Question about Emerson MS3100 3-Disc CD Changer
Emerson 3 disc cd does not spin
None of the 3 disc drives will spin.
Cd will not eject. Keeps giving message "Now OPC" but will not do anything and will not eject cd either.
To remove a stuck CD from Tascam CC222 MKII
This solved the "Now OPC" problem
1. Unplug unit
2. Remove the top cover, (3 screws on each side and 3 on the back, lift cover).
3. Plug in unit.
4. Power on the unit to observe the drive spindle spinning clockwise, (1" disc on top of drive).
5. Turn off unit, do not unplug at this time.
6. Use a small screwdriver to prevent the drive spindle from spinning.
7. Power on the unit preventing the spin.
8. In approximately 10 seconds the display will read "Disc Error" and the CD tray will open.
9. Remove the screwdriver and the disc.
10. Turn off the unit and unplug.
11. Replace the cover.
12. Use a better quality disc.
Sep 23, 2010 | Tascam CC-222mkIII CD Player / Recorder
DISC WILL NOT SPIN PLAYSTATION 3 60GB
If another known working unit exhibits same propensity, then the issue is not with the drive but rather the electronics it is plugged into. See if there is a factory reset for your PS3. Otherwise you are SOL.
Sep 03, 2017 | Sony Playstation 3 (PS3) Console
Saying no rdy on cd player (Emerson)
make sure you have a cd and your tray spins when opened
Aug 11, 2009 | Emerson MS9700 CD Shelf System
Remote code for emerson 3cd player
I& do I need it to change c.d.s there a remote that comes with the Emerson mS31OO
Jun 03, 2009 | Emerson MS3100 3-Disc CD Changer
How to download music to my emerson mp3 player
first, install the software. if a disc comes with it, put that in before you connect it. if it dont have a disc, it will install when its connected. a window called "Autoplay" should come up. go to Open Folder To View Files and go to your My Music folder. drag all the music you want to the mp3 player's folder. hope this helped
Feb 17, 2009 | Emerson BAR900 MP3 Player
TOC READ
I have the same problem... Any solutions?
Sep 21, 2008 | Emerson MS3100 3-Disc CD Changer
CD's won't play
I know that Panasonic provides chips, optics (laser),etc. to Emerson. I am familiar with the problem you've experienced because I've had a Panasonic CD Player. If the disc doesn't spin (as you said), the problem must be that your shelf system probably has an optical problem (laser problem/pickup problem) and will need to be serviced.
Apr 22, 2007 | Emerson MS3103 Shelf System
Emerson MS3100 3-Disc CD Changer Logo
Top Emerson Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
