Question about Radio Communications
Noise Problem During Receive
I have an FT-840 with a receive problem. During receive, there is a static/clicking noise that sounds very similer to electrical noise. I've ruled out actual electrical noise as the problem is happening no matter where the radio is located. This noise seems to be in the front end, as it appears to be affecting the AGC as well. Any suggestions? Thanks, 73! Bob, KD5MHQ
  • 24 Answers
Bad grounds reset all pcb screws
Posted on Jul 14, 2009
Yaesu ft-857 squelch problem
Your RF gain control needs to be turned all the way up to be able to receive signals and if you are on one of the HF bands like 40 meters or any HF band the squelch control needs to be all the way off! You do not use squelch on HF! When on VHF or UHF then you would rotate the squelch control just to the point that the background noise stops and go no further. Higher squelch settings will only block weak signals and your radio will be deaf! Squelch control rotated just to the point the background noise stops! NO SQUELCH ON HF. Turn the squelch all the way off on HF!
Feb 01, 2017 | Yaesu Radio Communications
The only way I can receive is to have static all the time, how can I receive and transmit without static
has to do with the electrons in the air waves . Have you noticed that when you are near businesses with flourecent lights you pick up a lot of static? A traffic light may change and the electrical impulses from the change can be heard in your radio.It could also be the vehicle you are driving .Are you using a cigarette lighter plug which will give you static also . Do you have a noise blanker switch on the radio ? if yes make sure it is on and an A N L switch ,make sure it is on .
May 15, 2015 | Radio Communications
Flashing display ft 840
Radio needs service, flashing display means the PLL is out of lock
Mar 20, 2014 | Yaesu FT-840 Owners Manual
RE : Panasonic KX-TG6461 I installed this phone
thats an hardware fail , you need a service shop to fix it
Sep 13, 2013 | Panasonic KX-TG6461ET DECT Corded and...
Clicking/Static Noises
If you unplug the chat-controller cable from your headset and controller, does the click/static noise go away? If yes, then you need a new chat-controller cable. Email support@turtlebeach.com for that. ------- If the noise remains even after you've disconnected the chat cable, then the problem is likely due to the presence of too many other Radio Frequency wireless devices competing with the X31 transmit/receive, especially if you have an 802.11n ("N") router made before Oct 2009. If that's the case, you should definitely contact Turtle Beach at support@turtlebeach.com and ask them for help with this.
Feb 02, 2010 | Voyetra Turtle Beach Ear Force X3 Wireless...
Crackle/static during audio playback.
hi,
download Realtek high definition sound manager software, this will filter your noise and give u a good result.. all the best..
thanks
ehsanullah. md_ehsan_1@yahoo.co.in
Jun 16, 2009 | Edirol UA-25 External Sound System
I can fax out but I can't receive faxes.
What happens if you dial your fax number the way you make a normal voice call? Does the fax machine pick the line up? Can you hear it making electronic noises? Do you hear any static or line noise?
Try also putting a regular phone on the fax line and attempt to make voice calls to test the lin quality. Listen for static, noise, volume issues. Report problems to your telecom company if you have trouble in voice calls.
May 06, 2009 | Office Equipment & Supplies
GALAXY 88 HIGHT STATIC IN THE RECEIVE ..
If the antenna for the other properly operating radio is used with the radio with the noise and you are getting the static then we can assume it is the radio. If you hear signals with the static, that is, it does receive communications at the same time, there may be a problem with the noise reduction circuitry, or a defective component(s) in the receiver. Without knowing your experience I would suggest taking to a radio shop.
Oct 10, 2008 | Galaxy Radios DX- 88HL Base CB Radio
Radio Communications Logo
220 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
