Question about Toshiba Televison & Video
Toshiba TV 24V4210U remote doesn't work
Hey, I buy this tv 6month ago and today my remote control stop working. I change the batteries and nothing happen. It's look like no signal between the tv and the remote. If someone can help me I really appreciate
    Top Expert:
  • Toshiba Master
  • 74,383 Answers
If it is an original remote control to this TV, it should work even after replacing the batteries. If not works, check the battery contacts at its battery compartment for any rust or dust accumulated, which prevents proper contact to battery terminals. Clean the contacts well before inserting the batteries. If there is no such problem, check the infrared emission from the remote control. If you wish to get more details about how to check a remote control, check the site linked here. Pull up older posts.
If it is a universal remote control, as soon as you take out the batery from its compartment, all the settings will be lost. You should reset it with its setup codes. For more information http://electrohelponline.blogspot.com/Setup procedure, and setup code list to many popular remote controls are given.Pull up older posts.
Posted on Nov 28, 2013
SOURCE: bn59 00463 volume works nothing else cant turn on
Step 1: Remove the batteries
Step 2: Press the power button (red button) on the remote control 5 times.
Step 3: Replace the batteries and your remote should work fine.
Posted on Oct 27, 2009
fixyadude1
  • 57 Answers
SOURCE: RCA remote
Could it be possible that the remote needs reconfigured? If none of the buttons work, the it could possibly be that you need to re-enter the TV code back into the remote.
Posted on Sep 24, 2008
SOURCE: getting toshiba ct-852 to program
This remote is programed by holding the CODE button and pressing the electronic button that you want to be programed. (For example press and hold CODE and hit DVD.) After you do this you have 10 seconds to input the 2 digit program code for the electronic you want programed. If your manual doesn't have these codes you can This One on page 13.
Hope this helps
Posted on Feb 07, 2009
SOURCE: The Sony TV remote doesn't work (with good batteries).
NSE urc22b-12 please pin code forTV SONY model KV-A2921D
Posted on Sep 28, 2009
  • 1335 Answers
SOURCE: my samsung remote BN59-00852A just stopped
Try the instructions below. If you need to replace the remote, you can order one from:
http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=BN59-00852A&uuid=12967730823440
Before replacing the remote, try the following:
How to Re-Start Your "Dead" Remote Control This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls. Good Luck!
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
Step 5- Try the remote.
Special Note:
If you have a digital camera, camcorder or camera phone you can test the remote to see if it is emitting a signal. Face the remote towards the lens of the digital unit until you can see the front of the remote. Depress any button on the remote. You should see a light (steady, blink or flashing) being emitted from the remote. If you do then the problem might not be the remote but the sensor on the TV unit.
Let me know if you have further questions. Please make sure to rate this solution. Thanks.
Posted on Feb 03, 2011
Toshiba 24V4210U tv/dvd "incorrect disc"
Prob has some dust on the lazer if you have a cd player cleaner give that a shot or blow it out really good and give it a shot
Dec 14, 2013 | Televison & Video
The TV stopped responding to the remote control
tried with reset doesn't work, ok it could be the IR sensor at the front panel of the tv doesn't work. but before you replace it you need to ensure if your remote controller is working. have you tried to check the remote with camera trick just to know if the remote controller is sending light to the IR sensor of the tv.
Sep 23, 2012 | Advent LC-20H15A 20 in. EDTV-Ready LCD TV
The remote control stopped working on my toshiba flat screen i changed the batteries and only the volume works with the remote still can't turn on/off or change channels
Make sure the mode switch is set correctly for the device (TV, Cable, Video recorder, etc) that you are trying to control.
Apr 28, 2010 | Toshiba CZ36V61 TV
My remote control doesn't work. nothing happens when i use it
It can be a faulty infra-red receiver board, usually wont pick up signal from wide angle or distance. what is your tv?
Mar 18, 2009 | Televison & Video
Tv won't turn on
Buy a replacement remote - universal type to control everything except the toaster and kettle. Get your exact model number of tv and get a specific one from radioshack 15$
Aug 05, 2008 | Toshiba 32A33 32" TV
Remote problems
Try this website 1-800-Remotes factory original, buy an exact remote.
May 26, 2008 | Toshiba 20AF46 20" TV
Toshiba TV Remote Control not working
i have bought universal remote controls and they do not work. what can i do? i have bought rca universal philips universal remote,
Nov 17, 2007 | Toshiba 36HFX71 36" TV
I have been seeing a lot of Toshiba remote "eyes" (the infra-red receiver inside the TV) fail recently. If several known good remotes cannot control the TV then the IR receiver will have to be replaced. If you have no experience soldering and unsoldering PC boards then have a qualified tech handle it for you.
Jun 27, 2006 | Toshiba 32A30 32" TV
Televison & Video Logo
63 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
