Question about Microsoft Xbox 360 Console
My xbox 360 doesn't want to play any 360 games but it plays xbox games.
I played my 360 for about 1 day and I turned it off, then i tried to turn it back on so I can play halo 3 but it didn't want to read the disc.I tried xbox games and it worked but it still doesn't want to read 360 games....what should I do?
Take it back to where you bought it and ask for a new one or try troubleshooting number is found on back of instruction manual
Posted on Oct 19, 2007
    Scholar:
  • 110 Answers
Take a look at this:
http://support.microsoft.com/kb/909819/en-us
Also call 1800-4my-xbox and talk with them, you may can get the xbox360 replaced for a new one.
Also check these recent problems on xbox.com:
http://www.xbox.com/en-US/support/?WT.svl=nav
Good luck,
Cam
Posted on Oct 18, 2007
SOURCE:
SOURCE: XBox 360 Elite
Buy a new Xbox 360
Posted on Oct 17, 2007
SOURCE: Xbox 360 disc drive
if it isnt the magnet issue (hitachi drive only) then the solution is the drive isnt spinning the disc, in which case open the console, open the drive top, and hand spin your disc on the spindle for about a minute or so, make sure you push the laser block to the back of the drive, and when you power it up it should spin.
Posted on Dec 01, 2007
  • 142 Answers
SOURCE: my xbox 360 wont read any disc
Call 1-800-4MY-XBOX and they will solve your problem.
Posted on Feb 03, 2009
  • 19 Answers
SOURCE: 360 reads game discs but it won't play game and it says play DVD
The problem is that the laser is either dying out, is dirty, or is not getting enough power.
so try to fix it using these steps...
- first open the 360 and pull out the dvd drive and open it up too.
- clean everything out good with compressed air, and q-tips dipped in alcohol.
- now you need to adjust the power going to the laser.Sometimes you may have to try multiple settings before getting it justright. Just keep adjusting the resistance lower and lower until itworks.
- if you tried multiple settings and still get the errors, then either get a replacement drive, or a new laser for it. Click Here for how to properly install the new laser.
- if you get a replacement drive, please not that there is a key in the pcb of the drive that must match the key from the motherboard, so you must either spoof firmware with the key, or swap out the old pcb board and put it in to the new drive.
If you need more dvd drive repair help click here
Posted on Mar 06, 2009
sharkymo
  • 95 Answers
SOURCE: Xbox 360 won't read a certain game
If you have the original X box CD's it will work fine expect when you have issues with region code.PAL NTSC are the two format a game can work with.so if you have NTSC formated game TRY a PAL version.it may work.
else clean your lens and try inserting a new CD of that GAME.
Posted on Jun 12, 2009
Why does it keep shutting down after 5 min of playing a game?
Xbox Keeps Turning Off - Xbox 360 S - iFixit
https://www.ifixit.com/Answers/View/.../Xbox+Keeps+Turning+Off
iFixitI put up with it turning off of a couple of weeks and then the power cord blew up ... The slim edition of the classic Xbox 360 with a 250GB HDD and built-in Wi-Fi. ... After your description, I am starting to think that your power brick is the problem. .... in i cant donothing about if i was trying to play my gta4 in keep cutting off in 1 ...
Does Your Xbox 360 Keep Freezing? ' MyGamerXP
www.mygamerxp.com/xbox/does-your-xbox-360-keep-freezing/
Sep 14, 2015 - 5. Check Your Xbox 360 Hard Drive. Not only can the cache corrupt from .... I unplugged the console when it froze instead of turning the power off. ... hi my 360 keeps on freezing on any game i play and like the screen frezzes but .... It willnot, even after 6 goes, play, it freezes, and after about 2 mins, it ejects.
My 250GB Slim keeps turning itself off every 5 - 10 minutes ...
forums.xbox.com/xbox_support/f/7/t/156970.aspx
Xbox
Jan 17, 2016 | Video Game Consoles & Games
Xbox360 wont play origanal xbox games
Some XBox games have both a 360 and original XBox version, so you can't play them on the 360. Other games simply aren't compatible. Your game may fall into one of those two groups.
