Question about Apple iPhone 5
Rpaced screen iphone 5 mic doese not work
Mic after screen
  • 3 Answers
Didn't seen iPhone 5 inside, however in my 3gs, which I changed screen 8 times it happened often that ear dynamic didn't worked, because of not very good spare screen, I always used my original ear dynamic, which I had to detach every time from the broken screen assembly and reattach to the new screen. Else - you should recheck if every cable was firmly reconnected back after repair procedure.
Posted on Nov 28, 2013
How to remove scratches from iPhone screen?
its not recondmended its a screen /lens not like regular glass where you can buff out fine scratch with toothpaste the following links show how to remove scuffs or very very fine scratches but on some creens trying to remove a scratch may cause malufunctions
I5 Phone Screen Scratch Remover Yahoo Video Search Results http://mashable.com/2014/06/28/phone-screen-scratches/#8C596Bi36aqt How To Clean and Remove Scratches on the iPhone 5 5S 6 6 Plus
Aug 11, 2016 | Apple iPhone 6
IPhone mic doesn't work in Notes app
Is this the Notes app that came with the phone, or one you installed?
Sep 03, 2014 | Apple iPhone 5
Iphone 5 mic not working
This is a common problem and will need to be taken to the at&t or apple store nearest you.
Nov 27, 2013 | Apple iPhone 5
Mic not working
You may have to return your iphone to your store if the mic really does not work. But first try completely turning off your iPhone. Hold down the top button until "slide to power off" comes on... Then slide to off. Once completely off, wait a minute and click the upper right button to turn on again.
Many times "things" don't work because you have too many apps open atone time... So close the apps you are not using. To see what apps that are open, double click the button at the bottom of your screen quickly... Make sure that your first icon page is showing when you do this...By double clicking you will then see at the bottom of the page a single row of all apps that are running... You can then press on the app icon(s) that are open for a second or so.... And "x" will appear. Touch the "x" to turn off the app... NOTE: Make sure that you only do this on the highlighted bottom row...
Oct 14, 2013 | Cell Phones
When I hold my new iPhone 5 with my left hand, the caller says my voice is muffled. Not so if holding phone on right side.
This is because the mic is located on the left side (phone facing toward you) as you switch hands the mic is moved further from your mouth.
Dec 22, 2012 | Apple iPhone 5
Pair visor go bluetooth with iPhone 3GS
iPhone 3 GS, This should be able to help you: http://www.lcd-screen-digitizer.com/iphone/iphone-3gs-usb-port-flex-+mic+ringer-speaker+antenna-us.html
Sep 27, 2012 | Supertooth One Bluetooth Visor...
How can i increase volume for mic iphone 3gs or input volume during calls..they cant hear me clearly..thats my phone problem..iphone 3gs..
Hello
1 .You need to confirm if its the volume or the mic of your phone that has the problem.
2 .If its the mic,your callers would not hear you but you would be able to hear them.
3. You can Adjust the volume of your iPhone by depressing the volume button on the left edge of the phone, close to the top. This will cause a volume indicator to appear, superimposed over the other icons on your screen. This will increase the volume of your ringer. If you wish to adjust the volume of the phone speaker, use this button during a live phone call. You can also control the volume of your speaker when you are using your iPhone as a music player in the same manner.
4. If its the mic,remove the iPhone from the case, as your case may be blocking the device's microphone.
5. Plug the iPhone device cable into the iPhone and into the computer's USB port.
6.Launch iTunes. Click "iPhone" or the device's name in the sidebar in iTunes and click "Summary then Click "Check for Update" and "Download and Install" to update your iPhone's OS.
7. Remove the device cable after the update finishes and insert your headphone jack into the iPhone's headphones port,tap "Phone" on the home screen, tap "Contacts" and tap a contact to place a call.
8. Press the "+" button on the microphone to increase your microphone's volume.
9. If the problem persists take your iPhone to your local Apple Store for professional service.
BEST OF LUCK
Dec 15, 2010 | Cell Phones
Iphone 3g has lost sound, mic, home button and charger port broke
check if any flex strip are hanging loose. and push them in their respective slots.
May 01, 2010 | Apple iPhone 3G Black Smartphone
IPhone - mice not working
hiiii sir plz give me solution my iphone mic is not working ,voice is incoming but my voice is not going
Apr 15, 2008 | Apple iPhone Smartphone
Microphone isn't working with the computer.
1-select start2-select contrrol panel3-select sound speech and audio devices4-select sound and audio devices.5-confirm that mute box not signed.6-pres advanced in mic volume confirm mute box not signed7-select audio you will see capture screen in mic volume sign select.8-in default device press volume you will see volume control screen in mic volume confirm that mute box not signed
Mar 02, 2008 | Philips PH62080 Uni-Directional Microphone...
Apple iPhone 5 Logo
42 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
