Question about Stanley Vacuums
Need the vacuum to blow out air - Stanley Vacuums
Eureka vacuum blowing dust into the air
Check the leak (where the dust come from); maybe you need to tighten or reseat one or more part in that area.
Feb 09, 2014 | Eureka AirSpeed One Turbo Bagless Upright...
Seems to **** up the dirt/dust and simply blow it out instead of capturing it inside
Most of these have an suction hose and a blow port. One blows air, one sucks air. Make sure the suction hose is on the correct port. Also, a dirty air filter will cause the same effects. The filter must be good to prevent the dirt and dust being blow around.
Nov 08, 2010 | Craftsman 17026 Wet/Dry Vacuum
Bissell proheat blowing out air instead of sucking in air
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
vm,v
Feb 16, 2009 | Bissell 1699 ProHeat Clear View Upright...
Husky 6 gallon dry/vac wont **** in air, only blows air out
Maybe you have the vac hose plugged into the blow out port.
Nov 16, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
My vacuum blows air instead of sucking air. I have a dirt devil swivel guide. I got something stuck in the brush spinner, got it out...but now the vacuum doesnt suck stuff up anymore.
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=571660
Generic problem for all Vacuums
Posted by katweaver3 on May 04, 2008
My vacuum blows air instead of sucking air. I have a dirt devil swivel guide. I got something stuck in the brush spinner, got it out...but now the vacuum doesn’t **** stuff up anymore.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Normally if your vacuum has a round belt you may have your belt on backwards, please reverse the belt and the suction will return also you may have a clog in the tube leading up to the bag or dirt cup would be anther reason for the blowing instead of suction. This is not covered under the factory warranty. Feel free to contact your local vacuum dealer for questions.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.royalvacuums.com
Customer Service
For help with a model that is not working, if you want to check an order, if you need help finding a part or service center or have any other comment, complaint or question that is not a technical question about this web site use the link above. You can also call our Customer Service department between 8AM and 7PM EST Monday through Friday at (800) 321-1134.
Thanks, Don – The Vac Man
Go Ahead. Use Us.
May 04, 2008 | Vacuums
Dysin vacuum blows air instead of sucking it!
If it is blowing air, then it is still clogged up somewhere, you didn't give your model number, but some of these have removable covers on each side and on the back. Also make sure that all covers are back on securely.
Jan 07, 2008 | Vacuums
Dysons aren't supposed to clog up, but they do. There a number of ports you can open to see if there are clogs in any of them. Usually a clog is why it will blow air and debris out instead of sucking. You just need to find it.
Jan 05, 2008 | Vacuums
Help needed pronto!!
Most vacuums are make to suck not blow. Except for the Rainbows or Rexair vacuums. They have a port for blowing air.
Oct 30, 2007 | Vacuums
HELP!!!!!
The hose is probably clogged. It is supposed to blow out at the filter. It filters the exhaust air so you don't get dust back into the air.
Oct 16, 2006 | Regina RG3100 Vacuum
Vacuums Logo
16 people viewed this question
Top Stanley Vacuums Experts
J.D. Browning
J.D. Browning
Tom Chichester
Are you a Stanley Vacuum Expert? Answer questions, earn points and help others