Apr 22, 2014 | Microsoft Xbox 360 Console
My Halo 3 disc is scratched, i have tried all the tricks and it still wont work, i need some help
If this ever happens to you I recommend going to Blockbuster or something and renting a copy of the scratched up game for one day After you have done this follow these steps. 1. Insert the disk, make sure it is readable i.e. playable 2. In the My Xbox section of the Xbox Dashboard scroll all the way to the left until you have the option "play game" now press Y 3. When you press Y you will enter the game details section, scroll down to the Install Game option. 4. Wait a while for the game to install (this will take up some drive space but it shouldn't be too horrible) 5. after the game is installed you Xbox will use the downloaded files to play the game. Insert your original scratched up disk and try to play it. You should be good to go from there. 6. If this still doesn't work your disk is beyond repair
Jul 05, 2011 | Microsoft Halo 3 for Xbox 360
Xbox 360 wont play any disk keeps saying no disk
Try cleaning the disk, if that doesn't work, try another disk, if that doesn't work, then turn the xbox off, take the hard drive out, put it back in, then try playing the game again.
May 28, 2011 | Sony Video Game Consoles & Games
My 360 only plays cds or dvd s wont play games please advise
Step 1: Inspect and clean your disc Take a close look at the bottom side of your game, movie, or music disc (the side without a label or image). Are there scratches? Excessive scratches or smudges can prevent your console from reading the disc. Clean your disc 1. Hold the disc by the edges without touching the top or bottom surfaces. 2. Using a soft, clean, slightly damp cloth, lightly wipe from the center of the disc outward. Note Do not use solvents to clean the disc. 3. Once the disc is clean, load the disc into your console and see if the disc plays. If the disc still does not play, try step 2. Step 2: Try other discs Try other discs to determine whether the problem happens with any disc or only with this particular disc. If multiple game discs, DVDs, or CDs will not play: 1. Make sure the media type and the disc region code are compatible with the console. 2. If the problem happens with several discs of different types (games, DVDs, and CDs), skip to “Step 7: Request a repair” below. If a specific game disc will not play: 1. Search the Microsoft Knowledge Base to determine if the game title has any known problems. 2. Make sure the media type and the disc region code are compatible with the console. If the disc you are using has a region code that is compatible with your console but you still cannot play the disc, try step 3. Step 3: Clear your system cache If your Xbox 360 console can’t play multiple game discs, try clearing your system cache. Here’s how: 1. On the console, go to My Xbox, and then select System Settings. 2. Select Memory. 3. Highlight any storage device, and then press Y on your controller. 4. Select Clear System Cache.
Note If Clear System Cache is not available, use the button sequence described in the following article: 971755 How to clear the Xbox 360 console cache 5. Try to play a game disc. If you still can’t play a game disc, try step 4. Step 4: Remove the hard drive If the problem only happens with game discs, let’s try temporarily removing your hard drive. If your Xbox 360 console does not have a hard drive, skip to step 5. 1. Turn off your console. 2. Locate the hard drive on your console. 3. Press the release button on the hard drive and lift the hard drive from the console. 4. Turn on your console. 5. Try to play a game disc.If this step resolves the problem, reattach the hard drive and contact Xbox support to order a replacement hard drive. If this step resolves the problem, reattach the hard drive and contact Xbox support to order a replacement hard drive. If you still can’t play game discs, try step 5. Step 5: Disconnect memory units 1. Turn off your console. 2. Unplug any memory units attached to your console. 3. Turn on your console. 4. Try playing a game. If this step resolves the problem, reattach the memory units and contact Xbox support to order a replacement memory unit.
Feb 15, 2010 | Microsoft Xbox 360 Console
I can playing a game on my xbox 360 and all of a
This is unfortunately a common problem with the console, you are eventually going to just get the three red lights and the unit will be dead. Call Microsoft now to get them to replace the unit. You can call them at 1-800-4-My-Xbox
Thanks
Aug 23, 2009 | Microsoft Xbox 360 Console
Xbox asking for update. wont install update! CANT PLAY HELP!!!
as i tell everyone with this problem with other games too go buy a new concolse if that helps i hope it does
Jan 15, 2009 | Microsoft Xbox 360 Console
Xbox 360 quit playing the new 360 games
I would take it back for a new one...
Halo 3 is notorious for overheating the console...
check out www.360problems.com
Dec 26, 2007 | Microsoft Xbox 360 Console
is this limited addition halo 3?
get a new one or find a place where you can get it fixed but there are not alot of places to get it fixed.im sorry im the barer of bad news.
Dec 04, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
438 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Ekse
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
