Question about Dell adamo xps 13.4" dual core ultra lightweight laptop
New dell battery will not communicate with computer
Just purchased a new battery from Dell for Adamo XPS laptop and I get flashing orange lights and a message saying the battery can't communicate with computer
  • 1,511 Answers
That means it can't charge the battery.
Posted on Aug 24, 2014
Dell adamo 13 Laptop is dead and not powering on
I would verify you are getting the right voltage out of your AC adaptor with a meter. I believe it should be 15vdc. If you are not getting the correct voltage buy a new one off eBay and charge your battery.
If you are getting the right voltage but the unit doesn't power up, remove the battery and check its condition with a meter. If the battery is bad, you may be able to run the laptop with the AC adaptor only.
http://news.cnet.com/2300-17938_105-10000721-1.html Take look inside the Dell Adamo Photos Cracking open the Dell Adamo
Jan 14, 2014 | Dell adamo 13 (dacwaq1_1) PC Notebook
My dell adamo xps won't turn on.
Hello There!
A lot things may be the cause:
these are hingt to try, and check!
be safe first!
1) May be power supply defective
2) may be bad RAM
3) may be, bad caps, in your mobo or PSU.
good luck!
Carl
Jan 09, 2012 | Dell Adamo XPS Laptop with Intel Core 2...
Adamo xps is frozen after it boots windows so I can't put my password in. Ctr Alt Delete doesn't work either so it seems that my keyboard is not working. What do I do?
on the pc using safe mode(press F8 when starting) you can access through administrator account and then go to control panel>useraccounts>desired account> remove password and so you can remove the password
Aug 20, 2010 | Dell Adamo XPS Laptop with Intel Core 2...
My battery has been out for a year and I use my lap top with the charger only . The laptop holds no charge and it flashes orange. Has this hurt my computer? I have a xps m1210. A suggestions for a battery...
No your PC is not hurt. The problem is that you motherboard is having problems reconizing the charger. I recomend calling Dell Costomer Service and telling them you problem and have them replace the motherboard and or battery.
Jul 09, 2010 | Dell XPS M1210 Notebook
Dell XPS M1330 battery not detected!
Normally the life time of a laptop battery is 300 cycles. that is 300 discharges and charges. Since your laptop is almost 2 years old, the battery could be at the end of its life time, and again depends on how often you use your laptop in a day. Better goto a service center or get a similar battery from any of your friends just to make sure it is not a motherboard issue. Then you can think about which part you've to replace.
Please come back and rate my solution if it turns to be helpful fro you, or also if you need more clarifications. Thnx
Apr 01, 2010 | Dell XPS M1330 Notebook
I have a Dell XPS M1210 laptop for which I have just purchased a new 9-cell compatible battery. It worked great for a couple of hours, but now shuts off immediately when unplugged from the AC power supply....
You might want to try what I did when I had a completely discharged battery for my Dell Laptop. I attached the battery to the computer, make sure the computer is off and plug in the charger for a full twenty four hours (undisturbed). And this really worked. I had no problems with the battery. Good luck.
Feb 26, 2010 | Dell XPS M1210 Notebook
Continuous alternating one green and three flashing red battery
note.gif NOTE: Battery operating time (the time the battery can hold a charge) decreases over time. Depending on how often the battery is used and the conditions under which it is used, you may need to purchase a new battery during the life of your computer. Check the battery status light — If the battery status light flashes orange or is a steady orange the battery charge is low or depleted. Connect the computer to an electrical outlet.
If the battery status light flashes green and orange, the battery is too hot to charge. Shut down the computer, disconnect the computer from the electrical outlet, and then let the battery and computer cool to room temperature.
If the battery status light rapidly flashes orange, the battery may be defective. Contact Dell _I found this on : http://support.dell.com/support/edocs/systems/latd820/en/ug/index.htm Hope this helps and good luck. if i "fixed ya" please rate me. thanks-jmattes
Oct 22, 2009 | Dell Latitude D820 Notebook
Battery Light Flashes Orange and Green
I have had three different laptops, last one an XPS from DELL which did the same thing. Replacing the battery solved all three laptops. How old is the battery you have in there now?
Jun 02, 2009 | Dell Inspiron 6000 Notebook
Laptop battery charge indicator flashing amber and green
If the battery is hot from being used in your computer or being in a hot environment, the battery may not charge when you connect the computer to an electrical outlet.The battery is too hot to start charging if the batter15.jpg light flashes alternately orange and green. Disconnect the computer from the electrical outlet and allow the computer and the battery to cool to room temperature. Then connect the computer to an electrical outlet to continue charging the battery.
Regards..
Apr 14, 2009 | Dell XPS M1710 2.33GHz Core 2 DUO T7600...
Dell Inspiron 5160 flashing orange / green power LED
If your Dell notebook battery flashes four orange one green, there might be a problem with your battery.The battery life is also shorten and doesn’t last longer than an hour.gets hot sometimes.
pls see this if it helps
http://www.wareprise.com/2007/07/05/dell-notebook-battery-flashes-four-orange-one-green/
This is directly from the User Manual:
If the computer is connected to an electrical outlet, the Battery light operates as follows:
• Solid green: The battery is charging.
• Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the light operates as follows:
• Off: The battery is adequately charged (or the computer is turned off).
• Flashing orange: The battery charge is low.
• Solid orange: The battery charge is critically low.
pls do rate me FIXYA if i helped u
Nov 29, 2008 | Dell Inspiron 5160 Notebook
Dell adamo xps 13.4" dual core ultra lightweight laptop Logo
90 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
