Question about Dryers
Kenmore dryer 79690272900
Dryer does not work there is power to dryer,when i open door lite comes on but the digital display is comepletely blank
  • 39 Answers
This is too broad a question. Does the dryer light go out when you press the button? It should, but the switch could still be bad. Is the motor receiving power? If yes, replace the motor. Is the belt in place so that the belt switch is working? Test the belt-switch with meter. Lastly, is the main control (logic) board still functioning? Consider this last.
Posted on Nov 28, 2013
SOURCE: Dryer won't turn off when door is opened
The problem is the door switch. Order a new switch and replace the old one. Remove the front panel of the dryer and the switch is at the top of the opening held on by two screws and connected by two or three wires.
Posted on Mar 30, 2008
  • 4 Answers
SOURCE: Dryer will not turn on
If some parts of the dryer works and others don't, then a connection wire is either loose or damaged. You can look up the model of your dryer online and find a wiring guide. Then open up the dryer by taking the front (depending on model) and look for a loose wire or any damage. If the dryer has never worked before, then you may need to rewire the plug, for example, in some older houses the wiring is not grounded and the ground wire needs to be connected with the neutral in order to complete the circuit.
Posted on Apr 20, 2008
AlmostBob
  • 550 Answers
SOURCE: dryer stpped working
with power disconnected
if any wire disconnected before any test, reconnect & test dryer, reconnect wires after each test
disconnect wires from start button and test, conduct when pushed, no conduct when release
if fail replace start button test dryer
disconnect wires from door switch and test, conduct when pushed, no conduct when release
if fail replace door switch test dryer
follow leads from start button to relay(relay is first device connected to start button), and make sure all wires connected at both ends. If any wires disconnected, test dryer
locate thermostats and thermal fuses on fan housing and ducts
individually disconnect wires from each and test. conduct good, no conduct fail
replace any failed thermal fuse or thermostat test dryer
if all prior test OK
replace relay, test dryer
Posted on Oct 12, 2008
  • 1122 Answers
SOURCE: kenmore dryer series 70 won't turn on
most of the time it is the door switch that goes bad,also you can check the main fuse inside the dryer on the blower box,and always make sure your dryer vent and wall vent are clear to vent,let me know what you find-mike
Posted on Oct 29, 2008
  • 1122 Answers
SOURCE: dryer does not come on. Light comes on when dryer door is opened.
check the door switch-mike
Posted on May 29, 2009
Kenmore he5 dryer doesn't run, have power, door switch works, thermal fuse, have continuity?
What does the display say? Typically, these Kenmore dryers don't run because of a door latch error. We have had to have our door latch replace 3 times in 3 years. There is a lengthy trouble shooting program to bypass the latch error but it is time consuming.
Oct 15, 2014 | Kenmore Dryers
How do i open our kenmore 80 series gas dryer to check the pilot light, blower works but no heat
I always go comepletly over a dryer when it has a heating issue. Most of the time a gas dryer will get a airflow issue and melt the fuse. That fuse is here:
See that white skinny thing with 2 blue wires. It is right next to the control thermostat. That black stat judges drum temp and turns the gas assembly on and off. If the vent is blocked then the fuse melts and kills the power to the gas assembly. You will have no heat. Why did the fuse melt?
Ya gotta wash out the filter housing
The gas assembly has 3 basic components all wired together in a way that the whole shebang is safe to operate. Do you hear the normal clicking associated with the dryer heat? If you do then that means the ignitor is glowing and the flame sensor is working so the solenoids are bad. Sometimes it works sometimes it don't when these solenoids are going bad. Here is a video which shows how to get into the machine> Solenoid replacement
If yours has the filter inside the door then the fuse to check would be behind the filter housing
I have service manuals and videos posted on a FixYa tip I wrote about Kenmore dryers HERE
Oct 26, 2011 | Dryers
I have a Kenmore 500 series dryer. The dryer just stopped working but the light stays on when the door is closed.
the door switch is broke.when you push on the paddle of the door switch the lite should go out,if you don't see the paddle it most likely broke off,you need to send the full model number next time,it will start with 110.or similar.the door switch is a safety so the machine won't run until the door is closed,if the switch is broke no power will go to start the dryer
May 10, 2011 | Kenmore 500 6953 Dryer
Kenmore Elite Smartheat Quiet Pak 9 won't start. Light turns on and off inside drum when door opens/closes, but no lights come on on the outside display.
My Kenmore Elite dryer keeps beeping..just going through the end of cycle alarm-high,low,off...anyone have any suggestions?
May 30, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore dryer doesnt have power there is continuity to the timer and the switch
Is there power at the receptacle? The easy way to check this is to go to your electrical panel, turn off the 30 amp (2 - pole) circuit breaker, wait a few seconds and then turn it back on. If you have any lights, digital displays, etc. that indicate power being on to the dryer - then try going through your routine again for drying your clothes. If this doesn't do it, feel free to contact me again - and I'll help you with the next step. Sometimes the door latch can affect power. Meaning, if the door isn't shut all the way - it won't turn on. Now, if it is shut all the way and you know you have power to the machine, and it still won't work. A faulty door latch switch has been known to be the cause. Good Luck to you, and I hope the simple solution works for you. - Jim
Mar 29, 2010 | Kenmore 62882 Electric Dryer
Our Kenmore Elite HE4 gas dryer will not start although all controls on front are lite and appear to be functioning properly (settings can be changed, etc). I has been working fine for several hours until...
check the door switch and door latch. Open door, set the dryer to air fluff cycle, and manually depress the door switch. Press start button. If it started - door needs alignment to fix it.
If it did not start:
If your dryer has light inside - check if light turns off when you press the switch. If not - switch needs replacement.
If all that checks out ok - the problem is more serious, and you might need a tech to come out and diagnose it.
Mar 04, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore HE4 no power to control, no sound, but the drum light bulb on when door opened
Another post reported replacing the power cord. I am trying to determine if this is a factory defect. Check the power at the power cord connections inside the dryer. You could have lost power on one leg and the other 120 volt leg is letting the light work. Let me know what the model and serial number is.
InMrFixIt
Aug 15, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
50 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
