Question about Garden
Jobmate pressure washer motor won't start
It cut out when running and the person holding the nozzle shut it off while the engine was still running. It won't turn back on. It is a Jobmate electric, model 39-8677-2 purchased 2008 maybe? Is there a fuse?
Monster80
  • 460 Answers
SOURCE: pressure washer has no pressure
Try and back flush the washer..Take spay nozzle off washer and back flush with hose...If any kind of sand or deposits get into the Pump it will hold pressure valve open not letting it build pressure.after back flushing hook back up washer and before you put spar nozzle back on or start washer turn water on and make sure all air is out of washer..hook spray nozzle back up and hold it open with washer still off.when you see that there is no more air coming out of washer start it and you should have pressure.Hope this helps you and have a great day!!
Posted on Apr 05, 2009
Monster80
  • 460 Answers
SOURCE: When trigger is engaged under pressure nothing happens.
Make sure all of the water is bleed out of it buy holding trigger down with motor not running until theres is not more bubbles or air that comes out..Make sure where the inlet for waters screen is not plugged..You may have to back flush washer to clean out or to unstick the pressure valve..Hope this helps you and have a great day
Posted on Apr 06, 2009
  • 10 Answers
SOURCE: pressure washer stalls out when wand nozzle is released
common for not starting unless trigger engaged as you are turning the pump as well as engine creating pressure,as for stalling pump has unloader valve which is probably in need of grease(use good silicone grease)this allows water to ciculate when trigger released.
Posted on Apr 20, 2009
  • 156 Answers
SOURCE: Pressure Washer quit running
I have owned four of those units. Every one of them did what you are experiencing or just wouldn't give me any pressure after only a few uses. The company was certainly no help. I gave up after four and bought a heavier gas model from Lowes. Hope this info helps.
Posted on Jul 06, 2009
  • 9 Answers
SOURCE: I was using the pressure
Sounds like it could be your unloader. make sure you always have the water on while your motor is running.
Posted on Aug 10, 2011
1997 Delco Versa 4200, 220v pressure washer. Installed new pump, suntec shut off valve and wiring connector. Still no fuel to fuel nozzle.
you have a pressure washer that uses 220 volts but have a fuel nozzle
what is it a petrol engine or electric motor
be more specific as to make model year engine type etc in your next post as posts are not linked
Nov 18, 2016 | Garden
Water flows thru the pressure washer pump and out of wand, when I start the motor flow stops. I have a craftsman model # 580.752060 I've taken pump apart and there are no obstructions that I can...
Let the water run for a longer time. "Walk" the hoses, from the faucet to the pump and then to the nozzle, holding the hoses up to displace any trapped air in the lines through the pump and out the nozzle. What it sounds like is that air is reaching the pump. When it does, it cavitates, and no water can be pumped. Tighten all of your hose fittings securely. Try holding the trigger down while starting the washer. It may be easier with another person helping.
Best regards, --W/D--
Jul 08, 2011 | Craftsman 2500 PSI Briggs Stratton...
My Troy Built pressure washer shuts down when I turn on the water. Is the pressure cut off valve that might be frozen?
Hold the trigger of the pressure nozzle open. Turn on the water . Wait to see water coming out of the pressure wand.Then try and start the engine. They can get air locked.
Feb 12, 2010 | Karcher 2500 PSI Pressure Washer
Pressure Washer Engine will not stay running
My Kracher 2500 pressure washer has no pressure unless I remove the nozzle. If, I remove the nozzle and pump the trigger several times and quickly replace the nozzle it works fine until I release the trigger. Karcher (online) suggested I remove and clean the unloader which I did. It still doesn't work correctly. What another solution?
May 29, 2009 | Garden
No high preasure at nozzle
Try starting the washer up without a nozzle clicked in and purging water through the pump, shut it down and install the nozzle and restart, if the motor lugs then it is making pressure, if the pump squirts water out of the by-pass immediately and or constantly it may be a stuck bypass and not a bad pump.
May 26, 2009 | Psi 2500 Mobile Pressure Washer 5hp Honda...
Apr 06, 2009 | Garden
Pressure washer has no pressure
Apr 05, 2009 | Garden
Garden Logo
52 people viewed this question
Top Garden Experts
Jay Finke
Jay Finke
Dennis Key
Dennis Key
john h
