Question about Lexmark Wheelwriter 15 Series II Typewriter
Where do I find the return clutch torque limiter on an IBM2 wheelwriter
  • Lexmark Master
  • 3,594 Answers
The WW's don't have a torque limiter. If it isn't returning all the way and making a howling noise spray some WD40 on the shaft that the carrier slides on and also the carrier motor bearings.
DickyO
Posted on Mar 14, 2014
Why can't my 2006 jeep go into 4 wheel drive?
are you on dirt? or pavement...????????????????????????
we cant answer until you answer what 4wd option you have.
if that makes no sense, then read the operators guide,
it tells you what's there and how to use it.
read that first, then ask questions,?
and if Part time 4wd?, it';s not to be used on dry pavement only ICE.
eg:
4WD: Select-Trac (or older Select-Drive has a slip coupling too, NP129/229) is AWD in that, "the "4Hi" setting the drive shafts were coupled together using a viscous-type coupler " this anti wind up slipper"
Watch out for exception 1: Select-Trac NP228 based jeeps, it does not have a viscous-type limited-slip coupling. It was used briefly in 1986.
Quada-Trac is full time 4WD (not in lock mode) has a real center differential to shift torque between front and rear. This is the best system , not just a slip clutch as above. Then went BACK to the slipper in 1980. (odd huh?) Up to 1998.
Quadra-Trac-II "4-All Time", "N" or neutral, and "4-Lo". In "4-All Time", torque is applied to the rear wheels under normal driving conditions.
If the rear axle starts rotating at a significantly higher rate than the front axle, hydraulic pressure builds up in the gerotor oil pump and causes the clutch pack, to progressively transfer torque to the front axle, until both axles return to the same speed
Quadra-Trac I was introduced in 2004-10, same as above but is automatic with no driver controls ,like above.
The Quadra-Drive system was introduced in 1999 and is based on the Quadra-Trac II system but adds limited slip differentials (the best full time system ,with great traction to all wheels all the time) 1999 to 04.
Quadra-Drive-II has electronic limited slip differentials or ELSDs 2005 up.
Aug 01, 2014 | 2006 Jeep Grand Cherokee
Why wont my jep go into 4 wheel drive when I pull th lever?
which system?
we cant guess what is In YOUR CAR, ever.
you must SAY. or RTM, in the glove box.
and why are you using 4wd on dry pavement, now>?
Torque limiter quick to engage Why?
Usually it is a worn clutch that will cause this.
May 26, 2014 | Drills
Is there a diagram of where the clutch return spring is on a 2008 Hyundia Santa Fe?
The clutch don't have spring to return. hydraulic pressure return the pedal. if you pedal go down to the flour and don't return you lost the pressure. First look in the reservoir for fluid. add DOT3 brake fluid and bleed the system. inspect for leak
Good luck
Apr 15, 2014 | 2007 Hyundai Santa Fe Limited
I got one of these drivers to replace my older driver. It clearly has more than enough torque, which is good in some cases but for some routine things around the house it is too much. Even on the lowest...
Most models have two selections, one for the clutch (which in effect regulates the torque applied) and the other is the gear selection ( usually a setting of 1, 2 & 3, with 1 being for driving screws and 3 for drilling purposes). In addition to those selections, the trigger controls the overall speed of the motor. These are all the control you have over the drill, granted the Dewalt tool is a bit torquey, but it is meant to be a construction tool.
Nov 23, 2010 | Dewalt 18 Volt Compact Drill Kit
Rear cluch not working
Depends on what model and components you have:
ENGINE TORQUE DISTRIBUTION – DIRECTING THE FLOW OF POWER
In an all-wheel-drive vehicle, engine power can be directed to all four wheels. Subaru Symmetrical AWD differs slightly from model to model in how it directs power to the wheels, depending on its transmission.
MODELS WITH FIVE-SPEED MANUAL TRANSMISSION – CONTINUOUS ALL-WHEEL DRIVE: A viscous-type locking center differential and limited-slip rear differential help distribute torque – normally configured at a 50/50 split front to rear. If wheel speed differs between front and rear axles, the center and/or rear differentials lock up to help distribute power to the wheels with the most traction.
MODELS WITH FOUR-SPEED AUTOMATIC TRANSMISSIONS – ACTIVE ALL-WHEEL DRIVE: An electronically controlled variable transfer clutch and limited-slip rear differential distribute power to where traction is needed. Sensors monitor parameters such as wheel slippage, throttle position, and braking to help determine torque distribution and direct it to the wheels with optimum traction.
MODELS WITH FIVE-SPEED AUTOMATIC TRANSMISSION – VARIABLE TORQUE DISTRIBUTION ALL-WHEEL DRIVE: As with Active All-Wheel Drive, an electronically controlled variable transfer clutch distributes power, but through a planetary-type center differential and a viscous-type limited-slip rear differential. Torque distribution is normally configured at a performance-oriented rear-wheel-biased 45/55 split front to rear. Sensors monitor the same parameters as for Active All-Wheel Drive.
WRX STI, WITH SIX-SPEED MANUAL TRANSMISSION – DRIVER CONTROLLED CENTER DIFFERENTIAL (DCCD) ALL-WHEEL DRIVE: The STI uses an electronically managed multi-plate transfer clutch and a mechanical limited-slip differential in conjunction with a planetary-gear-type center differential to control power distribution between the front and rear wheels. Featuring manual and three automatic modes, DCCD is normally configured at a 41/59 split front to rear. Sensors monitor parameters such as wheel slippage, steering angle, throttle position, and braking to help determine torque distribution and direct it to the wheels with optimum traction. DCCD also features a limited-slip helical front and Torsen® rear differential. ... }
And what are the symptoms? How do you know the coupling to the rear is not working?
Jun 05, 2010 | 1995 Subaru Legacy
My IBM selectric II typewriter carriage stuck in right margin
Sounds like the return lever arm is not putting enough pressure on the return clutch, or the clutch is slipping. The exp key uses the same clutch but the pressure comes from your finger. Theres no way you can fix this yourself. Get an IBM mechanic.
Oct 14, 2009 | Lexmark Wheelwriter 15 Series II...
IBM Wheelwriter doesn't type until I hit return button.
On the R. side of the keyboard is a key that says print mode press this key and the dl print on the displaywill go out.
DickyO
Mar 17, 2009 | IBM Wheelwriter 30 Typewriter
IBM Selectric II
The return clutch torque limiter is off or broken. If you take the right dust cover off it is on the turning hub around the middle of the typewriter. a small spring about 1.25 inches long with a hook on the end. I have been fixing these for 35 years. good luck. Lawrence
Jun 06, 2008 | Lexmark Wheelwriter 15 Series II...
IBM wheelwriter 6 Series II
try turning the machine off put a SMALL amount of oil on the large round rod running across the typewriter manually push the print head left and right a few times to see if it will loosen up. The problem is usually caused be drying oil you may consider having it serviced by a pro.
Oct 31, 2007 | Lexmark Wheelwriter 6 Series II Typewriter
Lexmark Wheelwriter 15 Series II Typewriter Logo
41 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
