Question about Senco & Frame Pro 601 Framing Nailer
Senco 601 plunger sticks when unplugging air line
Plunger stuck to top plastic part on head have to remove head and put it back in the cylender
    Sergeant:
  • 206 Answers
The piston stop in the head is supposed to grab and hold the piston - I don't believe that is your issue. The problem I think you are experiencing is the head valve not moving freely up and down. There is a funny looking spring under the head valve to push it back - often these get weak or broken causing the head valve to jam.http://senco.com/Documents/Guides/FP601_PC.pdf
Part # KB4393
I would purchase the repair kit #YK0360 which includes this spring - clean and lubricate the tool as you reassemble.
Posted on Jun 17, 2014
4 Suggested Answers
  • 142 Answers
SOURCE: Framepro 601. Works fine until air is disconnected
sounds like lack of lubrication. Lack of lubrication builds up crud inside. Take the 4 Cap screws off the top of the gun (pay attention to how stuff comes out or you screwed). Carefully, turn the gun over and let the piston fall out. Now you can wipe some of the gunk out of the cylinder. Put it all back together, put about 10 drops of pneumatic tool oil in the air input fitting and spray up the nose of the gun with WD40 or some type of dry lube.
This should take care of it
Posted on Jul 28, 2009
  • 142 Answers
SOURCE: Senco 601 nailer shoots 2 nails each time the trigger is pulled.
the 601 had a design flaw, in the nose, where the nails hit as the are being pushed forward, the peice was made out of a peice of metal that was too soft, it wore down and that is where you get the double nail problem.
Senco offered a trade in, this was years ago, for a limited time and gave us credit towards new guns, which we gladly did
Posted on Dec 31, 2009
  • 885 Answers
SOURCE: what angle nails are used
The Senco Frame Pro 601 uses 34 degree clipped head nails.
Posted on Nov 23, 2010
Plunger extended and blowing air in framing nailer
Air leaking out of head and driver extended indicates that the cylinder seal is bad and or the head valve is sticking or stuck in the head. Easy to check by removing the head and looking at the large plastic seal on top of the cylinder. If seal looks good, pull out the head valve and lube with white grease. Parts are here :
Good luck
Jul 20, 2014 | Porter Cable FR350A Factory Reconditioned...
Senco pro frame 601 just blows air when trigger is pulled
Senco nailers are mostly not lubricated but moisture and dirt do they have the neck compressor not tapped in time and then inside the top cover of this tools can have that or the parts are hanging can not move freely and clean, solvent them out and grease it with silicon OKS1110 Kluber Silubrin or Dow Corning DC4 in most cases the models of Senco are oilless IF the seal of the piston is made out of kevlar instead of a plain o-ring .
Jan 20, 2014 | Senco 1G0003R FactoryReconditioned...
What degree nails
Hi, Senco 601's use a 34 Degree Strip nail. Easiest way to remember is this when thinking of Senco strip nailers:
601 and 651 are 34 Degree clipped head nails
602 and 652 are 20 Degree FULL round head nails
www.collatedfasteners.co.uk
Mar 17, 2013 | Senco & Frame Pro 601 Framing Nailer
My frame pro 601 will sometimes shoot one to five times and then when you pull the triger nothing happens air comes out the core valve hole above the trigger when pulled then you can unplug air and tap on...
Senco makes a kit for your nail gun, part number YK0360. If you have any o-rings giving you problems, it's always best to replace all of them. You can get them from online parts stores like eReplacementparts.com or possibly from rental or repair places near you. Make sure you lubricate all the o-rings well when putting the new ones in.
Dec 13, 2012 | Senco & Frame Pro 601 Framing Nailer
I have a Senco Frame Pro framing nailer. The plunger is sticking in the
Check the drive pin for burrs and file them off. Check for worn piston replace if necessary. Clean the air return hole in the top of the piston cover. Add oil if manufacturer recommends it.
Mar 24, 2012 | Senco Air Tools & Compressors
Framepro 601. Works fine until air is disconnected then reconnected again, then it won't shoot and just discharges out the top 'vent' (not the exhaust). Some kind of safety lock is sticking?
Jul 28, 2009 | Senco & Frame Pro 601 Framing Nailer
Senco staple fastener not firing.
Make sure you actually removed the entire broken staple and there's not a piece still wedged up in there somehow.
Try raising the air pressure up to 125 psi and plug it in and unplug it a few times. Sometimes the piston can get jammed, and a smack with the palm of your hand on the side of the cylinder will jar it loose. If that doesn't work, try pulling the trigger as you jam the nose of the gun against a soft piece of 2x4 or something, repeatedly firing and jarring the tool. If this doesn't do it, you may have to open it up to clear the jam and put it back together.
Mar 28, 2009 | Senco Fastening Systems 760102N Pro 25 Xp...
Senco &  Frame Pro 601 Framing Nailer  Logo
195 people viewed this question
Top Senco Tools & Hardware - Others Experts
John Trevino
yoopertech
John Bowen
Are you a Senco Tool and Hardware - Other Expert? Answer questions, earn points and help others
