Question about Toshiba 42HL67 42 in. LCD Television
How to disassemble the front panel on a Regaza 42hl67
Think it has dirt on the back of the glass
    Master:
  • Toshiba Master
  • 687 Answers
Recommend having a professional attempt this
Posted on Nov 30, 2013
Kenmore stove
Condensation streaks on an oven door window can be between multiple glass panels such that it is necessary to disassemble the door to clean.
Oct 30, 2013 | Kenmore Kitchen Ranges
Removal and disassembly of oven door
The panels on the door , specially the glass panels can be removed easily if care is taken to remove the fitting screws.
You can use a good cleaner glass cleaner to remove any dirt that has deposited on the frame and glass panels.
Once the glass is dry it can be refitted , care taken to use gloves so as to avoid hand impressions .
Dec 06, 2011 | Fisher and Paykel Ovens
Hitachi 55" plasma Director's Series
Replacing the front glass entails completely disassembling the entire TV. Your best bet is to look for a broken TV with a good front glass.
May 28, 2017 | Hitachi 55HDX62 55 in. Plasma HDTV
Is it possible to clean the inner side of the glass front screen from my panansonic TH42-PZ80
Anything is possible! It would be a lot of work because you have to totally disassemble the tv to get it broken down far enough to do that - and also make sure you dont break either of the glass when disassembling or reassembling.
thanks,
Michael
Apr 05, 2011 | Panasonic Viera TH-50PX80U Plasma TV
42hl67
Lcd logic drive board or a bad display panel. A scope is the best way to diagnose that problem.
Oct 14, 2009 | Toshiba 42HL67 42 in. LCD Television
My son threw a ball and hit the screen cracks all over can this be fixed with a new screen or is it junk now really bright light shows through all the crack marks
The front glass is just a protector for the LCD screen. If your TV turns on and the picture looks ok (may be a little color variation around the crack if front glass is pushing on it, variation OK black Bad) If the picture looks within the range described then replace the glass. It is just a piece of standard glass and a pretty easy diy job. If the LCD screen is broken the repair will be more than the replacement cost. Sad fact US TV repairmen make a living wage while the workers that assembled you TV wouldn't be able to buy lunch here with what they made putting it together.
Jun 02, 2009 | Toshiba 42HL67 42 in. LCD Television
Replace a window regulator in a 1994 ford explorer
wow, a lot of work to do.
Window Regulator, Front Door, Explorer Removal
srk~us~en~file=ani_caut.gif~gen~ref.gif WARNING: IF THE REGULATOR COUNTERBALANCE SPRING MUST BE REMOVED OR REPLACED FOR ANY REASON, MAKE SURE THAT THE REGULATOR ARMS ARE IN A FIXED POSITION PRIOR TO REMOVAL TO PREVENT POSSIBLE INJURY DURING C-SPRING UNWIND.
  1. Remove front door trim panel and front door trim shield . Refer to Section 01-05B .
  1. Remove inside door belt weatherstrip and glass stabilizer.
  1. Remove front door window glass as described in this section.
  1. Remove two nut and washer assemblies attaching the equalizer bracket.
  1. Remove three rivets (manual) or four rivets (power) attaching the regulator base plate to front door trim panel finish panel (23712) .
  1. Remove window regulator electric drive and front door window channel bracket from vehicle.
  1. Working on a bench, carefully bend tab flat to remove arm slides from front door window channel bracket .
  1. Install new window regulator electric drive arm plastic guides into front door window channel bracket and bend tab back to 90 degrees. Use care not to break tab; if tab is cracked or broken, replace front door window channel bracket . Make sure rubber bumper is installed properly on new front door window channel bracket , if replacement is made.
Installation
NOTE: The front door window channel bracket and window regulator electric drive are installed into the vehicle as one assembly. The front door window channel bracket may be disassembled from the window regulator electric drive as described in Steps 7 and 8 of Window Regulator, Removal.
  1. Install front door trim panel finish panel with preassembled glass bracket into vehicle. Set the regulator base plate to window regulator electric drive using base plate locator tab as a guide.
  1. Install three (manual) or four (power) rivets (385189-S100) to attach regulator to front door trim panel finish panel . Two 1/4-20 x 1-inch bolts and two 1/4-20 nut and washer assemblies may be used as alternates for glass retention. However, torque must not exceed 4-7 Nm (3-5 ft-lb). Equivalent metric retainers may be used.
  1. Install equalizer bracket.
  1. Install inside door belt weatherstrip and glass stabilizer.
  1. Lower regulator arms to access holes in front door trim panel finish panel . Install front door window glass as outlined.
  1. Adjust glass to ensure proper alignment with glass run. Cycle glass for smooth operation.
  1. Install front door trim panel and front door trim shield . Refer to Section 01-05B .
Apr 11, 2009 | 1994 Ford Explorer Limited
Cleaning Inside Glass Oven Door of KitchenAid KEMC308KSSO
To dismantle the kitchenaid pro line oven door: there is a lever over the hinges that attach a door to the oven. The lever is right on top of the hinge. Pull the lever up. When that lever is in the up position, you can pull the door out.
Jan 10, 2008 | KitchenAid Architect Series KEMC308KSS...
Dirt and grease between glass in oven door
My husband cleaned this today!! Yahoo--I had over sprayed the glass cleaner and it ran in the vents.
If you pull out the drawer on the bottom, and look up you will find that the glass is being held in at the bottom by a "clamp" & 3 screws, one on each end and in the middle.
After you remove these, the glass front will come off, and you will see the inner door. There is another piece of glass that I cleaned, and now it looks 100 % better. Of course, the door comes apart easier than it goes back together, we had a little trouble lining up the screws. Don;t push the glass on too tight, the screw holes lined up better when there was a little space.
Dec 04, 2007 | Kitchen Ranges
Toshiba 42HL67 42 in. LCD Television Logo
50 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
