Magnavox 55P8288A
Dull to light picture, attempts to adjust "no joy", request a link or source for service man/pdf...? something with flow charts or schematics or both would be extremely helpful...Thanks in Advance bshot
4 Suggested Answers
Slinteriors
  • 8617 Answers
SOURCE: Bad Picture on a Projection TV Magnavox 55P8288A magnavox
Change the coolant inside the CRT this will restore the color and clarity to 100% on your set.
Posted on May 25, 2008
Ecollier2012
  • 3459 Answers
SOURCE: Philips Magnavox 55P8288A Green tinge over entire picture
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Apr 11, 2009
rulds2008
  • 3866 Answers
SOURCE: Magnavox 55P8288A Picture is cloudy
You can purchase a factory one from www.remotes.com. and for you manual you can download it here just click on get manual http://www.retrevo.com/s/Philips-50ML8105D-TVs-review-manual/id/277ag615/t/1-2/
I sure do hope this helps you and thanks for using fixya.com
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on May 24, 2009
Bad dull color on a magnavox 55p8288a... how do I change the coolant in this tv
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 31, 2011 | Philips Magnavox 51MP392H Rear Projection...
Model number#55P8288A Phillips Magnavox(PVT910)We have no owners manual.And the picture is too orange.where can we get a manual to set it right
http://www.tvrepairkits.com/download-guides/tv-kit-001-002.pdf
www.scribd.com/.../Philips-DPTV400-TV-Projection-Training-Manual
www.scribd.com/.../Philips-Training-Manual-TV-Plasma-Display-Panel-Chasis-FTV1-9 -
Service & Repair manuals for your unit.
Sounds like your set has developed a "Color Mixing" problem, Please use the troubleshooting procedures and you will soon be able to find out what to do.
Apr 29, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Philips 55P8288A tv has a dull color and a red hue.
This sounds Like the the coolant for your piture tube has become cloudy and needs replacement (usually blue or green tube - thats why the image seems ovrely red).It's a big job (labour wise) since completee dissassembly is required ($200-300). It can be done youreself - check out TVrepairkits.com to get the coolant and instructions.
You can confirm that this is the problem by dissassembling the unit to the point where you can view the face of the CRT's (red green and blue) directly.
Nov 28, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
We have a Magnavox Model 55P8288A Projection tv and it is showing a cloudy and light picture.. Try to adjust color and it won't adjust...It shows a foggy picture...
Replace the CRT coolant. You can get the phillips CRT coolant replacement kit at the following link. The kit contains the coolant and the CD with instructions.
http://servicemanuals.vstore.ca/
Sep 22, 2009 | Televison & Video
Need owners manual for Magnavox 55" Projection TV 55P8288A, pleas
This manual does not seem to be available anywhere. I looked for it on the Magnavox website http://www.magnavox.com and it was not available. You can call the magnavox customer support at this telephone number. 1-800-705-2000. Give them the model number of you television and ask them for their help getting a copy of the owners manual. I also check for it on a google search. The search turn up no source either. So you best bet is to try and find another person who has the same model television and ask them to make a copy for you. You can do this on this website by looking up the people who have asked for help with the same model television and leaving them a message that you need a copy of the owners manual.You can also go to other help websites and ask for their help in getting a copy of the owners manual. I hope this information helps you with your problem
Jun 02, 2009 | Philips Magnavox 27MS343S 27" TV
May 24, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Toshiba 50H82 Wavy Lines - Jittery Picture.
Dont have the manual - sorry - but this is the most likely cause.
Projection TV sets have two very common problems listed below.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 11, 2008 | Toshiba 50H82 50" Rear Projection...
Viewing problems
Projection sets have two very common problems.
The first common problem is convergence
*Screen Looks 3-D
*Colors wont align
Nov 01, 2008 | Samsung HCL5515W 55" Rear Projection...
May 25, 2008 | Philips Magnavox 51MP392H Rear Projection...
Dim picture
If decide to do yourself, ya only have to do the green and blue ones, the red light spectrum won't allow fungal growth. Pull whole CRT assembly out to prevent spilled/leaking glycol from onto lower main boards
Sep 04, 2007 | Philips Magnavox 51MP392H Rear Projection...
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
