTAGE DROP AFTER STR.MAIN FILTER NOT DISCHARGE AND FUSE GONE EVERY TIME. I CHANGE STR & SUPPLY IC.
connect a series lamp for sefty to the monitor. start to disconnect the component from fuse ,line filter, bridge rectifier, filter capacitor, check the voltage at ic 12v also check pulse at str if not then check ic resistors capacitors,and replace if found faulty
Mar 23, 2011 | Samsung SyncMaster 1100P 21" CRT Monitor
Hi, I have a sony STR-DE675.; the audio cuts out between stereo and mono, as if something inside is heating up.I have cleaned all connections and carefully vacumed out any dust from inside the unit.The...
STR is a very sensitive ic module of the audio system and it always has a tendancy to heat up quickly and has some basic precautions to be maintained for operating this. correct speakers should have been connected so on..
if you are technically very confident open up your system try to locate the str ic unit check whether the contacts of the heat sync (aluminium metal chunk screwed with the ic to absorb the heat) has been correctly fixed. (pls note- manufacturers will always have appropriately heat synced it try to use it in a cooler place)
Feb 01, 2011 | Sony STR-DE675 Receiver
Sony STR-DG600 ticking sound defect bug. There
Replace the IC 1101 with Part No. 6-806-144-01. This Ic will have updated software on board to fix the problem.
Mar 27, 2010 | Sony STR-DE597 Receiver
Sony receiver STR-DE345 OVERHEATED how do i fix it ??????
these do run hot, they don't have a fan so they need good ventalation. If your has completely failed you may be able to resolder the voltage str and stk voltage driver Ic's or replace them.
Jul 16, 2009 | Sony STR-DE345 Receiver
Sony str-DE435 Flash Protector
this is not a reset problem, you have a defective audio output, is either the outputs transistors or the drivers IC's ( integrated circuit) and sometimes if you are lucky is just loose connections on the drivers IC;s.
good luck
Jun 18, 2009 | Sony STR-DE435 Receiver
Sony MHC-GX555 Mini Hi-Fi System Shelf System Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
