Question about Hannspree XV37 HDTV 37 in. LCD TV
Dont know how to channel search with remote
I have a new antenna and im trying to find out how to do a channel search, the antenna instructions say "do a channel search". Thank you
    Problem Solver:
  • 3 Answers
Do these steps using the remote: Power TV on. Press Input button and < or > to be sure you're looking at TV and not HDMI1 or something. Press Menu button and > to the 4th (I think) menu, where top two items are: Tuner Mode and Auto Scan. You ought to be able to start an auto scan with those. It takes a while, maybe ten minutes to finish, so be patient.
Posted on Dec 31, 2009
  • ELIZABETH THOMAS Apr 23, 2013
    THANK YOU THANK YOU THANK YOU!!!! :) YOU'RE A LIFESAVER!!! <3
My Tv no longer registers a signal from the antenna. I can see a picture thruogh my smart DVR and Chromecast but no pic with TV antenna. I bought a new antenna, still no signal.
Is the TV set to air or cable? It has to be set to air/antenna and a channel search has to be done first before a picture will show.
Mar 07, 2016 | Zenith Z50P3 50 in. Plasma TV
I dont have a remote and im trying to set up a digital tv antenna but the only channels im getting is 3 and all the video inputs. How to i program channels
Usually channel 3 is picked up on a channel scan when there is an input device connected to the TV via a Coaxial Cable, thus using only channel 3 on the TV itself and using the Digital converter box to tune in the channels.
The TV will need to be Digital ready to connect only a Digital Antenna to it and programmed to receive the Digital Broadcasts over the air. If you are certain that this TV is Digital Ready (TV manufactured from 2009 to the present) you can use the menu button on the top, side, or front of the television, then use the channel / volume buttons to move around the menu, and the input button as the enter button.
You will want to select Antenna (ATSC) signal before starting the auto program so the TV will be able to recognize the Digital Channel Broadcasts.
Hope this helps!
Cheers,
Scott
Apr 12, 2015 | Televison & Video
My digital prism tv is saying no database? what can I do to fix this?
I have the same problem do a channel scan if it dont work i dont know im stuck on it
Apr 07, 2010 | Televison & Video
Im losing channels on my tv. because i cant do a channel search
It's only thru your remote. try fixing your remote control.
Take off the battery, open the back of your remote, lift the circuit board, clean the green painted part with cotton balls slightly damp with rubbing alcohol as well as the black thingy behind your remote pad, let it dry put it back together, replace with a new battery and try if it works.
Feb 23, 2010 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
VIORE PLC7V95 7'' portable TV, cant get channels when scan
I notice that on mine, the positioning of the included tv antenna is very, very, very finicky. I also don't know how to "add" a new channel other than to hook it to the big house antenna and pick "re-scan" (or auto-scan or whatever it's called).
So I think your best bet is to pick a better antenna or know that even the tiniest fiddling with the antenna makes a diff. Sometimes, I even have the antenna horizontal (using the magnet) to get the good reception on a given channel. Seems like a hassle except that what should I expect from a tiny antenna....
Jun 15, 2009 | Televison & Video
Goodmans GTV69RFDT Television had all freeview now only getting 3 channels
First ensure that the TV input is set on the Freeview channels, just in case.
Then check the antenna, when Freeview does not get all channels, it is always the aerial (antenna).
Many areas in UK have still poor reception. If you use an internal antenna, go to Argos or Currys and buy an amplified antenna for freeview, that will improve the signal.
Oct 15, 2008 | Goodmans W280NS Television
No signal
Hopefully, anyway.
I had a similar problem, and my solution was this: I pressed menu on my TV and using my universal remote, went into setup, and then channel search (or near to that), at which point it began searching for analog and digital channels. This can take up to approx. 30 minutes. I suggest you occupy yourself while waiting; it is a sluggish process.
If you want assurance, your TV will have the majority of analog channels (basic cable), and a couple digital. I am basing this wholly on my experience, however. Once finished, it should switch immediately so a channel. Mine was a weather station.
I hope this is successful in helping you and those in the future.
Sep 02, 2007 | Televison & Video
Going from antenna to cable off the remote
Can you tell me what the remote code is for this unit
Sep 29, 2006 | Symphonic SC3813 13 in. TV/VCR Combo
Remote not working correctly
It all depends on what and how the cable box is connected . Do you have an outside or inside antenna connected? If you have a cable box , why would you want to go to another station on your tv? Does the cable box have an rf output that connects to the tv through he antenna input on the back of the set? If so the tv should stay on a station to recive the stations thru the cable box. Didnt the cable tech explain how to use the system?? If you dont understand how to use the cable you should, for sure call the companey, and see if they can explain how they hooked up your sysytem as theres many many ways to do this. If you have the owners manual what im about to explain is in there too. On the tv remote theres a button called menu, press it once. Use the up and down arrows to scroon down and highlight the setup . press the ok or enter buttonpress the right language,then search for channels. When this is over then exit out of the menu, and try switching channels. If you still dont have any channels you gonna have to find out whats connected to your rf input as channels wont come in if theres not the right source connected. GOOD LUCK
Jun 18, 2006 | RCA G27303HP 27" TV
Channels only up to 20
unfortuatly not your gonna need to get an original remote from http://www.vcrremotecontrols.com and the part # for zenith is 924-10042 and cost 29.95 + shipping.good luck
Apr 12, 2006 | Zenith ALG4010 VHS VCR
Hannspree XV37 HDTV 37 in. LCD TV Logo
266 people viewed this question
Top Hannspree Televison & Video Experts
Are you a Hannspree Televison and Video Expert? Answer questions, earn points and help others
